[Bug] Sonarr and Radarr not starting Topic is solved
Minimind
Re: [Bug] Sonarr and Radarr not starting
Post by Minimind »
Fourdee wrote: Please paste results, we'll check mono version installed:
dpkg -l | grep mono
I did what you asked me to do. It is running, but changing reinstalling etc is very iffy. Could you please look into the basic problem?
Kymru
Post by Kymru »
ok left this for a couple of months, can anyone confirm or deny if this has been resolved, i am itching to try and get Dietpi v6.x on my devices
brtravel
Post by brtravel »
I it just me, or is this still an issue? Sonarr was working great for weeks or months (with many reboots and power loss), then after a power loss it just won't come back today after 20+ reboots. I remember this happening before, but it was a couple months back and I can't remember what I did to fix it, perhaps just uninstall/reinstall Sonarr (and/or Mono?)?
v6.21.1
Odroid XU4
@brtravel
I believe it's due to a known bug in v6.21, resolved with v6.22 ETA this weekend.
Please try to resolve:
sed -i '/After=/s/[[:blank:]]multi-user.target//' /etc/systemd/system/dietpi-postboot.service
systemctl daemon-reload
systemctl enable dietpi-postboot
brtravel
Post by brtravel »
MichaIng wrote: Fri Mar 22, 2019 7:45 pm @brtravel
That's good to know, I'll wait for the new release rather than fighting this thing more.
I don't understand the code you gave, but I did run it. It doesn't seem to have changed anything. If I uninstall Sonarr and Mono, then install Sonarr, the first subsequent boot I can access the Sonarr GUI and it seems to be working fine. Then, if I reboot again, Sonarr starts out running (checked with 'htop' and 'dietpi-services status') BUT as soon as I navigate to the GUI it won't load, and then it has disappeared from the processes in 'htop' and shows as FAILED in 'dietpi-services status' (full readout below).
[FAILED] DietPi-Services | sonarr	failed (Result: signal) since Sat 2019-03-23 18:59:51 WITA; 17s ago
● sonarr.service - Sonarr (NzbDrone) Daemon (DietPi)
   Loaded: loaded (/etc/systemd/system/sonarr.service; disabled; vendor preset: enabled)
   Active: failed (Result: signal) since Sat 2019-03-23 18:59:51 WITA; 17s ago
  Process: 1086 ExecStart=/usr/bin/mono -O=-aot /opt/NzbDrone/NzbDrone.exe -nobrowser -data=/mnt/dietpi_userdata/sonarr (code=killed, signal=SEGV)
 Main PID: 1086 (code=killed, signal=SEGV)
Mar 23 18:56:00 DietPi mono[1086]: [Info] episode_last_searched_time: Starting migration to 130
Mar 23 18:56:00 DietPi mono[1086]: [Info] OwinHostController: Listening on the following URLs:
Mar 23 18:56:00 DietPi mono[1086]: [Info] OwinHostController:   http://*:8989/
Mar 23 18:56:02 DietPi mono[1086]: [Info] NancyBootstrapper: Starting Web Server
Mar 23 18:56:07 DietPi mono[1086]: [Warn] MonoDebugCheck: Mono is not running with --debug switch
Mar 23 18:59:51 DietPi mono[1086]: =================================================================
Mar 23 18:59:51 DietPi mono[1086]:         Native Crash Reporting
Mar 23 18:59:51 DietPi systemd[1]: sonarr.service: Main process exited, code=killed, status=11/SEGV
Mar 23 18:59:51 DietPi systemd[1]: sonarr.service: Unit entered failed state.
Mar 23 18:59:51 DietPi systemd[1]: sonarr.service: Failed with result 'signal'.
I just tested on test VM and it works well here.
Could you please run sonarr manually on terminal, try to access and if it crashes paste debug logs from terminal:
systemctl stop sonarr
sudo -u sonarr mono --debug -O=-aot /opt/NzbDrone/NzbDrone.exe -nobrowser -data=/mnt/dietpi_userdata/sonarr
This should log to terminal then, most likely a lot of output.
Access web UI to trigger failure (if that was the case, as far as I understood?)
Paste especially the output lines here that appeared when/after accessing the web UI
brtravel
Post by brtravel »
I saw the update available and did the update before seeing your reply, everything seems to be working fine now. Thank you!
Ah okay thanks for the feedback. Perhaps some mono update fixed it :).
