How to install pillow for python3 Topic is solved
Re: How to install pillow for python3
@dietpiOK
Try to update/install the mentioned modules first: pip3 install setuptools tokenize
dietpiOK
Post by dietpiOK »
pip3 install setuptools worked perfectly, but:
root@raspi:~# pip3 install tokenize
Collecting tokenize
Could not find a version that satisfies the requirement tokenize (from versions: )
No matching distribution found for tokenize
What does that mean?
@dietpiOK
Ah the modules is named "tokenizer": pip3 install tokenizer
You might also need to install apt install python3-dev which is somehow missing when dietpi-software installs python3-pip.
dietpiOK
Post by dietpiOK »
Thanks, MichIng, I just did not see that typo.
Unfortunately installing pillow still does not work:
Command "/usr/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-build-_8lazntv/pillow/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-yqukurd1-record/install-record.txt --single-version-externally-managed --compile" failed with error code 1 in /tmp/pip-build-_8lazntv/pillow/
root@raspi:~# pip3 install tokenizer
Requirement already satisfied: tokenizer in /usr/local/lib/python3.5/dist-packages
@dietpiOK
You installed apt install python3-dev?
dietpiOK
Post by dietpiOK »
Yes, it is installed.
@dietpiOK
Can you please paste the full output of pip3 install pillow? Perhaps some previous lines give a hint what is missing, e.g. some other dev or library package.
E.g.: https://stackoverflow.com/questions/391 ... python-3-6
- zlib required as long as you do not exclude it via command option.
- The last error exactly matches yours (besides Windows style file paths) but the lines before clearly state that zlib is expected.
Also see: https://stackoverflow.com/questions/346 ... e-in-linux
Besides checking for and in case install missing libs/-dev packages, the suggestion is to update pip via pip :):
pip3 install -U pip
hash -r # Required to reload the $PATH variable with the new pip3 binary
dietpiOK
Post by dietpiOK »
Issue is solved!
Thanks Dan, for your support.
I had tp update pip3... Now everything works and pillow is running.
Great that it worked. Made me play around a bid with pip/pip3 and it works quite handy in combination with APT packages. If you install modules via pip, the ones from the APT packages are even removed, so only the new version will stay in place, thus no data overhead :+1:. However of course bad if some own python project requires a specific version, however easy to achieve with pip as well, much more flexible than APT.
