Connect without SSH? Topic is solved
Re: Connect without SSH?
Usually it should work ootb. You are not login at that moment, therefore first you need to login as root.
gasto
Post by gasto »
I will try and let you guys know as soon as I get the USB keyboard. Thank you again.
gasto
Post by gasto »
It worked! Thanks ;)
ok perfect :)
WarHawk
Post by WarHawk »
Awesome job Joulinar!!!!!
