Nextcloud, how to change data directory?
przemko
Re: Nextcloud, how to change data directory?
Post by przemko »
That is:
drwxr-xr-x  8 root     root     4096 mar 21 08:11 .
drwxr-xr-x 21 root     root     4096 mar 22 09:33 ..
lrwxrwxrwx  1 root     root       28 mar 20 21:45 dietpi_userdata -> /mnt/Toshiba/dietpi_userdata
drwxr-xr-x  2 root     root     4096 sty  7 23:35 ftp_client
drwxr-xr-x  2 root     root        0 lut 14  2019 Maly
drwxrwxrwx  1 root     root     8192 mar 20 19:38 My_Passport
drwxr-xr-x  2 root     root     4096 sty  7 23:35 nfs_client
drwxr-xr-x  2 root     root     4096 sty  7 23:35 samba
drwxr-xr-x  4 www-data www-data 4096 mar 20 21:45 Toshiba
That is all correct. When changing the userdata location, a symlink is left behind, so the old path stays valid while the actual data is on the new drive.
przemko
Post by przemko »
But I see that path i nextcloud web app and all my data sync with that location. So I have to delete my data from
/mnt/dietpi_userdata/nextcloud_data/admin
Yes thats all correct. As you can see there is a symlinc from old to new location
przemko
Post by przemko »
OK, thanks. Now I install fail2ban on my Rpi4 and cannot open Nextcloud, Emby and ssh :/ Can You help with that? I will create another topic for that.
Hmm, fail2ban should not be related to web access, especially not Nextcloud. By default it controls SSH access failures only and block access (completely) for a specific client when SSH access failed for, AFAIK 6 times, although might be 3 attempts only since each produces two log entries, AFAIK. Should be released after 600 seconds/10 minutes by default.
Were you able to access via SSH and web before installing fail2ban?
