8
113816
2 March 2025
Need help about cron job and its capability
17
11
8 April 2025
Kodi 20.5 on RPie5 - Videos won't play and CPU utilisation 100%
11
71
8 April 2025
SD Card crashed - Errors when restoring backup
17
94
7 April 2025
Opi 5 max won't boot
0
14
6 April 2025
Kernel version and kernel headers out of sync after kernel update
4
38
6 April 2025
BT XBOX series X - re-arranged buttons
1
29
5 April 2025
Allow `dietpi` user to remotely stop and start services
2
28
4 April 2025
[Orange Pi Zero 2W] How to enable UART5?
1
39
4 April 2025
How to use dietpi.txt when using dietpi-installer over debian 12 image?
4
37
4 April 2025
Occasionally sites won't load after upgrade from Bullseye to Bookworm (Adguard?)
3
37
4 April 2025
Jellyfin shows more than one server after reinstalling
3
25
4 April 2025
VICE full screen
1
64
3 April 2025
First time Install error
13
53
1 April 2025
[RPi 4B] No 4K resolution after upgrade to v9.10 [SOLVED]
6
103
1 April 2025
Auto removed kernel, am I in trouble?
7
42
1 April 2025
Odroid-C4 no hdmi audio
3
42
31 March 2025
Troubles with installation of HomeAssistant
2
35
31 March 2025
Microphone not working on OrangePi Zero 2w
20
89
31 March 2025
Using DietPi on an external cloud host
5
41
31 March 2025
How to create a DietPi-VM in Pimox7?
12
1766
30 March 2025
Mounting problem (solved)
3
21
30 March 2025
Jellyfin - resest admin password
10
59645
30 March 2025
Migrate from Odroid N2+ to a fresh Raspberry Pi 5
2
28
30 March 2025
Per-app VPN routing?
5
28
29 March 2025
NanoPi NEO3 with DietPi Can I use a LCD2USB?
10
71
29 March 2025
Can't access nextcloud web login page - pihole and unbound installed already
9
36
29 March 2025
Troubles during dietpi-update
7
48
27 March 2025
How to swap DIETPI- Server-(Hardware)
9
81
27 March 2025
Failed to load library: libnspr4.so
2
20
26 March 2025
