First of all OpenVPN is udp/1194, the rest belong to other protocols. But which one are you using?
Also if you are adding multiple ports you should also change the sequence number, as now the first two are overwritten by the third.
VPN out + OpenVPN in
Re: VPN out + OpenVPN in
Ok thank you. I tried at the beginning only with 1194 but ot didn't connect so I added the other two which I thought they were also needed for Openvpn.
I am using the default installer from dietpi for Openvpn slño if 1194 UDP is enough i can leave the first one only.
Still it doesn't get through
You can verify the port with
Other than that post the following:
ss -tunlp | grep vpn
ip -4 addr; ip -4 ro list table all; ip -4 ru
The fist command has no return, the second gives a lot of information
Not related, but I also have realised that thr no-ip ddns script is updating to the wrong ip even when I mark eth0 as the interface for updating.
dietpi@DietPi:~$ ss -tunlp | grep vpn
dietpi@DietPi:~$ ip -4 addr; ip -4 ro list table all; ip -4 ru
inet 192.168.31.254/24 brd 192.168.31.255 scope global eth0
5: tun0: <POINTOPOINT,MULTICAST,NOARP,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UNKNOWN group default qlen 100
inet 10.8.0.1 peer 10.8.0.2/32 scope global tun0
6: tun1: <POINTOPOINT,MULTICAST,NOARP,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UNKNOWN group default qlen 100
inet 10.121.34.39/23 brd 10.121.35.255 scope global tun1
default via 192.168.31.1 dev eth0 table 100
0.0.0.0/1 via 10.121.34.1 dev tun1
default via 192.168.31.1 dev eth0 onlink
10.8.0.0/24 via 10.8.0.2 dev tun0
10.8.0.2 dev tun0 proto kernel scope link src 10.8.0.1
10.121.34.0/23 dev tun1 proto kernel scope link src 10.121.34.39
37.120.136.243 via 192.168.31.1 dev eth0
128.0.0.0/1 via 10.121.34.1 dev tun1
192.168.31.0/24 dev eth0 proto kernel scope link src 192.168.31.254
local 10.8.0.1 dev tun0 table local proto kernel scope host src 10.8.0.1
broadcast 10.121.34.0 dev tun1 table local proto kernel scope link src 10.121.34.39
local 10.121.34.39 dev tun1 table local proto kernel scope host src 10.121.34.39
broadcast 10.121.35.255 dev tun1 table local proto kernel scope link src 10.121.34.39
broadcast 127.0.0.0 dev lo table local proto kernel scope link src 127.0.0.1
broadcast 192.168.31.0 dev eth0 table local proto kernel scope link src 192.168.31.254
local 192.168.31.254 dev eth0 table local proto kernel scope host src 192.168.31.254
broadcast 192.168.31.255 dev eth0 table local proto kernel scope link src 192.168.31.254
0: from all lookup local
16010: from all sport 1194 lookup 100
32766: from all lookup main
32767: from all lookup default
What about this?
grep port /etc/openvpn/*
grep: /etc/openvpn/client: Is a directory
grep: /etc/openvpn/easy-rsa: Is a directory
grep: /etc/openvpn/server: Is a directory
/etc/openvpn/server.conf:port 1194
netstat -putan | grep 1194
udp 0 0 0.0.0.0:1194 0.0.0.0:* 1240/openvpn
netstat is not included in dietpi and is deprecated, ss is the successor. Anyway, we have established the openvpn server is running on udp/1194
Install tcpdump if you don't have it already and run:
Then try to connect from the client, let it capture a few packets, stop with Ctrl-c and paste here the output.
sudo tcpdump -i eth0 -evn udp port 1194
Probably it's required to add "dev eth0" to the ip route, to force it using the right device as well.
It doesn't hurt to add it, however the dietpi shouldn't have any issues finding the 192.168.31.1 as it is directly connected to the eth0.
Where should I add the dev flag? What other things I can do?
