The weird point is that I hadn't this problem (read-only mount) before the 6.2 installation. All worked and was stable.
Now at each reboot of the PC, I have to re-mount manually the filesystem.
Is there a different kernel in 6.2 than in 6.1 ?
I've rebooted, the filesystem is in readonly, see here the dmesg report:
[ 0.000000] Linux version 4.9.0-5-amd64 (
debian-kernel@lists.debian.org) (gcc version 6.3.0 20170516 (Debian 6.3.0-18) ) #1 SMP Debian 4.9.65-3+deb9u2 (2018-01-04)
[ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-4.9.0-5-amd64 root=UUID=7f909194-7a22-4ca7-963b-1346ce7f67f3 ro net.ifnames=0 consoleblank=0 quiet
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[ 0.000000] x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
[ 0.000000] x86/fpu: Enabled xstate features 0x7, context size is 832 bytes, using 'compacted' format.
[ 0.000000] x86/fpu: Using 'eager' FPU context switches.
[ 0.000000] e820: BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009ffff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000000a0000-0x00000000000fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x0000000003ffffff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000004000000-0x0000000004009fff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x000000000400a000-0x0000000009cfffff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000009d00000-0x0000000009ffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000000a000000-0x000000000affffff] usable
[ 0.000000] BIOS-e820: [mem 0x000000000b000000-0x000000000b01ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000000b020000-0x00000000dbdcffff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000dbdd0000-0x00000000dbf1efff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000dbf1f000-0x00000000dc01dfff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000dc01e000-0x00000000dc3f2fff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x00000000dc3f3000-0x00000000dcef6fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000dcef7000-0x00000000dcf85fff] type 20
[ 0.000000] BIOS-e820: [mem 0x00000000dcf86000-0x00000000deffffff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000df000000-0x00000000dfffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000f8000000-0x00000000fbffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fea00000-0x00000000fea0ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000feb80000-0x00000000fec01fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fec10000-0x00000000fec10fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fec30000-0x00000000fec30fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed00000-0x00000000fed00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed40000-0x00000000fed44fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed80000-0x00000000fed8ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000feefffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000021f37ffff] usable
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] efi: EFI v2.60 by American Megatrends
[ 0.000000] efi: ACPI 2.0=0xdc01e000 ACPI=0xdc01e000 SMBIOS=0xdce63000 SMBIOS 3.0=0xdce62000 ESRT=0xda586e98 MEMATTR=0xd8dc1418
[ 0.000000] SMBIOS 3.1.1 present.
[ 0.000000] Kernel/User page tables isolation: disabled
[ 0.000000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.000000] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.000000] e820: last_pfn = 0x21f380 max_arch_pfn = 0x400000000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF write-through
[ 0.000000] C0000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000000 mask FFFF80000000 write-back
[ 0.000000] 1 base 000080000000 mask FFFFC0000000 write-back
[ 0.000000] 2 base 0000C0000000 mask FFFFE0000000 write-back
[ 0.000000] 3 disabled
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] TOM2: 0000000220000000 aka 8704M
[ 0.000000] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WC UC- WT
[ 0.000000] e820: update [mem 0xe0000000-0xffffffff] usable ==> reserved
[ 0.000000] e820: last_pfn = 0xdf000 max_arch_pfn = 0x400000000
[ 0.000000] esrt: Reserving ESRT space from 0x00000000da586e98 to 0x00000000da586ed0.
[ 0.000000] Base memory trampoline at [ffff991e00096000] 96000 size 24576
[ 0.000000] Using GB pages for direct mapping
[ 0.000000] BRK [0x137737000, 0x137737fff] PGTABLE
[ 0.000000] BRK [0x137738000, 0x137738fff] PGTABLE
[ 0.000000] BRK [0x137739000, 0x137739fff] PGTABLE
[ 0.000000] BRK [0x13773a000, 0x13773afff] PGTABLE
[ 0.000000] BRK [0x13773b000, 0x13773bfff] PGTABLE
[ 0.000000] BRK [0x13773c000, 0x13773cfff] PGTABLE
[ 0.000000] BRK [0x13773d000, 0x13773dfff] PGTABLE
[ 0.000000] BRK [0x13773e000, 0x13773efff] PGTABLE
[ 0.000000] BRK [0x13773f000, 0x13773ffff] PGTABLE
[ 0.000000] BRK [0x137740000, 0x137740fff] PGTABLE
[ 0.000000] BRK [0x137741000, 0x137741fff] PGTABLE
[ 0.000000] BRK [0x137742000, 0x137742fff] PGTABLE
[ 0.000000] RAMDISK: [mem 0x35ce3000-0x36e68fff]
[ 0.000000] ACPI: Early table checksum verification disabled
[ 0.000000] ACPI: RSDP 0x00000000DC01E000 000024 (v02 ALASKA)
[ 0.000000] ACPI: XSDT 0x00000000DC01E098 0000B4 (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: FACP 0x00000000DC0248A8 000114 (v06 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI BIOS Warning (bug): Optional FADT field Pm2ControlBlock has valid Length but zero Address: 0x0000000000000000/0x1 (20160831/tbfadt-658)
[ 0.000000] ACPI: DSDT 0x00000000DC01E1E8 0066BA (v02 ALASKA A M I 01072009 INTL 20120913)
[ 0.000000] ACPI: FACS 0x00000000DC3DBE00 000040
[ 0.000000] ACPI: APIC 0x00000000DC0249C0 0000DE (v03 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: FPDT 0x00000000DC024AA0 000044 (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: FIDT 0x00000000DC024AE8 00009C (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: SSDT 0x00000000DC024B88 008C98 (v02 AMD AMD ALIB 00000002 MSFT 04000000)
[ 0.000000] ACPI: SSDT 0x00000000DC02D820 000BB8 (v01 AMD AMD CPU 00000001 AMD 00000001)
[ 0.000000] ACPI: CRAT 0x00000000DC02E3D8 000BD0 (v01 AMD AMD CRAT 00000001 AMD 00000001)
[ 0.000000] ACPI: CDIT 0x00000000DC02EFA8 000029 (v01 AMD AMD CDIT 00000001 AMD 00000001)
[ 0.000000] ACPI: SSDT 0x00000000DC02EFD8 002DBA (v01 AMD AMD AOD 00000001 INTL 20120913)
[ 0.000000] ACPI: MCFG 0x00000000DC031D98 00003C (v01 ALASKA A M I 01072009 MSFT 00010013)
[ 0.000000] ACPI: HPET 0x00000000DC031DD8 000038 (v01 ALASKA A M I 01072009 AMI 00000005)
[ 0.000000] ACPI: SSDT 0x00000000DC031E10 000024 (v01 AMDFCH FCHZP 00001000 INTL 20120913)
[ 0.000000] ACPI: UEFI 0x00000000DC031E38 000042 (v01 00000000 00000000)
[ 0.000000] ACPI: BGRT 0x00000000DC031E80 000038 (v01 ALASKA ALASKA 01072009 AMI 00010013)
[ 0.000000] ACPI: IVRS 0x00000000DC031EB8 0000D0 (v02 AMD AMD IVRS 00000001 AMD 00000000)
[ 0.000000] ACPI: SSDT 0x00000000DC031F88 0000F8 (v01 AMD AMD PT 00001000 INTL 20120913)
[ 0.000000] ACPI: SSDT 0x00000000DC032080 001993 (v01 AMD AmdTable 00000001 INTL 20120913)
[ 0.000000] ACPI: WSMT 0x00000000DC033A18 000028 (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] No NUMA configuration found
[ 0.000000] Faking a node at [mem 0x0000000000000000-0x000000021f37ffff]
[ 0.000000] NODE_DATA(0) allocated [mem 0x21f37b000-0x21f37ffff]
