8
113758
2 March 2025
Radxa Zero 3e | eth0 briding not working
2
5
14 March 2025
Letsencrypt Auto renewal fails - Error getting validation data
36
3710
14 March 2025
Adguard Terminal Edition
0
11
13 March 2025
LED on PiZero 2 w flashing on a regular cadence
4
21
13 March 2025
Paperless NGX scanned document management software
15
3215
13 March 2025
Enable TV Out in Orange Pi Zero 2W
0
13
13 March 2025
Self signed certificate for PiHole v6 does not work after Bookworm upgrade
18
46
13 March 2025
Troubleshooting DietPI from bootable USB
3
19
13 March 2025
WebDAV uploads to nginx/Nextcloud result in 0 bytes
0
6
13 March 2025
Rock64 - sudden default route loss
4
25
12 March 2025
Unable to mount an Audio CD - DVDs OK, using dietpi-drive_manager
2
30
3 March 2025
Cronjob + unwanted reboot
10
73
12 March 2025
Help with SSH issue
0
19
12 March 2025
Cyberghost VPN
29
1722
12 March 2025
Only a little slow
8
74
12 March 2025
Just setup a Pi 5 with active cooler but the fan isn't being turned on
0
17
11 March 2025
Boot fail from usb/ssd on odroid c4
11
1487
11 March 2025
How does DietPi install software
2
46
11 March 2025
Reducing Fan noise?
3
40
11 March 2025
Wondering could restillo sync be added to software list
1
15
11 March 2025
Plexamp Fails to Load as Startup Service
13
1920
11 March 2025
Port forwarding in dietpi Raspberry 4
5
51
11 March 2025
Would an Intel NUC 5i5RYH be supported on bare metal?
2
16
11 March 2025
Radxa Zero 3W ST7735S Display Connection Issue
0
8
11 March 2025
Failed to install Unbound from Dietpi-software
11
40
10 March 2025
Transferring dietpi to new/different hardware?
7
767
10 March 2025
OMPD config edit issue
13
46
10 March 2025
NanoPi R5S Graphis/GUI issues - Help!
22
216
9 March 2025
Random lock-ups Nanopi Neo 3
4
50
8 March 2025
