[Solved] How to run Pi-Hole and FreshRSS at the same time?
Re: How to run Pi-Hole and FreshRSS at the same time?
To avoid the same issue with future pihole -up calls, please do the following:
G_CONFIG_INJECT 'INSTALL_WEB_SERVER=' 'INSTALL_WEB_SERVER=false' /etc/pihole/setupVars.conf
Mordog
Post by Mordog »
done.
so in the future i have to run dietpi-software reinstall 93 to update pi-hole?
Nope, with the commend you just made, you can from now on use pihole -up without issues.
Mitchel99
Re: [Solved] How to run Pi-Hole and FreshRSS at the same time?
Post by Mitchel99 »
Thank you, MichaIng, Fourdee and Mordog!
My lighttpd configuration is fixed too now and I can run Pihole and FreshRSS at same time! Great! :D