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ 0.000000] DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
[ 0.000000] Normal [mem 0x0000000100000000-0x000000021f37ffff]
[ 0.000000] Device empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000001000-0x000000000009ffff]
[ 0.000000] node 0: [mem 0x0000000000100000-0x0000000003ffffff]
[ 0.000000] node 0: [mem 0x000000000400a000-0x0000000009cfffff]
[ 0.000000] node 0: [mem 0x000000000a000000-0x000000000affffff]
[ 0.000000] node 0: [mem 0x000000000b020000-0x00000000dbdcffff]
[ 0.000000] node 0: [mem 0x00000000dbf1f000-0x00000000dc01dfff]
[ 0.000000] node 0: [mem 0x00000000dcf86000-0x00000000deffffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x000000021f37ffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000001000-0x000000021f37ffff]
[ 0.000000] On node 0 totalpages: 2084670
[ 0.000000] DMA zone: 64 pages used for memmap
[ 0.000000] DMA zone: 27 pages reserved
[ 0.000000] DMA zone: 3999 pages, LIFO batch:0
[ 0.000000] DMA32 zone: 14129 pages used for memmap
[ 0.000000] DMA32 zone: 904223 pages, LIFO batch:31
[ 0.000000] Normal zone: 18382 pages used for memmap
[ 0.000000] Normal zone: 1176448 pages, LIFO batch:31
[ 0.000000] ACPI: PM-Timer IO Port: 0x808
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
[ 0.000000] IOAPIC[0]: apic_id 7, version 33, address 0xfec00000, GSI 0-23
[ 0.000000] IOAPIC[1]: apic_id 8, version 33, address 0xfec01000, GSI 24-55
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] ACPI: HPET id: 0x10228201 base: 0xfed00000
[ 0.000000] smpboot: Allowing 16 CPUs, 10 hotplug CPUs
[ 0.000000] PM: Registered nosave memory: [mem 0x00000000-0x00000fff]
[ 0.000000] PM: Registered nosave memory: [mem 0x000a0000-0x000fffff]
[ 0.000000] PM: Registered nosave memory: [mem 0x04000000-0x04009fff]
[ 0.000000] PM: Registered nosave memory: [mem 0x09d00000-0x09ffffff]
[ 0.000000] PM: Registered nosave memory: [mem 0x0b000000-0x0b01ffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xdbdd0000-0xdbf1efff]
[ 0.000000] PM: Registered nosave memory: [mem 0xdc01e000-0xdc3f2fff]
[ 0.000000] PM: Registered nosave memory: [mem 0xdc3f3000-0xdcef6fff]
[ 0.000000] PM: Registered nosave memory: [mem 0xdcef7000-0xdcf85fff]
[ 0.000000] PM: Registered nosave memory: [mem 0xdf000000-0xdfffffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xe0000000-0xf7ffffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xf8000000-0xfbffffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfc000000-0xfe9fffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfea00000-0xfea0ffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfea10000-0xfeb7ffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfeb80000-0xfec01fff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfec02000-0xfec0ffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfec10000-0xfec10fff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfec11000-0xfec2ffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfec30000-0xfec30fff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfec31000-0xfecfffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfed00000-0xfed00fff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfed01000-0xfed3ffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfed40000-0xfed44fff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfed45000-0xfed7ffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfed80000-0xfed8ffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfed90000-0xfedfffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfee00000-0xfeefffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfef00000-0xfeffffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xff000000-0xffffffff]
[ 0.000000] e820: [mem 0xe0000000-0xf7ffffff] available for PCI devices
[ 0.000000] Booting paravirtualized kernel on bare hardware
[ 0.000000] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645519600211568 ns
[ 0.000000] setup_percpu: NR_CPUS:512 nr_cpumask_bits:512 nr_cpu_ids:16 nr_node_ids:1
[ 0.000000] percpu: Embedded 35 pages/cpu @ffff99201ec00000 s105304 r8192 d29864 u262144
[ 0.000000] pcpu-alloc: s105304 r8192 d29864 u262144 alloc=1*2097152
[ 0.000000] pcpu-alloc: [0] 00 01 02 03 04 05 06 07 [0] 08 09 10 11 12 13 14 15
[ 0.000000] Built 1 zonelists in Node order, mobility grouping on. Total pages: 2052068
[ 0.000000] Policy zone: Normal
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.9.0-5-amd64 root=UUID=7f909194-7a22-4ca7-963b-1346ce7f67f3 ro net.ifnames=0 consoleblank=0 quiet
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Calgary: detecting Calgary via BIOS EBDA area
[ 0.000000] Calgary: Unable to locate Rio Grande table in EBDA - bailing!
[ 0.000000] Memory: 7959300K/8338680K available (6196K kernel code, 1159K rwdata, 2848K rodata, 1408K init, 688K bss, 379380K reserved, 0K cma-reserved)
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=512 to nr_cpu_ids=16.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=16
[ 0.000000] NR_IRQS:33024 nr_irqs:1096 16
[ 0.000000] Console: colour dummy device 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484873504 ns
[ 0.000000] hpet clockevent registered
[ 0.000000] tsc: Fast TSC calibration failed
[ 0.000000] tsc: PIT calibration matches HPET. 1 loops
[ 0.000000] tsc: Detected 3193.920 MHz processor
[ 0.000013] Calibrating delay loop (skipped), value calculated using timer frequency.. 6387.84 BogoMIPS (lpj=12775680)
[ 0.000015] pid_max: default: 32768 minimum: 301
[ 0.000029] ACPI: Core revision 20160831
[ 0.008707] ACPI: 7 ACPI AML tables successfully acquired and loaded
[ 0.009377] Security Framework initialized
[ 0.009378] Yama: disabled by default; enable with sysctl kernel.yama.*
[ 0.009382] AppArmor: AppArmor disabled by boot time parameter
[ 0.009601] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.010791] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.011340] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.011344] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.011567] CPU: Physical Processor ID: 0
[ 0.011568] CPU: Processor Core ID: 0
[ 0.011574] mce: CPU supports 23 MCE banks
[ 0.011589] LVT offset 1 assigned for vector 0xf9
[ 0.011650] LVT offset 2 assigned for vector 0xf4
[ 0.011660] Last level iTLB entries: 4KB 1024, 2MB 1024, 4MB 512
[ 0.011660] Last level dTLB entries: 4KB 1536, 2MB 1536, 4MB 768, 1GB 0
[ 0.012624] Freeing SMP alternatives memory: 24K
[ 0.015864] ftrace: allocating 25212 entries in 99 pages
[ 0.023324] smpboot: Max logical packages: 3
[ 0.182137] Switched APIC routing to physical flat.
[ 0.182892] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.327148] smpboot: CPU0: AMD Ryzen 5 1600 Six-Core Processor (family: 0x17, model: 0x1, stepping: 0x1)
[ 0.327150] Performance Events: Fam17h core perfctr, AMD PMU driver.
[ 0.327153] ... version: 0
[ 0.327153] ... bit width: 48
[ 0.327153] ... generic registers: 6
[ 0.327154] ... value mask: 0000ffffffffffff
[ 0.327154] ... max period: 00007fffffffffff
[ 0.327154] ... fixed-purpose events: 0
[ 0.327155] ... event mask: 000000000000003f
[ 0.327613] NMI watchdog: enabled on all CPUs, permanently consumes one hw-PMU counter.
