- DietPi version |
G_DIETPI_VERSION_CORE=9
G_DIETPI_VERSION_SUB=3
G_DIETPI_VERSION_RC=0
G_GITOWNER=‘MichaIng’ - Distro version | bookworm
- Kernel version | Linux DietPi 6.1.0-20-amd64 #1 SMP PREEMPT_DYNAMIC Debian 6.1.85-1 (2024-04-11) x86_64 GNU/Linux
- Architecture | amd64
- SBC model | Native PC (x86_64)
- Power supply used | Laptop Stock
- SD card used | TOSHIBA HDD
Can’t access softwares and nothing working properly even wifi. Tried other forum solutions, nothing works for me.
RootFS is currently set to “Read Only (R/O)”. DietPi-Drive_Manager requires
“Read Write (R/W)” access to function.
Would you like to re-enable R/W access on RootFS?
When clicked ok it shows:
- Command: mount -v -o remount,rw /
- Exit code: 32
- DietPi version: v9.3.0 (MichaIng/master) | HW_MODEL: 21 | HW_ARCH: 10 |
DISTRO: 7 - Error log:
mount: /: cannot remount /dev/sda1 read-write, is write-protected.
dmesg(1) may have more information after failed mount system call.
From dmesg:
[ 1.143288] r8169 0000:02:00.0: can't disable ASPM; OS doesn't have ASPM control
[ 1.145533] ehci-pci 0000:00:1d.0: EHCI Host Controller
[ 1.145612] ehci-pci 0000:00:1d.0: new USB bus registered, assigned bus number 1
[ 1.145710] ehci-pci 0000:00:1d.0: debug port 2
[ 1.149817] ehci-pci 0000:00:1d.0: irq 23, io mem 0xf7223000
[ 1.156102] SCSI subsystem initialized
[ 1.160673] r8169 0000:02:00.0 eth0: RTL8168gu/8111gu, f8:32:e4:00:36:9c, XID 509, IRQ 45
[ 1.160772] r8169 0000:02:00.0 eth0: jumbo features [frames: 9194 bytes, tx checksumming: ko]
[ 1.165198] ehci-pci 0000:00:1d.0: USB 2.0 started, EHCI 1.00
[ 1.165348] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
[ 1.165439] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.165526] usb usb1: Product: EHCI Host Controller
[ 1.165592] usb usb1: Manufacturer: Linux 6.1.0-20-amd64 ehci_hcd
[ 1.165661] usb usb1: SerialNumber: 0000:00:1d.0
[ 1.165945] hub 1-0:1.0: USB hub found
[ 1.166018] hub 1-0:1.0: 2 ports detected
[ 1.166358] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 1.166449] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[ 1.167670] xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x100 quirks 0x000000000004b810
[ 1.167949] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 1.168022] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 3
[ 1.168108] xhci_hcd 0000:00:14.0: Host supports USB 3.0 SuperSpeed
[ 1.168280] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
[ 1.170116] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.170203] usb usb2: Product: xHCI Host Controller
[ 1.170267] usb usb2: Manufacturer: Linux 6.1.0-20-amd64 xhci-hcd
[ 1.170333] usb usb2: SerialNumber: 0000:00:14.0
[ 1.170595] hub 2-0:1.0: USB hub found
[ 1.170675] hub 2-0:1.0: 11 ports detected
[ 1.177693] usb usb3: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.01
[ 1.177785] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.177869] usb usb3: Product: xHCI Host Controller
[ 1.177933] usb usb3: Manufacturer: Linux 6.1.0-20-amd64 xhci-hcd
[ 1.177999] usb usb3: SerialNumber: 0000:00:14.0
[ 1.178228] hub 3-0:1.0: USB hub found
[ 1.178305] hub 3-0:1.0: 4 ports detected
[ 1.188676] libata version 3.00 loaded.
[ 1.195013] ahci 0000:00:1f.2: version 3.0
[ 1.205288] ahci 0000:00:1f.2: AHCI 0001.0300 32 slots 2 ports 6 Gbps 0x3 impl SATA mode
[ 1.205381] ahci 0000:00:1f.2: flags: 64bit ncq pm led clo only pio slum part deso sadm sds apst
[ 1.206175] scsi host0: ahci
[ 1.206503] scsi host1: ahci
[ 1.206671] ata1: SATA max UDMA/133 abar m2048@0xf7222000 port 0xf7222100 irq 47
[ 1.206760] ata2: SATA max UDMA/133 abar m2048@0xf7222000 port 0xf7222180 irq 47
[ 1.253229] tsc: Refined TSC clocksource calibration: 1995.380 MHz
[ 1.253306] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x39864456686, max_idle_ns: 881590680204 ns
[ 1.253431] clocksource: Switched to clocksource tsc
[ 1.421265] usb 1-1: new high-speed USB device number 2 using ehci-pci
[ 1.433266] usb 2-5: new high-speed USB device number 2 using xhci_hcd
[ 1.520938] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 1.521084] ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 1.524719] ata2.00: ATAPI: MATSHITA DVD-RAM UJ8HC, 1.00, max UDMA/100
[ 1.531810] ata2.00: configured for UDMA/100
[ 1.574664] ata1.00: ATA-8: TOSHIBA MQ01ABD100, AX0R2J, max UDMA/100
[ 1.575228] ata1.00: 1953525168 sectors, multi 16: LBA48 NCQ (depth 32), AA
[ 1.577651] ata1.00: configured for UDMA/100
[ 1.577954] usb 1-1: New USB device found, idVendor=8087, idProduct=8001, bcdDevice= 0.03
[ 1.578090] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.578499] scsi 0:0:0:0: Direct-Access ATA TOSHIBA MQ01ABD1 2J PQ: 0 ANSI: 5
[ 1.578946] hub 1-1:1.0: USB hub found
[ 1.579205] hub 1-1:1.0: 8 ports detected
[ 1.582113] scsi 1:0:0:0: CD-ROM MATSHITA DVD-RAM UJ8HC 1.00 PQ: 0 ANSI: 5
[ 1.618189] usb 2-5: config 1 interface 1 altsetting 4 endpoint 0x81 has invalid wMaxPacketSize 0
[ 1.624874] usb 2-5: New USB device found, idVendor=04f2, idProduct=b483, bcdDevice=99.14
[ 1.624986] usb 2-5: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.625068] usb 2-5: Product: USB2.0 VGA UVC WebCam
[ 1.655629] sd 0:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[ 1.655725] sd 0:0:0:0: [sda] 4096-byte physical blocks
[ 1.655813] sd 0:0:0:0: [sda] Write Protect is off
[ 1.655881] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.655922] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.656037] sd 0:0:0:0: [sda] Preferred minimum I/O size 4096 bytes
[ 1.701202] sr 1:0:0:0: [sr0] scsi3-mmc drive: 24x/24x writer dvd-ram cd/rw xa/form2 cdda tray
[ 1.701295] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 1.738263] sda: sda1
[ 1.738529] sd 0:0:0:0: [sda] Attached SCSI disk
[ 1.751300] sr 1:0:0:0: Attached scsi CD-ROM sr0
[ 2.265217] usb 2-6: new full-speed USB device number 3 using xhci_hcd
[ 2.414233] usb 2-6: New USB device found, idVendor=04ca, idProduct=3010, bcdDevice= 0.01
[ 2.414326] usb 2-6: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.506128] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
[ 2.712874] Not activating Mandatory Access Control as /sbin/tomoyo-init does not exist.
[ 4.057561] systemd[1]: Inserted module 'autofs4'
[ 4.349945] systemd[1]: systemd 252.22-1~deb12u1 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[ 4.350243] systemd[1]: Detected architecture x86-64.
[ 4.404371] systemd[1]: Hostname set to <DietPi>.
[ 5.665892] input: PS/2 Logitech Wheel Mouse as /devices/platform/i8042/serio1/input/input2
[ 6.094637] systemd[1]: Queued start job for default target graphical.target.
[ 6.119794] systemd[1]: Created slice system-getty.slice - Slice /system/getty.
[ 6.121264] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe.
[ 6.121916] systemd[1]: Started systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch.
[ 6.122471] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch.
[ 6.123290] systemd[1]: Set up automount proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point.
[ 6.123743] systemd[1]: Reached target cryptsetup.target - Local Encrypted Volumes.
[ 6.124160] systemd[1]: Reached target integritysetup.target - Local Integrity Protected Volumes.
[ 6.124613] systemd[1]: Reached target paths.target - Path Units.
[ 6.124971] systemd[1]: Reached target remote-fs.target - Remote File Systems.
[ 6.125389] systemd[1]: Reached target slices.target - Slice Units.
[ 6.125750] systemd[1]: Reached target swap.target - Swaps.
[ 6.126132] systemd[1]: Reached target veritysetup.target - Local Verity Protected Volumes.
