Mounting problem (solved)
I sent a bug report →
Please file a related bug report at GitHub or our forum:
What I did:
I shut down my Raspi on location A and switched off an USB HD
then I went to a complete other location B
here I unmounted the USB HD in Webmin and tried to mount another USB HD again in Webmin.
This did not work so I tried to do that with DIETPI-DRIVEMANAGER.. and that did not work, too.
I thank you very much for your help.
Karl
What is the reason for sharing these 2 links? And why not sharing an error message. Actually nobody can do anything with the information given.
that was the advise from DIETPI-Software.. but I could solve this mounting problem by my own.. Funny, but after a reboot drive manager worked again. I am used to see this behavior in Linux..
But next I run in another problem on installing ** home assistant.**
The installer refers to a file in /tmp, which I enclose to this case
python-build.20250330230346.8247.log (995 Bytes)
BR KARL
Pls open a new topic as this is a different issue