[ 0.327687] x86: Booting SMP configuration:
[ 0.327687] .... node #0, CPUs: #1 #2 #3 #4 #5
[ 0.339001] x86: Booted up 1 node, 6 CPUs
[ 0.339003] smpboot: Total of 6 processors activated (38327.04 BogoMIPS)
[ 0.339805] devtmpfs: initialized
[ 0.339849] x86/mm: Memory block size: 128MB
[ 0.342108] PM: Registering ACPI NVS region [mem 0x04000000-0x04009fff] (40960 bytes)
[ 0.342109] PM: Registering ACPI NVS region [mem 0xdc01e000-0xdc3f2fff] (4018176 bytes)
[ 0.342216] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.342229] futex hash table entries: 4096 (order: 6, 262144 bytes)
[ 0.342295] pinctrl core: initialized pinctrl subsystem
[ 0.342409] NET: Registered protocol family 16
[ 0.351180] cpuidle: using governor ladder
[ 0.367180] cpuidle: using governor menu
[ 0.367425] ACPI: bus type PCI registered
[ 0.367425] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.367478] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000)
[ 0.367479] PCI: MMCONFIG at [mem 0xf8000000-0xfbffffff] reserved in E820
[ 0.367485] PCI: Using configuration type 1 for base access
[ 0.383353] HugeTLB registered 1 GB page size, pre-allocated 0 pages
[ 0.383353] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.383598] ACPI: Added _OSI(Module Device)
[ 0.383599] ACPI: Added _OSI(Processor Device)
[ 0.383599] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.383599] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.383756] ACPI: Executed 2 blocks of module-level executable AML code
[ 0.387494] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[ 0.389846] ACPI: Interpreter enabled
[ 0.389856] ACPI: (supports S0 S4 S5)
[ 0.389857] ACPI: Using IOAPIC for interrupt routing
[ 0.390044] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.395910] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.395913] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
[ 0.396090] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
[ 0.396100] acpi PNP0A08:00: [Firmware Info]: MMCONFIG for domain 0000 [bus 00-3f] only partially covers this bridge
[ 0.396345] PCI host bridge to bus 0000:00
[ 0.396346] pci_bus 0000:00: root bus resource [io 0x0000-0x03af window]
[ 0.396347] pci_bus 0000:00: root bus resource [io 0x03e0-0x0cf7 window]
[ 0.396348] pci_bus 0000:00: root bus resource [io 0x03b0-0x03df window]
[ 0.396349] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 0.396350] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[ 0.396351] pci_bus 0000:00: root bus resource [mem 0x000c0000-0x000dffff window]
[ 0.396352] pci_bus 0000:00: root bus resource [mem 0xe0000000-0xf7ffffff window]
[ 0.396353] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.396359] pci 0000:00:00.0: [1022:1450] type 00 class 0x060000
[ 0.396433] pci 0000:00:00.2: [1022:1451] type 00 class 0x080600
[ 0.396513] pci 0000:00:01.0: [1022:1452] type 00 class 0x060000
[ 0.396567] pci 0000:00:01.1: [1022:1453] type 01 class 0x060400
[ 0.396662] pci 0000:00:01.1: PME# supported from D0 D3hot D3cold
[ 0.397323] pci 0000:00:01.1: System wakeup disabled by ACPI
[ 0.397351] pci 0000:00:01.3: [1022:1453] type 01 class 0x060400
[ 0.397444] pci 0000:00:01.3: PME# supported from D0 D3hot D3cold
[ 0.397492] pci 0000:00:01.3: System wakeup disabled by ACPI
[ 0.397521] pci 0000:00:02.0: [1022:1452] type 00 class 0x060000
[ 0.397588] pci 0000:00:03.0: [1022:1452] type 00 class 0x060000
[ 0.397655] pci 0000:00:04.0: [1022:1452] type 00 class 0x060000
[ 0.397727] pci 0000:00:07.0: [1022:1452] type 00 class 0x060000
[ 0.397780] pci 0000:00:07.1: [1022:1454] type 01 class 0x060400
[ 0.398117] pci 0000:00:07.1: PME# supported from D0 D3hot D3cold
[ 0.398158] pci 0000:00:07.1: System wakeup disabled by ACPI
[ 0.398191] pci 0000:00:08.0: [1022:1452] type 00 class 0x060000
[ 0.398244] pci 0000:00:08.1: [1022:1454] type 01 class 0x060400
[ 0.398335] pci 0000:00:08.1: PME# supported from D0 D3hot D3cold
[ 0.398377] pci 0000:00:08.1: System wakeup disabled by ACPI
[ 0.398446] pci 0000:00:14.0: [1022:790b] type 00 class 0x0c0500
[ 0.398645] pci 0000:00:14.3: [1022:790e] type 00 class 0x060100
[ 0.398848] pci 0000:00:18.0: [1022:1460] type 00 class 0x060000
[ 0.398896] pci 0000:00:18.1: [1022:1461] type 00 class 0x060000
[ 0.398942] pci 0000:00:18.2: [1022:1462] type 00 class 0x060000
[ 0.398990] pci 0000:00:18.3: [1022:1463] type 00 class 0x060000
[ 0.399036] pci 0000:00:18.4: [1022:1464] type 00 class 0x060000
[ 0.399087] pci 0000:00:18.5: [1022:1465] type 00 class 0x060000
[ 0.399139] pci 0000:00:18.6: [1022:1466] type 00 class 0x060000
[ 0.399190] pci 0000:00:18.7: [1022:1467] type 00 class 0x060000
[ 0.399333] pci 0000:01:00.0: [1987:5007] type 00 class 0x010802
[ 0.399345] pci 0000:01:00.0: reg 0x10: [mem 0xf7900000-0xf7903fff 64bit]
[ 0.414999] pci 0000:00:01.1: PCI bridge to [bus 01]
[ 0.415003] pci 0000:00:01.1: bridge window [mem 0xf7900000-0xf79fffff]
[ 0.415112] pci 0000:02:00.0: [1022:43bb] type 00 class 0x0c0330
[ 0.415127] pci 0000:02:00.0: reg 0x10: [mem 0xf73a0000-0xf73a7fff 64bit]
[ 0.415198] pci 0000:02:00.0: PME# supported from D3hot D3cold
[ 0.415233] pci 0000:02:00.0: System wakeup disabled by ACPI
[ 0.415265] pci 0000:02:00.1: [1022:43b7] type 00 class 0x010601
[ 0.415304] pci 0000:02:00.1: reg 0x24: [mem 0xf7380000-0xf739ffff]
[ 0.415311] pci 0000:02:00.1: reg 0x30: [mem 0xf7300000-0xf737ffff pref]
[ 0.415343] pci 0000:02:00.1: PME# supported from D3hot D3cold
[ 0.415390] pci 0000:02:00.2: [1022:43b2] type 01 class 0x060400
[ 0.415451] pci 0000:02:00.2: PME# supported from D3hot D3cold
[ 0.431000] pci 0000:00:01.3: PCI bridge to [bus 02-07]
[ 0.431003] pci 0000:00:01.3: bridge window [io 0xe000-0xffff]
[ 0.431005] pci 0000:00:01.3: bridge window [mem 0xf6000000-0xf73fffff]
[ 0.431008] pci 0000:00:01.3: bridge window [mem 0xe8000000-0xf21fffff 64bit pref]
[ 0.431097] pci 0000:03:00.0: [1022:43b4] type 01 class 0x060400
[ 0.431171] pci 0000:03:00.0: PME# supported from D3hot D3cold
[ 0.431239] pci 0000:03:01.0: [1022:43b4] type 01 class 0x060400
[ 0.431309] pci 0000:03:01.0: PME# supported from D3hot D3cold
[ 0.431372] pci 0000:03:04.0: [1022:43b4] type 01 class 0x060400
[ 0.431442] pci 0000:03:04.0: PME# supported from D3hot D3cold
[ 0.431516] pci 0000:02:00.2: PCI bridge to [bus 03-07]
[ 0.431520] pci 0000:02:00.2: bridge window [io 0xe000-0xffff]
[ 0.431522] pci 0000:02:00.2: bridge window [mem 0xf6000000-0xf72fffff]
[ 0.431526] pci 0000:02:00.2: bridge window [mem 0xe8000000-0xf21fffff 64bit pref]
[ 0.431576] pci 0000:04:00.0: [10ec:8168] type 00 class 0x020000
[ 0.431600] pci 0000:04:00.0: reg 0x10: [io 0xf000-0xf0ff]
[ 0.431635] pci 0000:04:00.0: reg 0x18: [mem 0xf7200000-0xf7200fff 64bit]
[ 0.431656] pci 0000:04:00.0: reg 0x20: [mem 0xf2100000-0xf2103fff 64bit pref]
[ 0.431775] pci 0000:04:00.0: supports D1 D2
[ 0.431775] pci 0000:04:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.447007] pci 0000:03:00.0: PCI bridge to [bus 04]
[ 0.447012] pci 0000:03:00.0: bridge window [io 0xf000-0xffff]
[ 0.447014] pci 0000:03:00.0: bridge window [mem 0xf7200000-0xf72fffff]
[ 0.447019] pci 0000:03:00.0: bridge window [mem 0xf2100000-0xf21fffff 64bit pref]
[ 0.447088] pci 0000:05:00.0: [1283:8892] type 01 class 0x060401
[ 0.447231] pci 0000:05:00.0: supports D1 D2
[ 0.447232] pci 0000:05:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.447273] pci 0000:03:01.0: PCI bridge to [bus 05-06]
[ 0.447413] pci 0000:05:00.0: PCI bridge to [bus 06] (subtractive decode)
[ 0.447501] pci 0000:07:00.0: [10de:128b] type 00 class 0x030000
[ 0.447517] pci 0000:07:00.0: reg 0x10: [mem 0xf6000000-0xf6ffffff]
[ 0.447532] pci 0000:07:00.0: reg 0x14: [mem 0xe8000000-0xefffffff 64bit pref]
[ 0.447547] pci 0000:07:00.0: reg 0x1c: [mem 0xf0000000-0xf1ffffff 64bit pref]
[ 0.447557] pci 0000:07:00.0: reg 0x24: [io 0xe000-0xe07f]
[ 0.447566] pci 0000:07:00.0: reg 0x30: [mem 0xf7000000-0xf707ffff pref]
[ 0.447682] pci 0000:07:00.1: [10de:0e0f] type 00 class 0x040300
[ 0.447698] pci 0000:07:00.1: reg 0x10: [mem 0xf7080000-0xf7083fff]
[ 0.463008] pci 0000:03:04.0: PCI bridge to [bus 07]
[ 0.463013] pci 0000:03:04.0: bridge window [io 0xe000-0xefff]
[ 0.463016] pci 0000:03:04.0: bridge window [mem 0xf6000000-0xf70fffff]
[ 0.463020] pci 0000:03:04.0: bridge window [mem 0xe8000000-0xf1ffffff 64bit pref]
[ 0.463365] pci 0000:08:00.0: [1022:145a] type 00 class 0x130000
[ 0.463442] pci 0000:08:00.2: [1022:1456] type 00 class 0x108000
[ 0.463451] pci 0000:08:00.2: reg 0x18: [mem 0xf7600000-0xf76fffff]
[ 0.463458] pci 0000:08:00.2: reg 0x24: [mem 0xf7700000-0xf7701fff]
[ 0.463523] pci 0000:08:00.3: [1022:145c] type 00 class 0x0c0330
[ 0.463531] pci 0000:08:00.3: reg 0x10: [mem 0xf7500000-0xf75fffff 64bit]
[ 0.463569] pci 0000:08:00.3: PME# supported from D0 D3hot D3cold
[ 0.463586] pci 0000:08:00.3: System wakeup disabled by ACPI
[ 0.463618] pci 0000:00:07.1: PCI bridge to [bus 08]
[ 0.463621] pci 0000:00:07.1: bridge window [mem 0xf7500000-0xf77fffff]
[ 0.463685] pci 0000:09:00.0: [1022:1455] type 00 class 0x130000
[ 0.463763] pci 0000:09:00.2: [1022:7901] type 00 class 0x010601
[ 0.463785] pci 0000:09:00.2: reg 0x24: [mem 0xf7808000-0xf7808fff]
[ 0.463814] pci 0000:09:00.2: PME# supported from D3hot D3cold
[ 0.463857] pci 0000:09:00.3: [1022:1457] type 00 class 0x040300
[ 0.463862] pci 0000:09:00.3: reg 0x10: [mem 0xf7800000-0xf7807fff]
[ 0.463901] pci 0000:09:00.3: PME# supported from D0 D3hot D3cold
[ 0.463950] pci 0000:00:08.1: PCI bridge to [bus 09]
[ 0.463953] pci 0000:00:08.1: bridge window [mem 0xf7800000-0xf78fffff]
[ 0.464337] ACPI: PCI Interrupt Link [LNKA] (IRQs 4 5 7 10 11 14 15) *0
[ 0.464384] ACPI: PCI Interrupt Link [LNKB] (IRQs 4 5 7 10 11 14 15) *0
[ 0.464425] ACPI: PCI Interrupt Link [LNKC] (IRQs 4 5 7 10 11 14 15) *0
[ 0.464475] ACPI: PCI Interrupt Link [LNKD] (IRQs 4 5 7 10 11 14 15) *0
[ 0.464520] ACPI: PCI Interrupt Link [LNKE] (IRQs 4 5 7 10 11 14 15) *0
[ 0.464557] ACPI: PCI Interrupt Link [LNKF] (IRQs 4 5 7 10 11 14 15) *0
[ 0.464591] ACPI: PCI Interrupt Link [LNKG] (IRQs 4 5 7 10 11 14 15) *0
[ 0.464622] ACPI: PCI Interrupt Link [LNKH] (IRQs 4 5 7 10 11 14 15) *0
[ 0.465054] vgaarb: setting as boot device: PCI:0000:07:00.0
[ 0.465055] vgaarb: device added: PCI:0000:07:00.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.465055] vgaarb: loaded
[ 0.465056] vgaarb: bridge control possible 0000:07:00.0
[ 0.465081] Registered efivars operations
[ 0.475896] PCI: Using ACPI for IRQ routing
[ 0.480201] PCI: pci_cache_line_size set to 64 bytes
[ 0.480260] e820: reserve RAM buffer [mem 0x09d00000-0x0bffffff]
[ 0.480261] e820: reserve RAM buffer [mem 0x0b000000-0x0bffffff]
[ 0.480262] e820: reserve RAM buffer [mem 0xdbdd0000-0xdbffffff]
[ 0.480263] e820: reserve RAM buffer [mem 0xdc01e000-0xdfffffff]
[ 0.480263] e820: reserve RAM buffer [mem 0xdf000000-0xdfffffff]
[ 0.480264] e820: reserve RAM buffer [mem 0x21f380000-0x21fffffff]
[ 0.480493] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[ 0.480495] hpet0: 3 comparators, 32-bit 14.318180 MHz counter
[ 0.482637] clocksource: Switched to clocksource hpet
[ 0.487103] VFS: Disk quotas dquot_6.6.0
[ 0.487123] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.487179] pnp: PnP ACPI init
[ 0.487245] system 00:00: [mem 0xf8000000-0xfbffffff] has been reserved
[ 0.487247] system 00:00: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.487305] system 00:01: [mem 0xfeb80000-0xfebfffff] could not be reserved
[ 0.487307] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.487360] pnp 00:02: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.487480] system 00:03: [io 0x0a00-0x0a2f] has been reserved
[ 0.487481] system 00:03: [io 0x0a30-0x0a3f] has been reserved
