How prepare the transition/upgrade from Buster to next version? Topic is solved
mail2rst
Re: How prepare the transition/upgrade from Buster to next version?
Post by mail2rst »
i have followed the above procedure to migrate from buster to bullseye. all of my system works on bullseye. I think with this command
sed -i 's/bullseye/buster/' /etc/apt/sources.list.d/*mosquitto*.list
we override the buster image off mqtt broker on bullseye system. as now bullseye component available for mqtt broker so we have to correct this command so that system will pick bullseye file.
basically just change the command and switch buster <> bullseye
sed -i 's/buster/bullseye/' /etc/apt/sources.list.d/*mosquitto*.list
apt update
apt upgrade
but it should be same version of mosquitto. They just added Bullseye repository without changes on mosquitto themselves
mail2rst
Post by mail2rst »
Thanks,
gasto
Post by gasto »
Hey guys, one of my Dietpi images is currently running on an Orange Pi Zero SBC (I followed these steps: https://github.com/MichaIng/DietPi/issu ... -280771944), but I'm not sure if the upgrade from Buster to Bullseye is supported on that board.
I wanted to check with you just in case if the guide on the blog (https://dietpi.com/blog/?p=811) would work for manually upgrading the system before doing anything.
Thanks as usual!
usually the guide should work same as it is not specified for specific devices. However we are not able to test the process on all SBC available. Therefore we recommend to do a full backup of the system before. Best would be to clone the SD card.
gasto
Post by gasto »
Got it, I'll try then. Thanks Joulinar ;)
