Occasionally sites won't load after upgrade from Bullseye to Bookworm (Adguard?)
    G_DIETPI_VERSION_SUB=11
    G_DIETPI_VERSION_RC=2
  • Distro version | Bookworm
  • Kernel version | Linux DietPi 5.10.103-v8+ #1529 SMP PREEMPT
  • Architecture | arm64
  • SBC model | RPi 4 Model B (aarch64)
  • Power supply used | 5V
  • SD card used | Not sure (hidden in SmartPi 2 case)
  • Software title | Adguard v0.107.59
  • Was the software title installed freshly or updated/migrated? Migrated
  • Can this issue be replicated on a fresh installation of DietPi? Haven’t tried.
  1. Enter any URL in browser (Firefox v136.0.4 on MacOS Sequoia 15.3.2)
  2. Most times the browser will connect to the site but about 10% of the time it won’t and I get the message to Try Again.
  3. Trying a few minutes later, it will connect no problem.
  • Immediate connection to the site.
  • I Get the message:
    Hmm. We’re having trouble finding that site.
We can’t connect to the server at www.newsminimalist.com. (This is one example.)
If you entered the right address, you can:
  • Try again later
  • Check your network connection
  • Check that Firefox has permission to access the web (you might be connected but behind a firewall)
Button: Try Again
Probably something you should discuss with AGH developer as we don’t maintain AGH ourselves. As well you can have a look into AGH logs. There you should see the client DNS request. You would need to check the browser error messages in detail. There is a difference between can't connect and DNS resolution failing.
Ok, I’m not actually sure what the reason for pages not loading is. But when I switched off AGH, some pages still won’t load. If it’s a DNS resolution issue, where would I begin looking to solve this?
I cannot imagine that it is due to the DNS resolution. You can try different DNS servers on the client and see if anything changes.
