Qbittorrent won't download to mounted USB drive.
Re: Qbittorrent won't download to mounted USB drive.
usually previous permissions should have been working. Let's try to adjust as follow
chown -R qbittorrent:dietpi /mnt/torrent
chmod -R 775 /mnt/torrent
Previously with 760 mode, execute permissions for the group were missing, required to allow reading a directories content, so 770 is the minimum when using dietpi:dietpi ownership. The qbittorrent user btw has dietpi as it's major group, so that it creates files with this group as well, assuring R/W access for media applications that are members of the dietpi group as well.
That is the case with most download services, including Sonarr/Radarr/Lidarr, so all cases where often other daemons want to import those downloads.
scheiner
Post by scheiner »
Did a new/fresh install of dietpi wirh qBittorrent.
Installed and formated (EXT4) a new USB drive for downloads. Successfully mounted as /mnt/download
As expected qBittorrent not working. Log shows :
(N) 2021-04-02T13:19:06 - An I/O error occurred, 'Album' paused. Album.flac) error: Permission denied
dietpi@DietPi:/mnt$ cd download/
dietpi@DietPi:/mnt/download$ ls -la
total 2
drwxr-xr-x 3 root root  4096 Apr  2 13:16 .
drwxr-xr-x 7 root root  4096 Apr  2 13:17 ..
drwx------ 2 root root 16384 Apr  2 13:16 lost+found
would like to make a step by step to fix this permission problem (chmod, chown etc).
Any ideas ?
Please see and apply the two commands suggested by Joulinar above already ;): #p30557
scheiner
Post by scheiner »
Just did. bitTorrent now starts fine and download procceed.
however i'm having a weid situation. after a few minutes when try to look the folder .. it returns this
ls: reading directory '.': Input/output error
total 0
and then when I launch drive-manager .... the mount shows it's filesystem as "Filesystem: Net" and not Ext4 as before.
the USB drive still there (plugged in)
dietpi@DietPi:/mnt/download$ df -h
udev            168M     0  168M   0% /dev
tmpfs            48M  4.4M   44M  10% /run
/dev/mmcblk0p1   15G  2.2G   13G  16% /
tmpfs           238M     0  238M   0% /dev/shm
tmpfs           5.0M     0  5.0M   0% /run/lock
tmpfs           238M     0  238M   0% /sys/fs/cgroup
tmpfs           1.0G     0  1.0G   0% /tmp
tmpfs            50M   32K   50M   1% /var/log
/dev/sda1       293G  4.6G  288G   2% /mnt/download
trendy
Post by trendy »
Can you check the health of the hard drive? I/O errors out of the blue are usually due to hardware failure.
scheiner
Post by scheiner »
The hard drive is ok. the problem was the dock station. Problem solved. Thank you.
ekonomstudenten
Post by ekonomstudenten »
scheiner wrote: Sat Apr 03, 2021 2:30 am The hard drive is ok. the problem was the dock station. Problem solved. Thank you.
I'm having the exact same problem. The drive starts out fine, but after using for a while qBittorrent stops downloading and drive manager reports the file system as 'net'. What was the issue with the dock station? I'm using a 4TB drive with an USB 3.0 enclosure, and I'd love to know what you did to fix the problem. Both the drive and the dock are brand new.
scheiner
Post by scheiner »
I was using my dock with a wrong power supply. Not providing enough power.
ekonomstudenten
scheiner wrote: Mon Apr 05, 2021 1:31 am I was using my dock with a wrong power supply. Not providing enough power.
Hm, okay. I'm pretty sure that I'm having another issue then, since I'm using the supplied power adaptor.
