Ok, I fixed this one !
my asound.conf is referring to /home/pi/.alsaequal.bin
And as per your recommendation I did every steps as root, so, of course I don't have /home/pi
I changed the directory to root et voilà !
Oh, and I forgot to mention, that this time I choose Jessie as this is the one I had working with the regular Raspbian.
(resolved) asound.conf for alsaequal
Re: asound.conf for alsaequal
It looks like I was too optimistic...
I have moded my asound.conf as per previous post
And this ok but, still cant make squeezelite working with my asound.conf
Squeezelite work by itself but not with my plugins
root@DietPi:~# /usr/bin/squeezelite-armv6hf -o equal
Failed to open controls file:/home/pi/.alsaequal.bin.
[18:58:28.483271] test_open:124 playback open error: Operation not permitted
[18:58:28.483675] output_init_common:373 unable to open output device
This time I don't know what to do ???
Thank you Dan and anybody for any idea...
Whatever the result here my offer for a free I2S sound card is still valid Dan !
Ok, now it works, I'm probably too old, I had to modify the directory at two different lines.
So this threads close here !
Don't loose your time with this anymore Dan !
And don't forget to send a mail should you want me to send you an I2S sound card.
Best regards,
Jean
Best regards,
Jean
Just a quick reply before heading off for the nightbricolodu13 wrote:It looks like I was too optimistic...
You need to change the following in /etc/asound.conf:
to
/root/.alsaequal.bin
I'am out of time for today, but I will run the tests at my end tomorrow and get back to you. And thanks for the continued offer, appreciate it.
Haha, i just posted, but you beat me to it. Great to hear its working. Let me know if you have further issues. Thanks Jean for the offer, i'll be in touchbricolodu13 wrote:Ok, now it works, I'm probably too old, I had to modify the directory at two different lines.
Best regards,
Jean
