ifconfig command not found ?
Fourdee
Re: ifconfig command not found ?
Post by Fourdee »
volpone wrote:The PATH issue arise when ifconfig command is run from LXterminal via RDP Microsoft Remote Desktop (as root too).
In this case /usr/sbin is not in the PATH replaced by /usr/X11R6/bin ?
Try forcing linux terminal emulation.
Add following to end of /root/.bashrc
export TERM='linux'
reload:
. /root/.bashrc
volpone
Post by volpone »
Thank you @Fourdee,
I've already set TERM=linux in .bashrc according to your recommendation, see this thread: http://dietpi.com/phpbb/viewtopic.php?f=11&t=1488
No joy ...
PATH KO from LXterminal via RDP and PATH OK when from OSX terminal.
Seems PATH is set differently when i'm logging from RDP (Microsoft Remote Desktop).
For example, same issue when running other command from LXterminal via RDP:
root@DietPi:~# reboot
root@DietPi:~# bash: reboot: command not found
Everything else is running perfectly ...
Any idea ?
markfree
Post by markfree »
I suggest closing this thread pointing to a more recent one, like viewtopic.php?p=22098
well you pulled up a 3 years old thread. Basically it was closed already. :lol:
