Rock5a Fan control
  • DietPi version :
    G_DIETPI_VERSION_CORE=9
    G_DIETPI_VERSION_SUB=14
    G_DIETPI_VERSION_RC=2
  • Distro version : bookworm
  • Kernel version : Linux Rock5A 6.1.115-vendor-rk35xx #1 SMP Tue Jun 3 13:10:51 UTC 2025 aarch64 GNU/Linux
  • Architecture : arm64
  • SBC model : ROCK 5A (aarch64)
  • Power supply used : 5V 3A
  • SD card used : M2 256Go
actually we have high temperature. I have more than 50° on my Rock 5a
I would like to spped up my fan which is connected on the dedicated connector on the board
I tried different command but nothing change. I install dietpi fan control but no changes.
Do you have an idea to increase the speed?
regards,
Jordi
Here is a way: [Guide] How to make the Rock 5b fan work properly - Joshua Riek's Ubuntu 24.04 - 5B/5B+ - Radxa Community
Just adjust the folders to dietpi and apply the overlay as you would on dietpi.
hello,
thx for your answer but i have an issue at step 2 with the command dtc -O dtb -o fanctrl-my.dtbo fanctrl-my.dts
I continue to search :slight_smile:
What is your issue with this command? You provided no information about how it fails. Have you installed dtc?
dtc: command not found
I’m looking for to install it :slight_smile:
Google helps. How to install dtc.
