[Tutorial - Outdated] RPi: - Move the filesystem to a USB Drive
k-plan
Re: DietPi - Boot RPi from USB?
Post by k-plan »
Hi.
which "boot problem" do you mean?
"repair disc" by what? By fsck ?
In your system need/want/make as filesystem check and repair, something is going wrong.
Storage medium is going to be faulty, or something witch power supply system is wrong.
johnvick
Legend
Post by johnvick »
The Pi3 can boot from USB drive without SD card - see this thread:
http://dietpi.com/phpbb/viewtopic.php?f=9&t=655
This is for interest only as it does not create a stable system.
John
jsfrederick
Re: RPi: - Move the filesystem to a USB Drive
Post by jsfrederick »
I've converted all my Pi's to boot from hard drive or USB stick. Works flawlessly! Followed the official instructions here: ( https://www.raspberrypi.org/documentati ... des/msd.md
I've had no issues so far. I am wondering if DietPi can be done using the same instructions. Has anyone tried? What is the take on official support for this from DietPi?
Thanks!
k-plan
Post by k-plan »
jsfrederick wrote:Has anyone tried?
Yes.
https://github.com/Fourdee/DietPi/issue ... -246702824
Running DietPi on a USB HDD w/o SD
jsfrederick wrote:I've converted all my Pi's to boot from hard drive or USB stick.
All Raspberry Pi's ?!
I will say no.
What's about Raspberry Pi-Zero, Raspberry Pi Zero W, Raspberry Pi B+ , Raspberry Pi B, Raspberry Pi A, Raspberry Pi 2, ...?
jsfrederick wrote:I've had no issues so far.
I have: https://github.com/Fourdee/DietPi/issue ... -246734927
And, unfortunately seeing no advantage over moving filesystem to USB devices. Only drawback and rising boot up time. Sorry.
But you can do as you like.
jsfrederick wrote:What is the take on official support for this from DietPi?
https://github.com/Fourdee/DietPi/issue ... -258833304
jsfrederick
Yes.
I will say no.
All the Pi's I have are RPi 3's so, yes, all mine are booting from hard disk.
I do. It reduces the issues with booting and writing to SD cards and produces a more stable storage platform. Yes, it does increase the boot time, but that is something I will live with. It also allows for LARGE (>2TB) storage platforms. I am using them for Nextcloud and Netatalk.
I did see and read the other message about this process. I think that most folks had attempted USB boot before it was "Officially" supported by RPI Foundation. They just supported this in March (I think). So maybe it would work well now with DietPi. I may give it a try when I get a few minutes.[
Thanks for the info/i]
tdiguy
Post by tdiguy »
Curious,
I previously had tried to run diet pi off usb and it was not supported.
My pi is set up to boot from the USB without an issue. I currently run Raspbian stretch off a usb stick.
Does diet pi now support booting from the usb so i could download the image write the image to usb with etcher and get rolling?