[ 6.126848] systemd[1]: Listening on systemd-fsckd.socket - fsck to fsckd communication Socket.
[ 6.127431] systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe.
[ 6.128729] systemd[1]: Listening on systemd-journald-audit.socket - Journal Audit Socket.
[ 6.129413] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log).
[ 6.130052] systemd[1]: Listening on systemd-journald.socket - Journal Socket.
[ 6.135274] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket.
[ 6.135949] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
[ 6.136297] systemd[1]: Reached target sockets.target - Socket Units.
[ 6.138595] systemd[1]: Mounting dev-hugepages.mount - Huge Pages File System...
[ 6.140705] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System...
[ 6.142253] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System...
[ 6.143629] systemd[1]: Mounting sys-kernel-tracing.mount - Kernel Trace File System...
[ 6.145832] systemd[1]: Starting fake-hwclock.service - Restore / save the current clock...
[ 6.147970] systemd[1]: Starting keyboard-setup.service - Set the console keyboard layout...
[ 6.149741] systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes...
[ 6.151350] systemd[1]: Starting modprobe@configfs.service - Load Kernel Module configfs...
[ 6.155566] systemd[1]: Starting modprobe@dm_mod.service - Load Kernel Module dm_mod...
[ 6.157261] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
[ 6.159594] systemd[1]: Starting modprobe@fuse.service - Load Kernel Module fuse...
[ 6.161894] systemd[1]: Starting modprobe@loop.service - Load Kernel Module loop...
[ 6.162263] systemd[1]: systemd-fsck-root.service - File System Check on Root Device was skipped because of an unmet condition check (ConditionPathExists=!/run/initramfs/fsck-root).
[ 6.164551] systemd[1]: Starting systemd-journald.service - Journal Service...
[ 6.167150] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules...
[ 6.169123] systemd[1]: Starting systemd-remount-fs.service - Remount Root and Kernel File Systems...
[ 6.171092] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices...
[ 6.207914] systemd[1]: Finished systemd-modules-load.service - Load Kernel Modules.
[ 6.209488] systemd[1]: Starting systemd-sysctl.service - Apply Kernel Variables...
[ 6.379784] systemd[1]: Mounted dev-hugepages.mount - Huge Pages File System.
[ 6.380191] systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System.
[ 6.380563] systemd[1]: Mounted sys-kernel-debug.mount - Kernel Debug File System.
[ 6.380921] systemd[1]: Mounted sys-kernel-tracing.mount - Kernel Trace File System.
[ 6.416075] systemd[1]: Started systemd-journald.service - Journal Service.
[ 6.512891] EXT4-fs (sda1): re-mounted. Quota mode: none.
[ 6.522593] loop: module loaded
[ 6.818882] fuse: init (API version 7.37)
[ 6.821758] device-mapper: core: CONFIG_IMA_DISABLE_HTABLE is disabled. Duplicate IMA measurements will not be recorded in the IMA log.
[ 6.821901] device-mapper: uevent: version 1.0.3
[ 6.822061] device-mapper: ioctl: 4.47.0-ioctl (2022-07-28) initialised: dm-devel@redhat.com
[ 7.412273] systemd-journald[235]: Received client request to flush runtime journal.
