I think you haft to edit this line for the storage place.
And one more thing is if the disk is spinning all the time will get warm.It is faster to respond but...!!!
I had setup it in this style and i didnt like cose is not safe also for the data.
Keep us informed whith your setup cose I'm also interesting.
I've tested my configuration out a bit now and this is what i've done so far.
I've changed the spindown back on, since the longer duration (lifetime) of the hard drive is much more appreciated than speed.
i.e made no changes to etc/hdparm.conf everything is now working as expected. I just reinstalled Nextcloud and chose force USB under drive manager. Hope that might help others encountering similar issues in the future!
juliuscaesar wrote:Thank you, i will look into that!
It also seems that my USB Harddrive is not reachable from time to time, i think it has to do with some setting like hdd spindown. Is it possible to change that setting somewhere so that the usb harddrive is always active and running?
Hi. Im planning to store my data on an external 2.5" HDD connecting it to my OPi with this cable (or similar) and a dedicated power supply for it. Would it be necessary to edit the hdparam.conf to avoid spindwon?
jngutierrez wrote:Would it be necessary to edit the hdparam.conf to avoid spindwon?
Unknown on this adapter, but if in doubt, disabling the spin down feature would be beneficial to avoid a possible issue.
