Login with SSH-Keys Topic is solved
Klola
Re: Login with SSH-Keys
Post by Klola »
In fact, I can still log in with user dietpi and the password, not with root.
Also here is DROPBEAR_EXTRA_ARGS=-gentered.
Should I log in first with dietpi and there
DROPBEAR_EXTRA_ARGS=-g?
Doesn't it make sense to disable the password for both logins if I only log in with an ssh key? Thanks
Just have a look to the man page I linked above. There you have all possible options. Just use -s options instead of -g if you like to disable password login for all user.
trendy
Post by trendy »
Klola wrote: Thu Sep 16, 2021 10:05 am Doesn't it make sense to disable the password for both logins if I only log in with an ssh key? Thanks
It makes sense, but first you need to make sure you can login with ssh keys before disabling password login globally to avoid getting locked out.
Klola
Post by Klola »
@trendy @Joulinar
Done. Both passwords disabled, SSH-Key is working :)
Thanks! learnt alot again! :)