[ 7.545277] ACPI: AC: AC Adapter [AC0] (on-line)
[ 7.566503] input: Asus Wireless Radio Control as /devices/LNXSYSTM:00/LNXSYBUS:00/ATK4002:00/input/input3
[ 7.613928] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input4
[ 7.613986] ACPI: button: Lid Switch [LID]
[ 7.614066] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input5
[ 7.629502] ACPI: button: Sleep Button [SLPB]
[ 7.629612] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input6
[ 7.629716] ACPI: button: Power Button [PWRF]
[ 8.068815] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 8.068877] sr 1:0:0:0: Attached scsi generic sg1 type 5
[ 8.092674] input: PC Speaker as /devices/platform/pcspkr/input/input7
[ 8.232013] ACPI: bus type drm_connector registered
[ 8.232976] iTCO_vendor_support: vendor-support=0
[ 8.233249] RAPL PMU: API unit is 2^-32 Joules, 4 fixed counters, 655360 ms ovfl timer
[ 8.233255] RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
[ 8.233258] RAPL PMU: hw unit of domain package 2^-14 Joules
[ 8.233259] RAPL PMU: hw unit of domain dram 2^-14 Joules
[ 8.233260] RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
[ 8.246205] Consider using thermal netlink events interface
[ 8.257475] iTCO_wdt iTCO_wdt.1.auto: Found a Wildcat Point_LP TCO device (Version=2, TCOBASE=0x1860)
[ 8.257681] iTCO_wdt iTCO_wdt.1.auto: initialized. heartbeat=30 sec (nowayout=0)
[ 8.312656] asus_wmi: ASUS WMI generic driver loaded
[ 8.911216] cryptd: max_cpu_qlen set to 1000
[ 8.931987] asus_wmi: Initialization: 0x1
[ 8.932045] asus_wmi: BIOS WMI version: 7.9
[ 8.932099] asus_wmi: SFUN value: 0xa0077
[ 8.932104] asus-nb-wmi asus-nb-wmi: Detected ATK, not ASUSWMI, use DSTS
[ 8.932109] asus-nb-wmi asus-nb-wmi: Detected ATK, enable event queue
[ 8.937609] input: Asus WMI hotkeys as /devices/platform/asus-nb-wmi/input/input8
[ 8.955873] asus_wmi: fan_curve_get_factory_default (0x00110024) failed: -19
[ 8.956321] asus_wmi: fan_curve_get_factory_default (0x00110025) failed: -19
[ 9.040742] intel_rapl_common: Found RAPL domain package
[ 9.040747] intel_rapl_common: Found RAPL domain core
[ 9.040749] intel_rapl_common: Found RAPL domain uncore
[ 9.040751] intel_rapl_common: Found RAPL domain dram
[ 9.040757] intel_rapl_common: RAPL package-0 domain package locked by BIOS
[ 9.040765] intel_rapl_common: RAPL package-0 domain dram locked by BIOS
[ 9.070201] mc: Linux media interface: v0.10
[ 9.164917] alg: No test for fips(ansi_cprng) (fips_ansi_cprng)
[ 9.247092] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 9.247510] cfg80211: Loaded X.509 cert 'benh@debian.org: 577e021cb980e0e820821ba7b54b4961b8b4fadf'
[ 9.247780] cfg80211: Loaded X.509 cert 'romain.perier@gmail.com: 3abbc6ec146e09d1b6016ab9d6cf71dd233f0328'
[ 9.248028] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 9.248268] cfg80211: Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
[ 9.498650] videodev: Linux video capture interface: v2.00
[ 9.648525] platform regulatory.0: firmware: direct-loading firmware regulatory.db
[ 9.926434] platform regulatory.0: firmware: direct-loading firmware regulatory.db.p7s
[ 10.158502] AVX2 version of gcm_enc/dec engaged.
[ 10.158553] AES CTR mode by8 optimization enabled
[ 10.601055] usb 2-5: Found UVC 1.00 device USB2.0 VGA UVC WebCam (04f2:b483)
[ 10.671589] input: USB2.0 VGA UVC WebCam: USB2.0 V as /devices/pci0000:00/0000:00:14.0/usb2/2-5/2-5:1.0/input/input9
[ 10.671765] usbcore: registered new interface driver uvcvideo
[ 11.298079] Bluetooth: Core ver 2.22
[ 11.298113] NET: Registered PF_BLUETOOTH protocol family
[ 11.298116] Bluetooth: HCI device and connection manager initialized
[ 11.298120] Bluetooth: HCI socket layer initialized
[ 11.298123] Bluetooth: L2CAP socket layer initialized
[ 11.298128] Bluetooth: SCO socket layer initialized
[ 11.729953] i915 0000:00:02.0: vgaarb: deactivate vga console
[ 11.731300] Console: switching to colour dummy device 80x25
[ 11.732589] i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=io+mem:owns=io+mem
[ 11.745300] snd_hda_codec_conexant hdaudioC1D0: CX20751/2: BIOS auto-probing.
