Raspberry PoE-HAT Fan Speed
Re: Raspberry PoE-HAT Fan Speed
does it has issues on all different OS ?
bequflo
Post by bequflo »
Hi, with the others OS was work the wifi but not do the ethernet, the eth0 always be down.
I have given up using it, now i use external power supply
maybe something wrong with the PoE-HAT. An alternativ would be using a POE Splitter
Amazon Link
bequflo
Post by bequflo »
Hi again.
I'm working with Raspberry 3 and POE HAT a couple off years they work very good. Now with the Raspberry 4 this is not possible.
I have several Raspberry and several POE HAT all of this doing the same.
But now i was installed "chromiumos_test_image_r77r2-rpi4b" into the Raspberry PI 4 with de POE HAT installed and all work right
but if I understood right, this is not working on standard Raspberry OS as well. Correct?
bequflo
Post by bequflo »
That's correctly the POE HAT was works right with Chrome OS but not with Raspbian OS
OK than it's an issue of Raspberry OS. As DietPi is using Raspberry OS as base image (for RPi boards), your PoE-HAT is not working on DietPi as well.
Matt
Post by Matt »
The_Raven wrote: Fri Mar 08, 2019 1:22 pm Hi all
I have a Raspberry Pi 3B+ with a PoE-HAT.
The HAT has a fan on it.
On raspian it's possible now to control the speed with a config-parameter in the config.txt:
dtparam=poe_fan_temp0=55000,poe_fan_temp1=60000
This turns on the fan @ 55C°.
I have tried this on dietpi, but i think it does not work.
Should this work or not?
Thx an greetings
Hi All,
I have a Raspebbry Pi 3B+ and I have attached a fan to it. The fan is just a fan, with two wires coming out of it. It is NOT a PoE-HAT with a fan. The fan is on the whole time running at full speed.
Is it possible to control the fan?
Thanks
Nope, if the fan is just connected to the board, it will spin whole time until you removed power. To have it controlled, you need additional stuff. There are a couple of guides on the web. Just search for "raspberry fan control"
The_Raven
Post by The_Raven »
Quick and dirt fix:
You can add a resistor to lower the speed (and the noise).
