Chester007
Posts: 35 Joined: Sat Mar 04, 2017 3:57 pm
Post
by Chester007 » Sat May 06, 2017 2:52 pm
Fourdee wrote: I think your lighttpd.conf has been overwritten during the PiHole update.
Assuming you are using the default Lighttpd webserver on DietPi:
Did you backup your
lighttpd.conf before upgrading pihole, as per
Updating PiHole: :
http://dietpi.com/phpbb/viewtopic.php?f ... rt=20#p174
If not, reinstall lighttpd to regenerate the config should fix this:
apt-get purge lighttpd -y
dietpi-software reinstall 84
Restoring the lighttpd.conf from a previous backup did the trick! Thank you!
Just wondering, I can still access the admin UI via the /admin address. Is that normal?
k-plan
Posts: 416 Joined: Sun Feb 28, 2016 5:28 pm
Post
by k-plan » Sat May 06, 2017 5:41 pm
Chester007 wrote: Just wondering, I can still access the admin UI via the /admin address. Is that normal?
Yes.
root@NanoPi-Neo:~# ls -lah /var/www/
insgesamt 88K
drwxrwxr-x 3 www-data www-data 4,0K Mai 6 16:07 .
drwxr-xr-x 13 root root 4,0K Mai 6 15:57 ..
lrwxrwxrwx 1 www-data www-data 19 Mai 6 16:07 admin -> /var/www/html/admin
-rwxrwxr-x 1 www-data www-data 38K Mär 19 11:06 apc.php
drwxrwxr-x 4 www-data www-data 4,0K Mai 6 16:06 html
-rwxrwxr-x 1 www-data www-data 68 Mai 6 16:07 index.html
-rwxrwxr-x 1 www-data www-data 3,3K Mär 4 18:55 index.lighttpd.html
-rwxrwxr-x 1 www-data www-data 23K Mär 19 11:06 opcache.php
-rwxrwxr-x 1 www-data www-data 20 Mär 19 11:06 phpinfo.php
lrwxrwxrwx 1 www-data www-data 19 Mai 6 16:07 pihole -> /var/www/html/admin
If you don't like this, remove the symbolic link:
Donating is the easiest – you can use PayPal and Bitcoin .
Chester007
Post
by Chester007 » Sat May 06, 2017 6:07 pm
k-plan wrote: Chester007 wrote: Just wondering, I can still access the admin UI via the /admin address. Is that normal?
Yes.
insgesamt 88K
Ah I see, haven't really noticed it before. Thanks anyway!