[ 11.745819] snd_hda_codec_conexant hdaudioC1D0: autoconfig for CX20751/2: line_outs=1 (0x17/0x0/0x0/0x0/0x0) type:speaker
[ 11.745824] snd_hda_codec_conexant hdaudioC1D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 11.745827] snd_hda_codec_conexant hdaudioC1D0: hp_outs=1 (0x16/0x0/0x0/0x0/0x0)
[ 11.745830] snd_hda_codec_conexant hdaudioC1D0: mono: mono_out=0x0
[ 11.745831] snd_hda_codec_conexant hdaudioC1D0: inputs:
[ 11.745833] snd_hda_codec_conexant hdaudioC1D0: Internal Mic=0x1a
[ 11.745835] snd_hda_codec_conexant hdaudioC1D0: Mic=0x19
[ 11.749212] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1b.0/sound/card1/input10
[ 11.749334] input: HDA Intel PCH Mic as /devices/pci0000:00/0000:00:1b.0/sound/card1/input11
[ 11.749438] input: HDA Intel PCH Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card1/input12
[ 11.808253] [drm] Initialized i915 1.6.0 20201103 for 0000:00:02.0 on minor 0
[ 11.810898] ACPI: video: Video Device [GFX0] (multi-head: yes rom: no post: no)
[ 11.813636] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input13
[ 11.813865] snd_hda_intel 0000:00:03.0: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[ 11.816985] fbcon: i915drmfb (fb0) is primary device
[ 12.932716] Console: switching to colour frame buffer device 170x48
[ 12.952164] i915 0000:00:02.0: [drm] fb0: i915drmfb frame buffer device
[ 13.103448] input: HDA Intel HDMI HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:03.0/sound/card0/input14
[ 13.103577] input: HDA Intel HDMI HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:03.0/sound/card0/input15
[ 13.103691] input: HDA Intel HDMI HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:03.0/sound/card0/input16
[ 13.133284] usbcore: registered new interface driver btusb
[ 13.265199] ath: phy0: WB335 1-ANT card detected
[ 13.265204] ath: phy0: Set BT/WLAN RX diversity capability
[ 13.274608] ath: phy0: Enable LNA combining
[ 13.275846] ath: phy0: ASPM enabled: 0x43
[ 13.275850] ath: EEPROM regdomain: 0x6c
[ 13.275851] ath: EEPROM indicates we should expect a direct regpair map
[ 13.275853] ath: Country alpha2 being used: 00
[ 13.275854] ath: Regpair used: 0x6c
[ 13.277083] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[ 13.277951] ieee80211 phy0: Atheros AR9565 Rev:1 mem=0x00000000911f372c, irq=19
[ 13.909319] usb 2-6: firmware: direct-loading firmware ar3k/ramps_0x31010000_40.dfu
[ 13.913437] intel_pstate: Turbo disabled by BIOS or unavailable on processor
[ 13.914106] usbcore: registered new interface driver ath3k
[ 13.914628] usb 2-6: USB disconnect, device number 3
[ 14.225308] usb 2-6: new full-speed USB device number 4 using xhci_hcd
[ 17.148526] wlan0: authenticate with 08:bf:b8:95:e9:d0
[ 17.148549] wlan0: 80 MHz not supported, disabling VHT
[ 17.161092] wlan0: send auth to 08:bf:b8:95:e9:d0 (try 1/3)
[ 17.173816] wlan0: authenticated
[ 17.177298] wlan0: associate with 08:bf:b8:95:e9:d0 (try 1/3)
[ 17.204527] wlan0: RX AssocResp from 08:bf:b8:95:e9:d0 (capab=0x1c11 status=0 aid=16)
[ 17.204726] wlan0: associated
[ 17.298825] wlan0: Limiting TX power to 30 (30 - 0) dBm as advertised by 08:bf:b8:95:e9:d0
[ 17.481430] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 19.418783] usb 2-6: New USB device found, idVendor=04ca, idProduct=3010, bcdDevice= 0.02
[ 19.418797] usb 2-6: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 22.084934] wlan0: authenticate with 08:bf:b8:95:e9:d0
[ 22.084969] wlan0: 80 MHz not supported, disabling VHT
