sorry, I switched to DietPi v6.33.0 (beta) : 23:56 - Mi 07.10.2020 and Baikal was not updated:
Version
This systems runs Baïkal 0.6.1
http://sabre.io/baikal
New version available: 0.7.1
What do I have to do?
Many thanks and friendly greetings.
Please update Baikal
Re: Please update Baikal
You need to run the re-installation as indicated in one of the first post.
But keep in mind that there is still the issue within Baikal themselves, leading to an empty config file after running the update.
dietpi-software reinstall 57
@Joulinar :
After upgrading to 0.7.1 Baikal throws an error:
The constant PROJECT_DB_MYSQL_HOST, containing the MySQL host name, is not set.
You should set it in config/baikal.yaml
I will still do this as described here:
https://web.nettworks.org/wiki/pages/vi ... d=37421142
and I'll get back to you on this.
Thank you very much.
yes that's as expected because of the Baikal issue. There we need to wait on Baikal to have it fixed. Basically you need to fill your database information into Baikal config file now.
@Joulinar:
If I'm annoying, you hit me!
I have entered the required data into the baikal.yaml, now the following error occurs:
Baïkal was not able to establish a connexion to the configured MySQL database (as configured in config/baikal.yaml).
Only good that there is a dietpi-backup! DietPi is a really great piece of software!
Thanks and many greetings.
Edit:
I successfully restored my Dietpi machine from a backup.
Edit:
ok, but you could have tried to reboot first. Maybe it would have changed something
I hope Baikal will fix this issue soon to ensure smooth upgrade from 0.6 > 0.7
@Joulinar:
after update to DietPi v6.33.1,
executed the entries in the config/baikal.yaml
reboot
unfortunately no change, the same error as before.
I successfully performed the restore of DietPi and will probably have to wait for the developers of Baikal to fix the bug.
Many friendly greetings.
reboot
yes unfortunately, this is still pending on Baikal side
Just for reference to track the solution on Baikal side:
GitHub issue: https://github.com/sabre-io/Baikal/issues/946
Pull request that should solve it: https://github.com/sabre-io/Baikal/pull/979
Feel free to report to any of those two draw some attention and hopefully speed up things a bid
@Joulinar:
Hurray, I made the update with your help!
I first ran the update Baikal from 0.6.1 to Baikal 0.7.0, then dietpi-software reinstall 57, then reboot.
Now Baikal offered me an update routine to 0.7.1, which I also ran.
The result is the following:
About this system
Version
These systems runs Baïkal 0.7.1
Many thanks to all of you here who supported me!
Friendly greetings.
About this system
Version
Friendly greetings.
