Help with Chromium autostart
  • DietPi version | cat /boot/dietpi/.version - G_DIETPI_VERSION_CORE=9
    G_DIETPI_VERSION_SUB=14
    G_DIETPI_VERSION_RC=2
  • Distro version | echo $G_DISTRO_NAME $G_RASPBIAN - bookworm 0
  • Kernel version | uname --all - Linux DietPi 6.12.25+rpt-rpi-2712 #1 SMP PREEMPT Debian 1:6.12.25-1+rpt1 (2025-04-30) aarch64 GNU/Linux
  • Architecture | dpkg --print-architecture - arm64
  • SBC model | echo $G_HW_MODEL_NAME or (EG: RPi3) - RPi 5 Model B (aarch64)
  • Power supply used | (EG: 5V 1A RAVpower) Geeek Pi 5V 3.6A
  • SD card used | (EG: SanDisk ultra) Kingston 32GB
  • Was the software title installed freshly or updated/migrated? - Freshly installed
  • Can this issue be replicated on a fresh installation of DietPi? - Yes
  1. Set Chromium to autostart through ‘dietpi-autostart’
  2. Change default URL to https://meet.google.com
  3. Sign in
  4. Join/attempt to join any meeting
  • It should pop-up with prompts to allow camera access etc.,
  • It should also show the video call UI with buttons for hanging up etc.
  • Launches black screen with no call UI and no pop-ups to enable access to camera or microphone
For context, I’m looking for this device to boot directly to a chromium window and Google meet in order for it to be used as a video conferencing device in my office
It launches to Google meet fine, but there is no video call functionality whatsoever - I imagine there are prerequisite packages missing that I need to install and possibly settings that need changing but I’m very much a hobbyist and don’t have the skillset to troubleshoot an issue like this
You probably need to go to dietpi-autostart and select option 17 for foreground with autologin.
Then add the command to bring up the browser with the Meet url in app mode.
chromium --app=https://meet.google.com
As for the missing video calls, are you certain that you have logged in to the chromium? I don’t use any plug-ins whatsoever and I have the functionality there.
You may solve the issue with missing calls in a normal chromium window and when you are done you may add it in the startup script.
Thanks for your help! I’m just trying this now, what else do I need to include in the autostart script other than what you mentioned above?
I think that should be all.