[ 22.097509] wlan0: send auth to 08:bf:b8:95:e9:d0 (try 1/3)
[ 22.112834] wlan0: authenticated
[ 22.117247] wlan0: associate with 08:bf:b8:95:e9:d0 (try 1/3)
[ 22.127143] wlan0: RX AssocResp from 08:bf:b8:95:e9:d0 (capab=0x1c11 status=0 aid=16)
[ 22.127342] wlan0: associated
[ 22.419314] wlan0: Limiting TX power to 30 (30 - 0) dBm as advertised by 08:bf:b8:95:e9:d0
[ 38.370417] ata1.00: exception Emask 0x0 SAct 0x70000e0 SErr 0x50000 action 0x0
[ 38.370488] ata1.00: irq_stat 0x40000001
[ 38.370517] ata1: SError: { PHYRdyChg CommWake }
[ 38.370553] ata1.00: failed command: READ FPDMA QUEUED
[ 38.370585] ata1.00: cmd 60/30:28:a0:30:fa/00:00:17:00:00/40 tag 5 ncq dma 24576 in
res 41/40:d0:c0:b0:3c/00:00:09:00:00/40 Emask 0x9 (media error)
[ 38.370673] ata1.00: status: { DRDY ERR }
[ 38.370701] ata1.00: error: { UNC }
[ 38.370727] ata1.00: failed command: WRITE FPDMA QUEUED
[ 38.370758] ata1.00: cmd 61/08:30:00:b8:3c/00:00:00:00:00/40 tag 6 ncq dma 4096 out
[ 38.370844] ata1.00: status: { DRDY ERR }
[ 38.370871] ata1.00: error: { UNC }
[ 38.370896] ata1.00: failed command: READ FPDMA QUEUED
[ 38.370927] ata1.00: cmd 60/00:38:08:3a:85/01:00:4b:00:00/40 tag 7 ncq dma 131072 in
[ 38.371013] ata1.00: status: { DRDY ERR }
[ 38.371040] ata1.00: error: { UNC }
[ 38.371068] ata1.00: failed command: READ FPDMA QUEUED
[ 38.371099] ata1.00: cmd 60/08:c0:70:ed:20/00:00:72:00:00/40 tag 24 ncq dma 4096 in
[ 38.371184] ata1.00: status: { DRDY ERR }
[ 38.371210] ata1.00: error: { UNC }
[ 38.371236] ata1.00: failed command: READ FPDMA QUEUED
[ 38.371267] ata1.00: cmd 60/00:c8:80:b0:3c/01:00:09:00:00/40 tag 25 ncq dma 131072 in
res 41/40:00:c0:b0:3c/00:01:09:00:00/40 Emask 0x409 (media error) <F>
[ 38.371355] ata1.00: status: { DRDY ERR }
[ 38.371381] ata1.00: error: { UNC }
[ 38.371406] ata1.00: failed command: READ FPDMA QUEUED
[ 38.371437] ata1.00: cmd 60/00:d0:80:b1:3c/01:00:09:00:00/40 tag 26 ncq dma 131072 in
[ 38.371522] ata1.00: status: { DRDY ERR }
[ 38.371548] ata1.00: error: { UNC }
[ 38.382123] ata1: hard resetting link
[ 38.697910] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 38.765119] ata1.00: configured for UDMA/100
[ 38.765582] sd 0:0:0:0: [sda] tag#5 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=4s
[ 38.765592] sd 0:0:0:0: [sda] tag#5 Sense Key : Medium Error [current]
[ 38.765599] sd 0:0:0:0: [sda] tag#5 Add. Sense: Unrecovered read error - auto reallocate failed
[ 38.765605] sd 0:0:0:0: [sda] tag#5 CDB: Read(10) 28 00 17 fa 30 a0 00 00 30 00
[ 38.765608] I/O error, dev sda, sector 402272416 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 2
[ 38.765713] sd 0:0:0:0: [sda] tag#6 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=2s
[ 38.765720] sd 0:0:0:0: [sda] tag#6 Sense Key : Medium Error [current]
[ 38.765724] sd 0:0:0:0: [sda] tag#6 Add. Sense: Unrecovered read error - auto reallocate failed
[ 38.765729] sd 0:0:0:0: [sda] tag#6 CDB: Write(10) 2a 00 00 3c b8 00 00 00 08 00
[ 38.765732] I/O error, dev sda, sector 3979264 op 0x1:(WRITE) flags 0x800 phys_seg 1 prio class 2
[ 38.765791] EXT4-fs warning (device sda1): ext4_end_bio:343: I/O error 10 writing to inode 131324 starting block 497408)
[ 38.765810] sd 0:0:0:0: [sda] tag#7 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=4s
[ 38.765814] sd 0:0:0:0: [sda] tag#7 Sense Key : Medium Error [current]
[ 38.765817] sd 0:0:0:0: [sda] tag#7 Add. Sense: Unrecovered read error - auto reallocate failed
[ 38.765820] sd 0:0:0:0: [sda] tag#7 CDB: Read(10) 28 00 4b 85 3a 08 00 01 00 00