[ 0.487483] system 00:03: [io 0x0a40-0x0a4f] has been reserved
[ 0.487484] system 00:03: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.487724] pnp 00:04: [dma 0 disabled]
[ 0.487805] pnp 00:04: Plug and Play ACPI device, IDs PNP0400 (active)
[ 0.488002] pnp 00:05: [dma 0 disabled]
[ 0.488030] pnp 00:05: Plug and Play ACPI device, IDs PNP0501 (active)
[ 0.488191] system 00:06: [io 0x04d0-0x04d1] has been reserved
[ 0.488192] system 00:06: [io 0x040b] has been reserved
[ 0.488193] system 00:06: [io 0x04d6] has been reserved
[ 0.488193] system 00:06: [io 0x0c00-0x0c01] has been reserved
[ 0.488194] system 00:06: [io 0x0c14] has been reserved
[ 0.488195] system 00:06: [io 0x0c50-0x0c51] has been reserved
[ 0.488196] system 00:06: [io 0x0c52] has been reserved
[ 0.488197] system 00:06: [io 0x0c6c] has been reserved
[ 0.488198] system 00:06: [io 0x0c6f] has been reserved
[ 0.488199] system 00:06: [io 0x0cd0-0x0cd1] has been reserved
[ 0.488200] system 00:06: [io 0x0cd2-0x0cd3] has been reserved
[ 0.488201] system 00:06: [io 0x0cd4-0x0cd5] has been reserved
[ 0.488201] system 00:06: [io 0x0cd6-0x0cd7] has been reserved
[ 0.488202] system 00:06: [io 0x0cd8-0x0cdf] has been reserved
[ 0.488203] system 00:06: [io 0x0800-0x089f] has been reserved
[ 0.488204] system 00:06: [io 0x0b00-0x0b0f] has been reserved
[ 0.488205] system 00:06: [io 0x0b20-0x0b3f] has been reserved
[ 0.488206] system 00:06: [io 0x0900-0x090f] has been reserved
[ 0.488207] system 00:06: [io 0x0910-0x091f] has been reserved
[ 0.488208] system 00:06: [mem 0xfec00000-0xfec00fff] could not be reserved
[ 0.488210] system 00:06: [mem 0xfec01000-0xfec01fff] could not be reserved
[ 0.488211] system 00:06: [mem 0xfedc0000-0xfedc0fff] has been reserved
[ 0.488212] system 00:06: [mem 0xfee00000-0xfee00fff] has been reserved
[ 0.488213] system 00:06: [mem 0xfed80000-0xfed8ffff] could not be reserved
[ 0.488214] system 00:06: [mem 0xfec10000-0xfec10fff] has been reserved
[ 0.488215] system 00:06: [mem 0xff000000-0xffffffff] has been reserved
[ 0.488216] system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.488541] pnp: PnP ACPI: found 7 devices
[ 0.494920] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.494972] pci 0000:00:01.1: PCI bridge to [bus 01]
[ 0.494974] pci 0000:00:01.1: bridge window [mem 0xf7900000-0xf79fffff]
[ 0.494978] pci 0000:03:00.0: PCI bridge to [bus 04]
[ 0.494980] pci 0000:03:00.0: bridge window [io 0xf000-0xffff]
[ 0.494983] pci 0000:03:00.0: bridge window [mem 0xf7200000-0xf72fffff]
[ 0.494986] pci 0000:03:00.0: bridge window [mem 0xf2100000-0xf21fffff 64bit pref]
[ 0.494990] pci 0000:05:00.0: PCI bridge to [bus 06]
[ 0.495012] pci 0000:03:01.0: PCI bridge to [bus 05-06]
[ 0.495020] pci 0000:03:04.0: PCI bridge to [bus 07]
[ 0.495022] pci 0000:03:04.0: bridge window [io 0xe000-0xefff]
[ 0.495025] pci 0000:03:04.0: bridge window [mem 0xf6000000-0xf70fffff]
[ 0.495027] pci 0000:03:04.0: bridge window [mem 0xe8000000-0xf1ffffff 64bit pref]
[ 0.495031] pci 0000:02:00.2: PCI bridge to [bus 03-07]
[ 0.495032] pci 0000:02:00.2: bridge window [io 0xe000-0xffff]
[ 0.495035] pci 0000:02:00.2: bridge window [mem 0xf6000000-0xf72fffff]
[ 0.495038] pci 0000:02:00.2: bridge window [mem 0xe8000000-0xf21fffff 64bit pref]
[ 0.495041] pci 0000:00:01.3: PCI bridge to [bus 02-07]
[ 0.495042] pci 0000:00:01.3: bridge window [io 0xe000-0xffff]
[ 0.495044] pci 0000:00:01.3: bridge window [mem 0xf6000000-0xf73fffff]
[ 0.495046] pci 0000:00:01.3: bridge window [mem 0xe8000000-0xf21fffff 64bit pref]
[ 0.495048] pci 0000:00:07.1: PCI bridge to [bus 08]
[ 0.495050] pci 0000:00:07.1: bridge window [mem 0xf7500000-0xf77fffff]
[ 0.495053] pci 0000:00:08.1: PCI bridge to [bus 09]
[ 0.495055] pci 0000:00:08.1: bridge window [mem 0xf7800000-0xf78fffff]
[ 0.495059] pci_bus 0000:00: resource 4 [io 0x0000-0x03af window]
[ 0.495059] pci_bus 0000:00: resource 5 [io 0x03e0-0x0cf7 window]
[ 0.495060] pci_bus 0000:00: resource 6 [io 0x03b0-0x03df window]
[ 0.495061] pci_bus 0000:00: resource 7 [io 0x0d00-0xffff window]
[ 0.495062] pci_bus 0000:00: resource 8 [mem 0x000a0000-0x000bffff window]
[ 0.495062] pci_bus 0000:00: resource 9 [mem 0x000c0000-0x000dffff window]
[ 0.495063] pci_bus 0000:00: resource 10 [mem 0xe0000000-0xf7ffffff window]
[ 0.495064] pci_bus 0000:01: resource 1 [mem 0xf7900000-0xf79fffff]
[ 0.495064] pci_bus 0000:02: resource 0 [io 0xe000-0xffff]
[ 0.495065] pci_bus 0000:02: resource 1 [mem 0xf6000000-0xf73fffff]
[ 0.495066] pci_bus 0000:02: resource 2 [mem 0xe8000000-0xf21fffff 64bit pref]
[ 0.495066] pci_bus 0000:03: resource 0 [io 0xe000-0xffff]
[ 0.495067] pci_bus 0000:03: resource 1 [mem 0xf6000000-0xf72fffff]
[ 0.495068] pci_bus 0000:03: resource 2 [mem 0xe8000000-0xf21fffff 64bit pref]
[ 0.495068] pci_bus 0000:04: resource 0 [io 0xf000-0xffff]
[ 0.495069] pci_bus 0000:04: resource 1 [mem 0xf7200000-0xf72fffff]
[ 0.495070] pci_bus 0000:04: resource 2 [mem 0xf2100000-0xf21fffff 64bit pref]
[ 0.495071] pci_bus 0000:07: resource 0 [io 0xe000-0xefff]
[ 0.495071] pci_bus 0000:07: resource 1 [mem 0xf6000000-0xf70fffff]
[ 0.495072] pci_bus 0000:07: resource 2 [mem 0xe8000000-0xf1ffffff 64bit pref]
[ 0.495073] pci_bus 0000:08: resource 1 [mem 0xf7500000-0xf77fffff]
[ 0.495073] pci_bus 0000:09: resource 1 [mem 0xf7800000-0xf78fffff]
[ 0.495277] NET: Registered protocol family 2
[ 0.495437] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.495523] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.495627] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.495647] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.495666] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.495723] NET: Registered protocol family 1
[ 0.495860] pci 0000:07:00.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[ 0.495956] PCI: CLS 64 bytes, default 64
[ 0.495984] Unpacking initramfs...
