8
113813
2 March 2025
Kernel version and kernel headers out of sync after kernel update
4
9
6 April 2025
BT XBOX series X - re-arranged buttons
1
21
5 April 2025
SD Card crashed - Errors when restoring backup
12
66
4 April 2025
Allow `dietpi` user to remotely stop and start services
2
19
4 April 2025
[Orange Pi Zero 2W] How to enable UART5?
1
26
4 April 2025
How to use dietpi.txt when using dietpi-installer over debian 12 image?
4
26
4 April 2025
Occasionally sites won't load after upgrade from Bullseye to Bookworm (Adguard?)
3
34
4 April 2025
Jellyfin shows more than one server after reinstalling
3
19
4 April 2025
Kodi 20.5 on RPie5 - Videos won't play and CPU utilisation 100%
6
52
4 April 2025
VICE full screen
1
62
3 April 2025
First time Install error
13
53
1 April 2025
[RPi 4B] No 4K resolution after upgrade to v9.10 [SOLVED]
6
99
1 April 2025
Auto removed kernel, am I in trouble?
7
39
1 April 2025
Odroid-C4 no hdmi audio
3
41
31 March 2025
Troubles with installation of HomeAssistant
2
35
31 March 2025
Microphone not working on OrangePi Zero 2w
20
86
31 March 2025
Using DietPi on an external cloud host
5
39
31 March 2025
How to create a DietPi-VM in Pimox7?
12
1763
30 March 2025
Mounting problem (solved)
3
21
30 March 2025
Jellyfin - resest admin password
10
59532
30 March 2025
Migrate from Odroid N2+ to a fresh Raspberry Pi 5
2
24
30 March 2025
Per-app VPN routing?
5
27
29 March 2025
NanoPi NEO3 with DietPi Can I use a LCD2USB?
10
70
29 March 2025
Can't access nextcloud web login page - pihole and unbound installed already
9
32
29 March 2025
Troubles during dietpi-update
7
48
27 March 2025
How to swap DIETPI- Server-(Hardware)
9
79
27 March 2025
Failed to load library: libnspr4.so
2
20
26 March 2025
Pi-hole v6 with Unbound - DNS Resolvers Not Reaching IPv6 Nameservers Despite Active IPv6 Connection
2
55
26 March 2025
How to update Home Assistant?
1
36
26 March 2025