[ 38.765823] I/O error, dev sda, sector 1267022344 op 0x0:(READ) flags 0x80700 phys_seg 3 prio class 2
[ 38.765857] Buffer I/O error on device sda1, logical block 497152
[ 38.765890] sd 0:0:0:0: [sda] tag#24 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=4s
[ 38.766916] sd 0:0:0:0: [sda] tag#24 Sense Key : Medium Error [current]
[ 38.766920] sd 0:0:0:0: [sda] tag#24 Add. Sense: Unrecovered read error - auto reallocate failed
[ 38.766924] sd 0:0:0:0: [sda] tag#24 CDB: Read(10) 28 00 72 20 ed 70 00 00 08 00
[ 38.766926] I/O error, dev sda, sector 1914760560 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 2
[ 38.768264] sd 0:0:0:0: [sda] tag#25 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=4s
[ 38.768272] sd 0:0:0:0: [sda] tag#25 Sense Key : Medium Error [current]
[ 38.768280] sd 0:0:0:0: [sda] tag#25 Add. Sense: Unrecovered read error - auto reallocate failed
[ 38.768289] sd 0:0:0:0: [sda] tag#25 CDB: Read(10) 28 00 09 3c b0 80 00 01 00 00
[ 38.768294] I/O error, dev sda, sector 154972352 op 0x0:(READ) flags 0x80700 phys_seg 2 prio class 2
[ 38.770023] sd 0:0:0:0: [sda] tag#26 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=4s
[ 38.770034] sd 0:0:0:0: [sda] tag#26 Sense Key : Medium Error [current]
[ 38.770044] sd 0:0:0:0: [sda] tag#26 Add. Sense: Unrecovered read error - auto reallocate failed
[ 38.770053] sd 0:0:0:0: [sda] tag#26 CDB: Read(10) 28 00 09 3c b1 80 00 01 00 00
[ 38.770059] I/O error, dev sda, sector 154972544 op 0x0:(READ) flags 0x80700 phys_seg 2 prio class 2
[ 38.772518] ata1: EH complete
[ 42.746260] ata1.00: exception Emask 0x0 SAct 0x680006 SErr 0x50000 action 0x0
[ 42.747643] ata1.00: irq_stat 0x40000001
[ 42.748989] ata1: SError: { PHYRdyChg CommWake }
[ 42.750352] ata1.00: failed command: READ FPDMA QUEUED
[ 42.751672] ata1.00: cmd 60/08:08:88:3a:85/00:00:4b:00:00/40 tag 1 ncq dma 4096 in
res 41/40:b0:c0:b0:3c/00:00:09:00:00/40 Emask 0x9 (media error)
[ 42.754385] ata1.00: status: { DRDY ERR }
[ 42.755745] ata1.00: error: { UNC }
[ 42.757071] ata1.00: failed command: READ FPDMA QUEUED
[ 42.758396] ata1.00: cmd 60/08:10:70:ed:20/00:00:72:00:00/40 tag 2 ncq dma 4096 in
[ 42.761102] ata1.00: status: { DRDY ERR }
[ 42.762480] ata1.00: error: { UNC }
[ 42.763839] ata1.00: failed command: READ FPDMA QUEUED
[ 42.765208] ata1.00: cmd 60/08:98:c0:b0:3c/00:00:09:00:00/40 tag 19 ncq dma 4096 in
res 41/40:08:c0:b0:3c/00:00:09:00:00/40 Emask 0x409 (media error) <F>
[ 42.767952] ata1.00: status: { DRDY ERR }
[ 42.769311] ata1.00: error: { UNC }
[ 42.770643] ata1.00: failed command: READ FPDMA QUEUED
[ 42.771960] ata1.00: cmd 60/08:a8:00:08:7c/00:00:07:00:00/40 tag 21 ncq dma 4096 in
[ 42.774748] ata1.00: status: { DRDY ERR }
[ 42.776099] ata1.00: error: { UNC }
[ 42.777445] ata1.00: failed command: WRITE FPDMA QUEUED
[ 42.778761] ata1.00: cmd 61/68:b0:f8:0a:18/00:00:00:00:00/40 tag 22 ncq dma 53248 out
[ 42.781520] ata1.00: status: { DRDY ERR }
[ 42.782893] ata1.00: error: { UNC }
[ 42.794720] ata1: hard resetting link
[ 43.109597] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 43.120405] ata1.00: configured for UDMA/100
[ 43.121960] sd 0:0:0:0: [sda] tag#1 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=4s
[ 43.121970] sd 0:0:0:0: [sda] tag#1 Sense Key : Medium Error [current]
[ 43.121975] sd 0:0:0:0: [sda] tag#1 Add. Sense: Unrecovered read error - auto reallocate failed
[ 43.121982] sd 0:0:0:0: [sda] tag#1 CDB: Read(10) 28 00 4b 85 3a 88 00 00 08 00
