8
114010
2 March 2025
Linux-image-amd64 - The following packages have been kept back
1
5
3 July 2025
Home Assistant causing dietpi to hung
21
104
3 July 2025
MEGAcmd on DietPi
4
22
3 July 2025
(Beelink) AMD AI9HX370 wrong temperature with cpu command (htop is OK)
4
15
2 July 2025
No static Mac address since v9.7.1
40
393
2 July 2025
Home Assistant Launch Error [cannot import name OrPattern]
4
25
2 July 2025
DietPi on BananaPi M5 bootdelay when headless
12
123
2 July 2025
Auto setup for headless installation fails to start
7
19
2 July 2025
ROCK(Pro)64 won't boot with Linux 6.12
41
489
1 July 2025
Laptop installer not detecting HDD
1
14
1 July 2025
UPMPDCLI instllation
2
23
1 July 2025
Randomly can't SSH into my DietPi install but can ping
3
27
1 July 2025
ACPI - What would be the best way to install it?
11
43
30 June 2025
Sd card to SSD migration on Raspberrypi4. (rpi-clone or..?)
1
18
30 June 2025
Raspberry PI 4 Argon One M.2 case, M.2 SSD inaccessible after a random amount of time
11
62
30 June 2025
Rock5a Fan control
1
17
29 June 2025
Moonlight removed from Software list?
8
60
29 June 2025
No autostart to Desktop as user
17
96
29 June 2025
RPI Zero v1 Fails boot with over_voltage=-2 -200mV energy savings setting in dietpi-config
0
12
27 June 2025
How to Connect to a Samba Server
8
85
27 June 2025
No sound card detected for Opi zero 2w
127
2364
27 June 2025
Debian 12 ARM64 on Apple Silicon with UTM converted to DietPi - Fails
6
221
27 June 2025
Unbound dietpi.conf - do we need module-config line?
2
28
27 June 2025
How to backup an entire SD Card over a network
3
56
27 June 2025
Help with Chromium autostart
4
34
27 June 2025
AdguardHome + Unbound unstable connections and cannot load websites sometimes
59
346
25 June 2025
Failed to start systemd-timesyncd.service error during update attempt
7
38
25 June 2025
No download for older Dietpi Versions available!
1
34
25 June 2025
Home Assistant : Obsolescence notice
1
36
25 June 2025
