Fourdee
v6.3
Post by Fourdee »
Deprecation warning: This post is deprecated. Please find our new documentation at: https://dietpi.com/docs/software/media/#airsonic
Airsonic
Feature rich media streaming server with a web interface. Coded in Java.
Access the web interface: First run setup:
Once connected to the web interface, we need to configure the Music directory:
  • Click the Settings button
  • Under Media Folders, replace the current music folder entry with /mnt/dietpi_userdata/Music, then select Save
  • Select Scan media folders now to update the library
Transfer music to your device:
Make sure you have one of DietPi's File Servers installed.
folder = /mnt/dietpi_userdata/Music
Fourdee
v6.9
Post by Fourdee »
Deprecation warning: This post is deprecated. Please find our new documentation at: https://dietpi.com/docs/software/webser ... /#influxdb
InfluxDB
influxDB is a database optimized to save time based data as logs or data from a sensor.
The main interface to the database for management and data transfert is http requests that are handled directly by influxdb service (default port being 8086).
The data can be nicely viewed with Grafana.
This installation and documentation was possible, thanks to @marcobrianza
Usage:
The package comes with a command line tool influx for database management operations
This tool also uses http so it can manage a database on a remote machine setting the -host option.
Official documentation can be found at https://docs.influxdata.com/influxdb/
  • Create a database
    influx -execute 'create database mydb'
    • Another method
      curl -i -XPOST http://localhost:8086/query --data-urlencode "q=CREATE DATABASE mydb"
  • Posting data
    curl -i -XPOST 'http://localhost:8086/write?db=mydb' --data-binary 'temperature value=20.12'
  • Show data
    influx -database mydb -execute 'SELECT * FROM temperature'
    • Another method
      curl -i -XPOST http://localhost:8086/query?db=mydb --data-urlencode "q=SELECT * FROM temperature"
  • By default http authentication is disabled, to enable, change auth-enabled = true in the configuration file /etc/influxdb/influxdb.conf, then restart services with dietpi-services restart
  • Create users and authorizations from influx CLI
    influx -username admin -password admin01
    CREATE USER admin WITH PASSWORD 'admin01' WITH ALL PRIVILEGES
    CREATE USER test_user WITH PASSWORD 'test_user01'
    GRANT ALL ON mydb TO test_user
    exit
Install information:
The data location for InfluxDB is stored/symlinked to the DietPi userdata directory: /mnt/dietpi_userdata/influxdb
Fourdee
v6.9
Post by Fourdee »
Deprecation warning: This post is deprecated. Please find our new documentation at: https://dietpi.com/docs/software/hardwa ... s/#grafana
Grafana
The open platform for beautiful analytics and monitoring.
NB: Grafana binaries are specific to the CPU architecture, therefore, swapping SD cards between RPi 1 <> 2+, is not recommended
Pre-req:
A database server is required for Grafana. As Grafana offers many options (InfluxDB/MySQL), we have not automatically installed either as manual configuration may be preferred.
However, we highly recommend installing InfluxDB:
  • dietpi-software install 74
Then follow the database creation guide here: viewtopic.php?p=12523#p12523
Access web interface: Usage Information:
If you have created a database as per the InfluxDB online doc, please follow these instructions:
  • From the Home Dashboard click Add data source, then enter the following information:
    • Type = InfluxDB
    • URL = http://localhost:8086
    • Database = mydb
    • User = test_user
    • Password = test_password01
    • Leave the remaining items with the default values.
  • Click Save & Test
  • From the Home Dashboard click New dashboard
    • click Graph
    • Click the example graph
    • Press e to edit the Data Source and the custom query
The data location for Grafana is stored/symlinked to the DietPi userdata directory: /mnt/dietpi_userdata/grafana
Fourdee
v6.10
Post by Fourdee »
Deprecation warning: This post is deprecated. Please find our new documentation at: https://dietpi.com/docs/software/media/#ubooquity
Ubooquity
Ubooquity is a free home server for your comics and ebooks library, with remote web interface viewing.
Access Web Interface: Transfer ebooks/comics to your device:
  • Use the following folders = /mnt/dietpi_userdata/ebooks and /mnt/dietpi_userdata/comics
  • Then use the admin page, to set the above locations for ebook and comic storage
  • Run a scan in the admin page to update the database
Update to the latest version:
dietpi-software reinstall 80
Fourdee
v6.10
Post by Fourdee »
Deprecation warning: This post is deprecated. Please find our new documentation at: https://dietpi.com/docs/software/media/ ... on-manager
Roon Extension Manager
At startup the Roon Extension Manager accesses a repository containing the community developed extensions. Via Settings->Extensions within Roon the repository can be viewed and an extension can be selected to perform a certain action.
Many thanks to @JanKoudijs for contributing this into DietPi
Details and usage information:
https://community.roonlabs.com/t/roon-e ... -7-0/26632
Fourdee
v6.13
Post by Fourdee »
Deprecation warning: This post is deprecated. Please find our new documentation at: https://dietpi.com/docs/software/bittorrent/#lidarr
Lidarr
Automatically download your favorite music.
