Upgrade from Buster to Bullseye Topic is solved
Niwre
Re: Upgrade from Buster to Bullseye
Post by Niwre »
@Joulinar
The following packages are said to be missing when I run apt update, but apt upgrade doesn't update any of them. :?
firefox-esr/stable-security 78.13.0esr-1~deb11u1 amd64 [aktualisierbar von: 78.13.0esr-1~deb10u1]
perl-base/stable-security 5.32.1-4+deb11u1 amd64 [aktualisierbar von: 5.28.1-6+deb10u1]
perl/stable-security 5.32.1-4+deb11u1 amd64 [aktualisierbar von: 5.28.1-6+deb10u1]
I though you have installed PiHole + WireGuard only. Where does FireFox is coming from?
Niwre
Post by Niwre »
@Joulinar
I don't remember installing Firefox, nor do I need Firefox.
can you have a look if it is installed via dietpi-software?
Niwre
Post by Niwre »
@Joulinar
apparently i installed firefox once because it shows up. However, the first installation was a long time ago and I actually only use WireGuard and piHole.
Sorry :?
Niwre
Post by Niwre »
I looked directly under the available software, there is no x for Firefox.
ok it is not installed via dietpi-software. Let's remove it if not required.
G_AGP firefox-esr
Let's check the system afterwards
apt update && apt upgrade -y
Niwre
Post by Niwre »
@Joulinar
then unfortunately there are still two packages left that will not be updated.
can you share full output of
apt update
apt upgrade
apt full-upgrade
apt autopurge
Niwre
Post by Niwre »
@Joulinar
I had just logged out of the console and then logged back in again, now it seems to work, I see loads of updates. I'll let that go through and then I'll get back to you. Thank you for your support.
