4
112352
29 October 2023
CPU freq stuck at 1400Mhz
4
24
15 May 2024
Kodi screenshot folder
1
19
15 May 2024
Orange Pi zero 2W - enable GPU
0
17
14 May 2024
Orange Pi 3 LTS screen flashes on and off
0
15
14 May 2024
51
524
14 May 2024
NextCloud Update to 27.1.9 fails - create backup failed
0
33
13 May 2024
Owncloud not reachable anymore
57
369
14 May 2024
NanoPC-T6 Image (Single Partition) Kernel Upgrade
27
131
14 May 2024
Best way to install or replace LXDE with FVWM?
0
30
13 May 2024
DietPi: Headless install on Raspberry Pi 5 NVME drive?
2
61
13 May 2024
Sysfs to control GPIO depracted -> Alternatives?
19
80
13 May 2024
App nextcloud iOS: browser is not supported
23
165
13 May 2024
Kodi screen resolution bug after update
0
43
13 May 2024
RPI zero 2 boot looping after "apt install ...", ARMv6-Bookworm (downloaded 20240512)
0
41
13 May 2024
NanoPi R2S Plus
29
656
13 May 2024
RPI5 - QBittorrent portforward on reboot
0
30
13 May 2024
Open Beta v9.4 | Please help testing and hardening our upcoming release
3
95
12 May 2024
Zigbee2MQTT and Home Assistant
4
150
12 May 2024
How to set custom library location for navidrome
12
41
12 May 2024
NordVPN Update Breaks Local Network Access
0
31
12 May 2024
DietPi, Autolaunching SH program on boot
0
27
12 May 2024
Maintain date modified over SMB share
0
29
12 May 2024
Odroid XU4 | Cloudshell 2 not working after Upgrade
72
1895
12 May 2024
[SOLVED] How to install vlc? no DE, just console.
4
2811
11 May 2024
Network state filling up terminal
8
1658
11 May 2024
Create a hotspot when no Access Point available
4
387
11 May 2024
Certbot error on renewal "Unsupported RSA key length: 1024"
4
78
11 May 2024
Latest update broke boot
4
60
11 May 2024
Iam unable to make navidrome scan my external ssd
10
628
11 May 2024
