8
113807
2 March 2025
How to use dietpi.txt when using dietpi-installer over debian 12 image?
4
15
4 April 2025
Occasionally sites won't load after upgrade from Bullseye to Bookworm (Adguard?)
3
30
4 April 2025
Jellyfin shows more than one server after reinstalling
3
14
4 April 2025
Kodi 20.5 on RPie5 - Videos won't play and CPU utilisation 100%
6
43
4 April 2025
[Orange Pi Zero 2W] How to enable UART5?
0
13
3 April 2025
VICE full screen
1
60
3 April 2025
First time Install error
13
49
1 April 2025
[RPi 4B] No 4K resolution after upgrade to v9.10 [SOLVED]
6
98
1 April 2025
SD Card crashed - Errors when restoring backup
10
56
1 April 2025
Auto removed kernel, am I in trouble?
7
38
1 April 2025
Odroid-C4 no hdmi audio
3
41
31 March 2025
Troubles with installation of HomeAssistant
2
29
31 March 2025
Microphone not working on OrangePi Zero 2w
20
81
31 March 2025
Using DietPi on an external cloud host
5
37
31 March 2025
How to create a DietPi-VM in Pimox7?
12
1759
30 March 2025
Mounting problem (solved)
3
21
30 March 2025
Jellyfin - resest admin password
10
59442
30 March 2025
Migrate from Odroid N2+ to a fresh Raspberry Pi 5
2
22
30 March 2025
Per-app VPN routing?
5
26
29 March 2025
NanoPi NEO3 with DietPi Can I use a LCD2USB?
10
69
29 March 2025
Can't access nextcloud web login page - pihole and unbound installed already
9
31
29 March 2025
Troubles during dietpi-update
7
47
27 March 2025
How to swap DIETPI- Server-(Hardware)
9
78
27 March 2025
Failed to load library: libnspr4.so
2
20
26 March 2025
Pi-hole v6 with Unbound - DNS Resolvers Not Reaching IPv6 Nameservers Despite Active IPv6 Connection
2
51
26 March 2025
How to update Home Assistant?
1
33
26 March 2025
rPi3 freezes after some time
26
108
26 March 2025
DietPi only connects to NFSv3 share (not NFSv4.x)
8
33
25 March 2025
Enter key not working
3
34
25 March 2025