[ 0.704603] Freeing initrd memory: 17944K
[ 0.704624] AMD-Vi: IOMMU performance counters supported
[ 0.704901] iommu: Adding device 0000:00:01.0 to group 0
[ 0.705007] iommu: Adding device 0000:00:01.1 to group 1
[ 0.705111] iommu: Adding device 0000:00:01.3 to group 2
[ 0.705221] iommu: Adding device 0000:00:02.0 to group 3
[ 0.705329] iommu: Adding device 0000:00:03.0 to group 4
[ 0.705432] iommu: Adding device 0000:00:04.0 to group 5
[ 0.705536] iommu: Adding device 0000:00:07.0 to group 6
[ 0.705639] iommu: Adding device 0000:00:07.1 to group 7
[ 0.705745] iommu: Adding device 0000:00:08.0 to group 8
[ 0.705852] iommu: Adding device 0000:00:08.1 to group 9
[ 0.705961] iommu: Adding device 0000:00:14.0 to group 10
[ 0.705973] iommu: Adding device 0000:00:14.3 to group 10
[ 0.706091] iommu: Adding device 0000:00:18.0 to group 11
[ 0.706103] iommu: Adding device 0000:00:18.1 to group 11
[ 0.706114] iommu: Adding device 0000:00:18.2 to group 11
[ 0.706125] iommu: Adding device 0000:00:18.3 to group 11
[ 0.706136] iommu: Adding device 0000:00:18.4 to group 11
[ 0.706147] iommu: Adding device 0000:00:18.5 to group 11
[ 0.706157] iommu: Adding device 0000:00:18.6 to group 11
[ 0.706167] iommu: Adding device 0000:00:18.7 to group 11
[ 0.706272] iommu: Adding device 0000:01:00.0 to group 12
[ 0.706390] iommu: Adding device 0000:02:00.0 to group 13
[ 0.706409] iommu: Adding device 0000:02:00.1 to group 13
[ 0.706425] iommu: Adding device 0000:02:00.2 to group 13
[ 0.706437] iommu: Adding device 0000:03:00.0 to group 13
[ 0.706448] iommu: Adding device 0000:03:01.0 to group 13
[ 0.706458] iommu: Adding device 0000:03:04.0 to group 13
[ 0.706475] iommu: Adding device 0000:04:00.0 to group 13
[ 0.706485] iommu: Adding device 0000:05:00.0 to group 13
[ 0.706498] iommu: Adding device 0000:07:00.0 to group 13
[ 0.706509] iommu: Adding device 0000:07:00.1 to group 13
[ 0.706619] iommu: Adding device 0000:08:00.0 to group 14
[ 0.706762] iommu: Adding device 0000:08:00.2 to group 15
[ 0.706868] iommu: Adding device 0000:08:00.3 to group 16
[ 0.706977] iommu: Adding device 0000:09:00.0 to group 17
[ 0.707085] iommu: Adding device 0000:09:00.2 to group 18
[ 0.707195] iommu: Adding device 0000:09:00.3 to group 19
[ 0.707399] AMD-Vi: Found IOMMU at 0000:00:00.2 cap 0x40
[ 0.707400] AMD-Vi: Extended features (0xf77ef22294ada):
[ 0.707401] PPR NX GT IA GA PC GA_vAPIC
[ 0.707403] AMD-Vi: Interrupt remapping enabled
[ 0.707403] AMD-Vi: virtual APIC enabled
[ 0.707627] AMD-Vi: Lazy IO/TLB flushing enabled
[ 0.708510] perf: AMD NB counters detected
[ 0.708514] perf: AMD L2I counters detected
[ 0.708932] perf: amd_iommu: Detected. (0 banks, 0 counters/bank)
[ 0.709320] audit: initializing netlink subsys (disabled)
[ 0.709335] audit: type=2000 audit(1520153219.448:1): initialized
[ 0.709664] workingset: timestamp_bits=40 max_order=21 bucket_order=0
[ 0.709744] zbud: loaded
[ 0.710452] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[ 0.710488] io scheduler noop registered
[ 0.710489] io scheduler deadline registered
[ 0.710501] io scheduler cfq registered (default)
[ 0.711624] aer 0000:00:01.1:pcie002: service driver aer loaded
[ 0.711645] aer 0000:00:01.3:pcie002: service driver aer loaded
[ 0.711659] aer 0000:00:07.1:pcie002: service driver aer loaded
[ 0.711674] aer 0000:00:08.1:pcie002: service driver aer loaded
[ 0.711683] pcieport 0000:00:01.1: Signaling PME through PCIe PME interrupt
[ 0.711683] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 0.711685] pcie_pme 0000:00:01.1:pcie001: service driver pcie_pme loaded
[ 0.711690] pcieport 0000:00:01.3: Signaling PME through PCIe PME interrupt
[ 0.711690] pci 0000:02:00.0: Signaling PME through PCIe PME interrupt
[ 0.711691] pci 0000:02:00.1: Signaling PME through PCIe PME interrupt
[ 0.711692] pcieport 0000:02:00.2: Signaling PME through PCIe PME interrupt
[ 0.711692] pcieport 0000:03:00.0: Signaling PME through PCIe PME interrupt
[ 0.711693] pci 0000:04:00.0: Signaling PME through PCIe PME interrupt
[ 0.711694] pcieport 0000:03:01.0: Signaling PME through PCIe PME interrupt
[ 0.711694] pci 0000:05:00.0: Signaling PME through PCIe PME interrupt
[ 0.711695] pcieport 0000:03:04.0: Signaling PME through PCIe PME interrupt
[ 0.711695] pci 0000:07:00.0: Signaling PME through PCIe PME interrupt
[ 0.711696] pci 0000:07:00.1: Signaling PME through PCIe PME interrupt
[ 0.711698] pcie_pme 0000:00:01.3:pcie001: service driver pcie_pme loaded
[ 0.711702] pcieport 0000:00:07.1: Signaling PME through PCIe PME interrupt
[ 0.711703] pci 0000:08:00.0: Signaling PME through PCIe PME interrupt
[ 0.711703] pci 0000:08:00.2: Signaling PME through PCIe PME interrupt
[ 0.711704] pci 0000:08:00.3: Signaling PME through PCIe PME interrupt
[ 0.711705] pcie_pme 0000:00:07.1:pcie001: service driver pcie_pme loaded
[ 0.711711] pcieport 0000:00:08.1: Signaling PME through PCIe PME interrupt
[ 0.711711] pci 0000:09:00.0: Signaling PME through PCIe PME interrupt
[ 0.711712] pci 0000:09:00.2: Signaling PME through PCIe PME interrupt
[ 0.711712] pci 0000:09:00.3: Signaling PME through PCIe PME interrupt
[ 0.711714] pcie_pme 0000:00:08.1:pcie001: service driver pcie_pme loaded
[ 0.711720] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.711724] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.711732] efifb: probing for efifb
[ 0.711741] efifb: framebuffer at 0xf1000000, using 3072k, total 3072k
[ 0.711742] efifb: mode is 1024x768x32, linelength=4096, pages=1
[ 0.711742] efifb: scrolling: redraw
[ 0.711743] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ 0.713931] Console: switching to colour frame buffer device 128x48
[ 0.716023] fb0: EFI VGA frame buffer device
[ 0.716635] GHES: HEST is not enabled!
[ 0.716682] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.737575] 00:05: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
[ 0.737853] Linux agpgart interface v0.103
[ 0.737900] AMD IOMMUv2 driver by Joerg Roedel <
jroedel@suse.de>
[ 0.738391] i8042: PNP: No PS/2 controller found. Probing ports directly.
[ 0.738855] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 0.738857] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 0.738958] mousedev: PS/2 mouse device common for all mice
[ 0.738998] rtc_cmos 00:02: RTC can wake from S4
[ 0.739191] rtc_cmos 00:02: rtc core: registered rtc_cmos as rtc0
[ 0.739242] rtc_cmos 00:02: alarms up to one month, y3k, 114 bytes nvram, hpet irqs
[ 0.739343] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.739717] NET: Registered protocol family 10
[ 0.739928] mip6: Mobile IPv6
[ 0.739929] NET: Registered protocol family 17
[ 0.739931] mpls_gso: MPLS GSO support
[ 0.740975] microcode: CPU0: patch_level=0x08001129
[ 0.740980] microcode: CPU1: patch_level=0x08001129
[ 0.740986] microcode: CPU2: patch_level=0x08001129
[ 0.740991] microcode: CPU3: patch_level=0x08001129
[ 0.740994] microcode: CPU4: patch_level=0x08001129
[ 0.740998] microcode: CPU5: patch_level=0x08001129
[ 0.741035] microcode: Microcode Update Driver: v2.01 <
tigran@aivazian.fsnet.co.uk>, Peter Oruba
[ 0.741147] registered taskstats version 1
[ 0.741157] zswap: loaded using pool lzo/zbud
[ 0.741245] ima: No TPM chip found, activating TPM-bypass!
[ 0.741973] rtc_cmos 00:02: setting system clock to 2018-03-04 08:47:00 UTC (1520153220)
[ 0.742020] PM: Hibernation image not present or could not be loaded.
[ 0.743009] Freeing unused kernel memory: 1408K
[ 0.743010] Write protecting the kernel read-only data: 12288k
[ 0.743419] Freeing unused kernel memory: 1980K
[ 0.745496] Freeing unused kernel memory: 1248K
[ 0.749422] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 0.754219] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[ 0.754259] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[ 0.754265] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[ 0.754753] random: udevadm: uninitialized urandom read (16 bytes read)
[ 0.754771] random: udevadm: uninitialized urandom read (16 bytes read)
[ 0.755893] random: udevadm: uninitialized urandom read (16 bytes read)
[ 0.755932] random: udevadm: uninitialized urandom read (16 bytes read)
[ 0.756174] random: udevadm: uninitialized urandom read (16 bytes read)
[ 0.756203] random: udevadm: uninitialized urandom read (16 bytes read)
[ 0.756237] random: udevadm: uninitialized urandom read (16 bytes read)
[ 0.779603] nvme nvme0: pci function 0000:01:00.0
[ 0.780213] SCSI subsystem initialized
[ 0.780517] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded
[ 0.780566] ACPI: bus type USB registered
[ 0.780580] usbcore: registered new interface driver usbfs
[ 0.780586] usbcore: registered new interface driver hub
[ 0.780602] usbcore: registered new device driver usb
[ 0.781140] libata version 3.00 loaded.
[ 0.781522] QUIRK: Enable AMD PLL fix
[ 0.781530] xhci_hcd 0000:02:00.0: xHCI Host Controller
[ 0.781535] xhci_hcd 0000:02:00.0: new USB bus registered, assigned bus number 1
[ 0.781744] piix4_smbus 0000:00:14.0: SMBus Host Controller at 0xb00, revision 0
[ 0.781745] piix4_smbus 0000:00:14.0: Using register 0x02 for SMBus port selection
[ 0.785752] AVX2 version of gcm_enc/dec engaged.
[ 0.785752] AES CTR mode by8 optimization enabled
[ 0.791574] r8169 0000:04:00.0 eth0: RTL8168g/8111g at 0xffffbc3d80cad000, 1c:1b:0d:e1
f7, XID 0c000800 IRQ 39
[ 0.791576] r8169 0000:04:00.0 eth0: jumbo features [frames: 9200 bytes, tx checksumming: ko]
[ 0.836915] xhci_hcd 0000:02:00.0: hcc params 0x0200ef81 hci version 0x110 quirks 0x00000418
[ 0.836997] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.836998] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.836999] usb usb1: Product: xHCI Host Controller
[ 0.837000] usb usb1: Manufacturer: Linux 4.9.0-5-amd64 xhci-hcd
[ 0.837001] usb usb1: SerialNumber: 0000:02:00.0
[ 0.837218] hub 1-0:1.0: USB hub found
[ 0.837229] hub 1-0:1.0: 10 ports detected
[ 0.837432] xhci_hcd 0000:02:00.0: xHCI Host Controller
[ 0.837434] xhci_hcd 0000:02:00.0: new USB bus registered, assigned bus number 2
[ 0.837436] xhci_hcd 0000:02:00.0: Host supports USB 3.1 Enhanced SuperSpeed
[ 0.837461] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 0.837474] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 0.837475] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.837476] usb usb2: Product: xHCI Host Controller
[ 0.837477] usb usb2: Manufacturer: Linux 4.9.0-5-amd64 xhci-hcd
[ 0.837478] usb usb2: SerialNumber: 0000:02:00.0
[ 0.837555] hub 2-0:1.0: USB hub found
[ 0.837560] hub 2-0:1.0: 4 ports detected
[ 0.837621] usb: port power management may be unreliable
[ 0.837676] ahci 0000:02:00.1: version 3.0
[ 0.837772] xhci_hcd 0000:08:00.3: xHCI Host Controller
[ 0.837774] xhci_hcd 0000:08:00.3: new USB bus registered, assigned bus number 3
[ 0.837828] ahci 0000:02:00.1: SSS flag set, parallel bus scan disabled
[ 0.837860] ahci 0000:02:00.1: AHCI 0001.0301 32 slots 8 ports 6 Gbps 0x33 impl SATA mode
[ 0.837862] ahci 0000:02:00.1: flags: 64bit ncq sntf stag pm led clo only pmp pio slum part sxs deso sadm sds apst
[ 0.837877] xhci_hcd 0000:08:00.3: hcc params 0x0270f665 hci version 0x100 quirks 0x00000418
[ 0.837939] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.837940] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.837941] usb usb3: Product: xHCI Host Controller
[ 0.837941] usb usb3: Manufacturer: Linux 4.9.0-5-amd64 xhci-hcd
[ 0.837942] usb usb3: SerialNumber: 0000:08:00.3
[ 0.838028] hub 3-0:1.0: USB hub found
[ 0.838033] hub 3-0:1.0: 4 ports detected
[ 0.838166] xhci_hcd 0000:08:00.3: xHCI Host Controller
[ 0.838167] xhci_hcd 0000:08:00.3: new USB bus registered, assigned bus number 4
[ 0.838177] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[ 0.838188] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[ 0.838189] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.838190] usb usb4: Product: xHCI Host Controller
[ 0.838190] usb usb4: Manufacturer: Linux 4.9.0-5-amd64 xhci-hcd
[ 0.838191] usb usb4: SerialNumber: 0000:08:00.3
[ 0.838277] hub 4-0:1.0: USB hub found
[ 0.838282] hub 4-0:1.0: 4 ports detected
[ 0.838507] scsi host0: ahci
[ 0.838591] scsi host1: ahci
[ 0.838682] scsi host2: ahci
[ 0.838760] scsi host3: ahci
[ 0.838832] scsi host4: ahci
[ 0.838907] scsi host5: ahci
[ 0.839003] scsi host6: ahci
[ 0.839070] scsi host7: ahci
[ 0.839106] ata1: SATA max UDMA/133 abar m131072@0xf7380000 port 0xf7380100 irq 42
[ 0.839107] ata2: SATA max UDMA/133 abar m131072@0xf7380000 port 0xf7380180 irq 42
[ 0.839108] ata3: DUMMY
[ 0.839108] ata4: DUMMY
[ 0.839109] ata5: SATA max UDMA/133 abar m131072@0xf7380000 port 0xf7380300 irq 42
[ 0.839111] ata6: SATA max UDMA/133 abar m131072@0xf7380000 port 0xf7380380 irq 42
[ 0.839111] ata7: DUMMY
[ 0.839111] ata8: DUMMY
[ 0.839291] ahci 0000:09:00.2: AHCI 0001.0301 32 slots 2 ports 6 Gbps 0x3 impl SATA mode
[ 0.839292] ahci 0000:09:00.2: flags: 64bit ncq sntf ilck pm led clo only pmp fbs pio slum part sxs
[ 0.839293] ahci 0000:09:00.2: both AHCI_HFLAG_MULTI_MSI flag set and custom irq handler implemented
[ 0.839511] scsi host8: ahci
[ 0.839590] scsi host9: ahci
[ 0.839620] ata9: SATA max UDMA/133 abar m4096@0xf7808000 port 0xf7808100 irq 45
[ 0.839621] ata10: SATA max UDMA/133 abar m4096@0xf7808000 port 0xf7808180 irq 46
[ 0.998434] nvme0n1: p1 p2 p3
[ 1.151275] ata9: SATA link down (SStatus 0 SControl 300)
[ 1.151297] ata10: SATA link down (SStatus 0 SControl 300)
[ 1.223002] usb 1-6: new full-speed USB device number 2 using xhci_hcd
[ 1.311024] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 1.348377] ata1.00: ATA-10: ST2000LX001-1RG174, SDM1, max UDMA/133
[ 1.348378] ata1.00: 3907029168 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
[ 1.407047] ata1.00: configured for UDMA/133
[ 1.407424] scsi 0:0:0:0: Direct-Access ATA ST2000LX001-1RG1 SDM1 PQ: 0 ANSI: 5
[ 1.620512] usb 1-6: New USB device found, idVendor=046d, idProduct=c52b
[ 1.620514] usb 1-6: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.620515] usb 1-6: Product: USB Receiver
[ 1.620515] usb 1-6: Manufacturer: Logitech
[ 1.631332] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.682292] usbcore: registered new interface driver usbhid
[ 1.682293] usbhid: USB HID core driver
[ 1.694471] logitech-djreceiver 0003:046D:C52B.0003: hiddev0,hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:02:00.0-6/input2
[ 1.726713] tsc: Refined TSC clocksource calibration: 3194.000 MHz
[ 1.726717] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x2e0a25d85ab, max_idle_ns: 440795234405 ns
[ 1.758358] ata2: SATA link down (SStatus 0 SControl 300)
[ 1.823332] input: Logitech K400 as /devices/pci0000:00/0000:00:01.3/0000:02:00.0/usb1/1-6/1-6:1.2/0003:046D:C52B.0003/0003:046D:4024.0004/input/input3
[ 1.823476] logitech-hidpp-device 0003:046D:4024.0004: input,hidraw1: USB HID v1.11 Keyboard [Logitech K400] on usb-0000:02:00.0-6:1
[ 2.072125] ata5: SATA link down (SStatus 0 SControl 300)
[ 2.543041] ata6: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 2.543663] ata6.00: ATA-9: WDC WD10JFCX-68N6GN0, 82.00A82, max UDMA/133
[ 2.543664] ata6.00: 1953525168 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
[ 2.544289] ata6.00: configured for UDMA/133
[ 2.544655] scsi 5:0:0:0: Direct-Access ATA WDC WD10JFCX-68N 0A82 PQ: 0 ANSI: 5
[ 2.577156] sd 0:0:0:0: [sda] 3907029168 512-byte logical blocks: (2.00 TB/1.82 TiB)
[ 2.577157] sd 0:0:0:0: [sda] 4096-byte physical blocks
[ 2.577176] sd 5:0:0:0: [sdb] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[ 2.577177] sd 5:0:0:0: [sdb] 4096-byte physical blocks
[ 2.577184] sd 0:0:0:0: [sda] Write Protect is off
[ 2.577185] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 2.577197] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 2.577204] sd 5:0:0:0: [sdb] Write Protect is off
[ 2.577206] sd 5:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[ 2.577217] sd 5:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 2.578760] sda: sda1
[ 2.579005] sd 0:0:0:0: [sda] Attached SCSI disk
[ 2.582320] sd 5:0:0:0: [sdb] Attached SCSI disk
[ 2.653015] random: fast init done
[ 2.750419] PM: Starting manual resume from disk
[ 2.750421] PM: Hibernation image partition 259:3 present
[ 2.750421] PM: Looking for hibernation image.
