4
112407
29 October 2023
[Tutorial] Editing DitePi Terminal Banner
13
19765
18 May 2024
How to create a DietPi-VM in Pimox7?
8
1340
18 May 2024
Mainline Linux/Debian for NanoPi R5S/C
59
2317
18 May 2024
No sound card detected for Opi zero 2w
2
18
18 May 2024
NextCloud Update to 27.1.9 fails - create backup failed
1
55
18 May 2024
Shairport-Sync not Airplay2
3
22
18 May 2024
Qbittorrent ssl setup
4
24
18 May 2024
[NGINX] Redirect homepage to different route
1
17
18 May 2024
Raspberry Pi plans to go public (IPO) - thoughts on alternative SBC providers?
4
62
17 May 2024
Reverse proxy for qBittorrent
1
198
17 May 2024
Nginx reverse proxy... how?
3
93
17 May 2024
Orange Pi 5B doesn't detect/show eMMC
2
31
17 May 2024
About Rock 5C support
2
36
17 May 2024
Info Post: Rockchip MPP with Jellyfin / FFMPEG is working and is great
3
1052
16 May 2024
52
601
16 May 2024
Try to install my Brother HL-3140CW led printer with CUPS
0
28
16 May 2024
Sysfs to control GPIO depracted -> Alternatives?
19
110
13 May 2024
Set a NEW User Data directory and SKIP move the data from the privious path
0
26
16 May 2024
Owncloud not reachable anymore
58
392
16 May 2024
Orange Pi zero 2W - enable GPU
1
47
15 May 2024
CPU freq stuck at 1400Mhz
4
44
15 May 2024
Kodi screenshot folder
1
35
15 May 2024
Orange Pi 3 LTS screen flashes on and off
0
30
14 May 2024
NanoPC-T6 Image (Single Partition) Kernel Upgrade
27
149
14 May 2024
Best way to install or replace LXDE with FVWM?
0
40
13 May 2024
DietPi: Headless install on Raspberry Pi 5 NVME drive?
2
82
13 May 2024
App nextcloud iOS: browser is not supported
23
176
13 May 2024
Kodi screen resolution bug after update
0
49
13 May 2024
RPI zero 2 boot looping after "apt install ...", ARMv6-Bookworm (downloaded 20240512)
0
58
13 May 2024
