DietPi version | G_DIETPI_VERSION_CORE=9 G_DIETPI_VERSION_SUB=3 G_DIETPI_VERSION_RC=0 G_GITBRANCH='master' G_GITOWNER='MichaIng'
Distro version | bookworm
Kernel version | Linux DietPi 6.1.63-current-sunxi #1 SMP Mon Nov 20 10:52:19 UTC 2023 armv7l GNU/Linux
Architecture | armhf
SBC model | Generic Allwinner H3 (armv7l) or orange pi zero lts
Power supply used | 5V 2.1A RAVpower
SD card used | EG: SanDisk ultra 32G
ı was set apt to auto upgrade
when ı was decided to use ffmpeg it didnt work
apt install ffmpeg
ffmpeg -version
[DietPi ~]# ffmpeg -version
ffmpeg: error while loading shared libraries: liblapack.so.3: cannot open shared object file: No such file or directory
ı downloaded libapack.so.3 using apt and its just downloaded libapack.so
ı need ffmpeg for hw encoding
Do you mean you did apt install liblapack3 ?
yep ı already did
Reading package lists… Done
Building dependency tree… Done
Reading state information… Done
liblapack3 is already the newest version (3.11.0-2). liblapack3 set to manually installed. 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. [DietPi Youtube]# ffmpeg ffmpeg: error while loading shared libraries: liblapack.so.3: cannot open shared object file: No such file or directory
can you check if files are present
find / -name "liblapack.so.3"
find / -name "liblapack.so.3" output
/usr/lib/arm-linux-gnueabihf/lapack/liblapack.so.3
/mnt/3da1b760-1c89-42a4-83c3-fc36790e409b/dietpi-backup/data/usr/lib/arm-linux-gnueabihf/lapack/liblapack.so.3
/mnt/3da1b760-1c89-42a4-83c3-fc36790e409b/dietpi_userdata/docker-data/overlay2/e61831f812dca27279ab8c1f236fcbcf97b2e82445584729e89aef82f6475016/diff/usr/lib/arm-linux-gnueabihf/liblapack.so.3
/mnt/3da1b760-1c89-42a4-83c3-fc36790e409b/dietpi_userdata/docker-data/overlay2/e61831f812dca27279ab8c1f236fcbcf97b2e82445584729e89aef82f6475016/diff/usr/lib/arm-linux-gnueabihf/lapack/liblapack.so.3
/mnt/dietpi_userdata/docker-data/overlay2/e61831f812dca27279ab8c1f236fcbcf97b2e82445584729e89aef82f6475016/diff/usr/lib/arm-linux-gnueabihf/lapack/liblapack.so.3
/mnt/dietpi_userdata/docker-data/overlay2/e61831f812dca27279ab8c1f236fcbcf97b2e82445584729e89aef82f6475016/diff/usr/lib/arm-linux-gnueabihf/liblapack.so.3
ı change ld.so.config file
cat /etc/ld.so.conf
include /etc/ld.so.conf.d/*.conf
and
loaded config
ldconfig
fixed problem
system
Closed
2 August 2024 10:07
6
