Roger, I'm actually not even caring about any chunk size error anymore, I just wish I stopped tinkering even if it gives me errors. At this point I can't even get into the site because of something I did with redis and permissions ;
i believe the culprit is "usermode -a -G redis www-data" a tip I found on a site and I don't know what impact it had on what I"m facing right now
Hi Joulinar , still working at it . do you think the redis-server might be causing loops?
I think this might be it, working on trying to figure this out. any help thanks
Jul 09 09:13:21 DietPi redis[586]: Could not create serv
er TCP listening socket ::1:6379: bind: Cannot assign requested address
Jul 09 09:13:21 DietPi redis[586]: Warning: 32 bit insta
nce detected but no memory limit set. Setting 3 GB maxmemory limit with 'noevict
ion' policy now.
Jul 09 09:13:21 DietPi systemd[1]: redis-server.service: Can't open PID file /ru
n/redis/redis-server.pid (yet?) after start: No such file or directory
honestly I'm not sure that this is related to redis. I did a test with lighttpd as web server, and I was able to upload a file of 1.2GB without issues. I guess it's more related to nginx as web server an some time out parameter
HI joul.
I just run Nextcloud, NGINX, PHP, REDIS, etc.. + one of the desktop environ + Real VNC .
I have pretty much returned back to working state almost. I haven't been able to try if the lock testing is gone (I think Redis works fine now)
The only errors I am encountering now are nextcloud related:
Error PHP Undefined index: debugMode at /var/www/nextcloud/core/templates/exception.php#26
Error PHP Undefined index: debugMode at /var/www/nextcloud/core/templates/exception.php#17
Fatal webdav OCP\Files\NotPermittedException: Could not create path