[ 43.121985] I/O error, dev sda, sector 1267022472 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 2
[ 43.123397] sd 0:0:0:0: [sda] tag#2 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=4s
[ 43.123403] sd 0:0:0:0: [sda] tag#2 Sense Key : Medium Error [current]
[ 43.123408] sd 0:0:0:0: [sda] tag#2 Add. Sense: Unrecovered read error - auto reallocate failed
[ 43.123412] sd 0:0:0:0: [sda] tag#2 CDB: Read(10) 28 00 72 20 ed 70 00 00 08 00
[ 43.123415] I/O error, dev sda, sector 1914760560 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 2
[ 43.124789] sd 0:0:0:0: [sda] tag#19 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=4s
[ 43.124794] sd 0:0:0:0: [sda] tag#19 Sense Key : Medium Error [current]
[ 43.124798] sd 0:0:0:0: [sda] tag#19 Add. Sense: Unrecovered read error - auto reallocate failed
[ 43.124803] sd 0:0:0:0: [sda] tag#19 CDB: Read(10) 28 00 09 3c b0 c0 00 00 08 00
[ 43.124806] I/O error, dev sda, sector 154972352 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 2
[ 43.126078] sd 0:0:0:0: [sda] tag#21 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=4s
[ 43.126087] sd 0:0:0:0: [sda] tag#21 Sense Key : Medium Error [current]
[ 43.126093] sd 0:0:0:0: [sda] tag#21 Add. Sense: Unrecovered read error - auto reallocate failed
[ 43.126099] sd 0:0:0:0: [sda] tag#21 CDB: Read(10) 28 00 07 7c 08 00 00 00 08 00
[ 43.126103] I/O error, dev sda, sector 125569024 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 2
[ 43.127697] ata1: EH complete
[ 43.128436] Aborting journal on device sda1-8.
[ 47.042131] ata1.00: exception Emask 0x0 SAct 0x4000000 SErr 0x40000 action 0x0
[ 47.043520] ata1.00: irq_stat 0x40000008
[ 47.044875] ata1: SError: { CommWake }
[ 47.046267] ata1.00: failed command: READ FPDMA QUEUED
[ 47.047858] ata1.00: cmd 60/08:d0:c0:b0:3c/00:00:09:00:00/40 tag 26 ncq dma 4096 in
[ 47.050641] ata1.00: status: { DRDY ERR }
[ 47.052099] ata1.00: error: { UNC }
[ 47.063946] ata1: hard resetting link
[ 47.377341] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 47.389549] ata1.00: configured for UDMA/100
[ 47.391124] scsi_io_completion_action: 1 callbacks suppressed
[ 47.391141] sd 0:0:0:0: [sda] tag#26 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=4s
[ 47.391152] sd 0:0:0:0: [sda] tag#26 Sense Key : Medium Error [current]
[ 47.391158] sd 0:0:0:0: [sda] tag#26 Add. Sense: Unrecovered read error - auto reallocate failed
[ 47.391164] sd 0:0:0:0: [sda] tag#26 CDB: Read(10) 28 00 09 3c b0 c0 00 00 08 00
[ 47.391167] blk_print_req_error: 1 callbacks suppressed
[ 47.391170] I/O error, dev sda, sector 154972352 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 2
[ 47.392599] ata1: EH complete
[ 47.750462] EXT4-fs error (device sda1): ext4_journal_check_start:83: comm mariadbd: Detected aborted journal
[ 47.804083] EXT4-fs (sda1): Remounting filesystem read-only
[ 61.570714] EXT4-fs error (device sda1): __ext4_remount:6425: comm mount: Abort forced by user
[ 122.642330] EXT4-fs error (device sda1): __ext4_remount:6425: comm mount: Abort forced by user
[ 797.440974] EXT4-fs error (device sda1): __ext4_remount:6425: comm mount: Abort forced by user
[ 806.901827] EXT4-fs error (device sda1): __ext4_remount:6425: comm mount: Abort forced by user
[ 818.711180] EXT4-fs error (device sda1): __ext4_remount:6425: comm mount: Abort forced by user
[ 909.630035] EXT4-fs error (device sda1): __ext4_remount:6425: comm mount: Abort forced by user
[ 924.288282] EXT4-fs error (device sda1): __ext4_remount:6425: comm mount: Abort forced by user