NB: A download client is required:
- Transmission BitTorrent server is recommended to enable automatic downloads.
Access web interface: First Run Setup:
Before you can add music, you'll need to select a search indexer to use from the web interface:
  • Simply goto Settings > Indexers then choose at least one indexer.
Setup your download client:
  • Simply goto Settings > Download Client, select your installed download client and enter required credentials.
Setup file creation mask:
  • If you require write access from other applications (e.g. Plex subtitle downloads), you'll also need to set the file/folder creation mask to allow this.
    • In the the web interface, select Settings
    • Toggle to Advanced settings slider (enable it)
    • Under Media Management tab, scroll down to the bottom of the page under Permissions, set the following values:
    • Save changes
Add a music:
  • Simply select Artist > Add New
  • Type a name of the artist you wish to find
  • Once found, under root folder, use the following location /mnt/dietpi_userdata/downloads
  • Change any other settings as required, then select Add
Using custom download/media directories outside of /mnt/:
Since DietPi v6.29, by default Lidarr has strict permissions to only access download and media directories inside /mnt/. If you need to use a different location, please do the following:
  • 1. Run dietpi-services from console
  • 2. Select lidarr
  • 3. Select Edit
  • 4. Uncomment (remove leading #) the line, starting with ReadWritePaths=
  • 5. Add your custom path to the end of this line, separated by one space
  • 6. Press ctrl+o buttons to save and ctrl+x to exit
Link databases to RAM:
Link the Lidarr info/settings database to RAM to increase access performance, reduce disk I/O and avoide constant external HDD spinning due to the very regular access to these files: viewtopic.php?f=8&t=5828
Recommended: Protect your privacy with a VPN:
Although we enable forced encryption on all our BitTorrent clients, if you wish to ensure complete privacy and peice of mind for all your downloaded content, using a VPN is critical.
Fourdee
v6.13
Post by Fourdee »
Deprecation warning: This post is deprecated. Please find our new documentation at: https://dietpi.com/docs/software/distri ... oldinghome
Folding@Home
Folding@home is a project focused on disease research. The problems we’re solving require so many computer calcul­ations – and we need your help to find the cures!
By default, our installation will add you to the DietPi team group, however, you can change this in the web interface at any time.
Access Web Interface: View/Edit Config file:
  • Stop service: systemctl stop fahclient
  • Edit config file: /mnt/dietpi_userdata/fahclient/config.xml
  • Save changes and restart service: systemctl start fahclient
View logs:
  • journalctl -u fahclient
v6.14
Deprecation warning: This post is deprecated. Please find our new documentation at: https://dietpi.com/docs/software/social/#freshrss
FreshRSS
A self-hosted RSS feed aggregator
Access web interface: How do I use this software?
Please refer to the official online documentation for usage information:
https://freshrss.github.io/FreshRSS/en/ ... steps.html
Fourdee
v6.15
Post by Fourdee »
Deprecation warning: This post is deprecated. Please find our new documentation at: https://dietpi.com/docs/software/media/#mympd
myMPD
A lightweight, bare-bones, no frills Hifi music player with a web based interface. myMPD is a front end for MPD, and a recent fork of YMPD.
Also installs:
  • MPD (music player daemon)
Access web interface: Install Notes:
We have disabled SSL and its redirect by default with the DietPi install. This is to prevent redirects to the hostname.
To re-enable the SSL connection and redirect option:
  • Edit /etc/mympd.conf
  • Replace ssl = false with ssl = true
  • Save changes and exit
  • Restart services with dietpi-services restart
  • Use the same URL address above, it will redirect to HTTPS during connection
Transfer/Add Music: Refresh Music Files / Database:
Simply select the Update database option from the settings menu in myMPD.
DietPi-JustBoom control panel: Tweak audio options on the fly
Simply run dietpi-justboom from the command line to launch
v6.18
Deprecation warning: This post is deprecated. Please find our new documentation at: https://dietpi.com/docs/software/cloud/#nextcloud-talk
Nextcloud Talk
Video calls hosted on your own Nextcloud instance. The TURN server "coturn" will be installed and configured as well to allow reliable video calls through outside the local network, NAT and firewall setups.
Also installs:
  • Nextcloud
  • coturn
Install Notes:
  • During installation you will be asked to enter the external server domain and a port, that you want to use for the coturn TURN server. Note that you need to forward the chosen port and/or open it in your firewall.
  • If HTTPS was or is enabled via dietpi-letsencrypt, coturn will be configured to use the LetsEncrypt certificates for TLS connections on the chosen TURN server port automatically.
  • coturn by default will listen to non-TLS requests as well on the port configured in /etc/turnserver.conf. You can force TLS/control this by switching port forwarding in your router and/or opening/dropping ports in your firewall.
  • coturn logging by default is disabled via /etc/default/coturn command arguments, since it is very verbose and produces much disk I/O. You can enable and configure logging via /etc/turnserver.conf, if required.
Locked
