Default port to forward thru firewall is UDP/1194
Mine works like a champ...never had a problem
OpenVPN general usage
Re: OpenVPN general usage
Will it work together with the tool from this website? I've heard good reviews about positive technologies.
As long as you allow incoming connections through the tun0 interface by this firewall it should generally work. But with pre-configured firewalls you never know exactly, e.g. in comparison to iptables where you explicitly need to block certain requests so you know exactly what is blocked in which circumstances.