[ 2.750509] PM: Image not found (code -22)
[ 2.750509] PM: Hibernation image not present or could not be loaded.
[ 2.750780] clocksource: Switched to clocksource tsc
[ 2.815136] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null)
[ 2.850783] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 2.879230] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
[ 2.879350] systemd[1]: Detected architecture x86-64.
[ 2.879446] systemd[1]: Set hostname to <DietPi>.
[ 2.907241] systemd[1]: apt-daily-upgrade.timer: Cannot add dependency job, ignoring: Unit apt-daily-upgrade.timer is masked.
[ 2.907244] systemd[1]: apt-daily.timer: Cannot add dependency job, ignoring: Unit apt-daily.timer is masked.
[ 2.907587] systemd[1]: Listening on Syslog Socket.
[ 2.907680] systemd[1]: Created slice User and Session Slice.
[ 2.907727] systemd[1]: Created slice System Slice.
[ 2.907998] systemd[1]: Mounting POSIX Message Queue File System...
[ 2.908080] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 2.932364] nvidia: loading out-of-tree module taints kernel.
[ 2.932369] nvidia: module license 'NVIDIA' taints kernel.
[ 2.932369] Disabling lock debugging due to kernel taint
[ 2.939744] vgaarb: device changed decodes: PCI:0000:07:00.0,olddecodes=io+mem,decodes=none:owns=io+mem
[ 2.939812] nvidia-nvlink: Nvlink Core is being initialized, major device number 247
[ 2.939822] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 375.82 Wed Jul 19 21:16:49 PDT 2017 (using threaded interrupts)
[ 2.941618] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 375.82 Wed Jul 19 20:35:11 PDT 2017
[ 2.950801] [drm] Initialized
[ 2.952329] acpi_cpufreq: overriding BIOS provided _PSD data
[ 2.955519] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input4
[ 2.955522] ACPI: Power Button [PWRB]
[ 2.955566] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input5
[ 2.955567] ACPI: Power Button [PWRF]
[ 2.961177] parport_pc 00:04: reported by Plug and Play ACPI
[ 2.961225] parport0: PC-style at 0x378, irq 5 [PCSPP,TRISTATE,EPP]
[ 2.962159] [drm] [nvidia-drm] [GPU ID 0x00000700] Loading driver
[ 2.965975] wmi: Mapper loaded
[ 2.968819] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 2.970885] sp5100_tco: SP5100/SB800 TCO WatchDog Timer Driver v0.05
[ 2.970926] sp5100_tco: PCI Vendor ID: 0x1022, Device ID: 0x790b, Revision ID: 0x59
[ 2.970930] sp5100_tco: I/O address 0x0cd6 already in use
[ 2.971366] ccp 0000:08:00.2: enabling device (0000 -> 0002)
[ 2.971435] ccp 0000:08:00.2: 3 command queues available
[ 2.971497] ccp 0000:08:00.2: Queue 2 can access 4 LSB regions
[ 2.971499] ccp 0000:08:00.2: Queue 3 can access 4 LSB regions
[ 2.971500] ccp 0000:08:00.2: Queue 4 can access 4 LSB regions
[ 2.971501] ccp 0000:08:00.2: Queue 0 gets LSB 4
[ 2.971501] ccp 0000:08:00.2: Queue 1 gets LSB 5
[ 2.971502] ccp 0000:08:00.2: Queue 2 gets LSB 6
[ 2.974149] ccp 0000:08:00.2: enabled
[ 2.975100] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 2.975125] sd 5:0:0:0: Attached scsi generic sg1 type 0
[ 2.982695] Adding 8337404k swap on /dev/nvme0n1p3. Priority:-1 extents:1 across:8337404k SSFS
[ 2.989738] systemd-journald[261]: Received request to flush runtime journal from PID 1
[ 3.003712] EFI Variables Facility v0.08 2004-May-17
[ 3.006933] input: PC Speaker as /devices/platform/pcspkr/input/input6
[ 3.008788] snd_hda_intel 0000:07:00.1: Disabling MSI
[ 3.008792] snd_hda_intel 0000:07:00.1: Handle vga_switcheroo audio client
[ 3.008808] snd_hda_intel 0000:09:00.3: enabling device (0000 -> 0002)
[ 3.014756] ppdev: user-space parallel port driver
[ 3.022639] kvm: disabled by bios
[ 3.025592] pstore: using zlib compression
[ 3.025601] pstore: Registered efi as persistent store backend
[ 3.027541] r8169 0000:04:00.0: firmware: direct-loading firmware rtl_nic/rtl8168g-2.fw
[ 3.028623] snd_hda_codec_realtek hdaudioC1D0: autoconfig for ALC887-VD: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:line
[ 3.028625] snd_hda_codec_realtek hdaudioC1D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 3.028626] snd_hda_codec_realtek hdaudioC1D0: hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[ 3.028627] snd_hda_codec_realtek hdaudioC1D0: mono: mono_out=0x0
[ 3.028627] snd_hda_codec_realtek hdaudioC1D0: dig-out=0x11/0x0
[ 3.028628] snd_hda_codec_realtek hdaudioC1D0: inputs:
[ 3.028629] snd_hda_codec_realtek hdaudioC1D0: Front Mic=0x19
[ 3.028630] snd_hda_codec_realtek hdaudioC1D0: Rear Mic=0x18
[ 3.028630] snd_hda_codec_realtek hdaudioC1D0: Line=0x1a
[ 3.043409] input: HD-Audio Generic Front Mic as /devices/pci0000:00/0000:00:08.1/0000:09:00.3/sound/card1/input7
[ 3.043446] input: HD-Audio Generic Rear Mic as /devices/pci0000:00/0000:00:08.1/0000:09:00.3/sound/card1/input8
[ 3.043478] input: HD-Audio Generic Line as /devices/pci0000:00/0000:00:08.1/0000:09:00.3/sound/card1/input9
[ 3.043510] input: HD-Audio Generic Line Out as /devices/pci0000:00/0000:00:08.1/0000:09:00.3/sound/card1/input10
[ 3.043542] input: HD-Audio Generic Front Headphone as /devices/pci0000:00/0000:00:08.1/0000:09:00.3/sound/card1/input11
[ 3.073333] r8169 0000:04:00.0 eth0: link down
[ 3.073396] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 3.073489] r8169 0000:04:00.0 eth0: link down
[ 3.075130] random: crng init done
[ 3.648039] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.3/0000:02:00.2/0000:03:04.0/0000:07:00.1/sound/card0/input12
[ 3.648152] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.3/0000:02:00.2/0000:03:04.0/0000:07:00.1/sound/card0/input13
[ 5.648273] r8169 0000:04:00.0 eth0: link up
[ 5.648287] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
