Lighttpd SSL failures after upgrade from Buster to Bullseye Topic is solved
Re: Lighttpd SSL failures after upgrade from Buster to Bullseye
are you able to access your DDNS address like https://your.ddnss.com without using /nextcloud sub path?
przemko
Post by przemko »
Yes I that placeholder page:
You should replace this page with your own web pages as soon as possible.
Unless you changed its configuration, your new server is configured as follows:
Configuration files can be found in /etc/lighttpd. Please read /etc/lighttpd/conf-available/README file.
The DocumentRoot, which is the directory under which all your HTML files should exist, is set to /var/www/html.
CGI scripts are looked for in /usr/lib/cgi-bin, which is where Debian packages will place their scripts. You can enable cgi module by using command "lighty-enable-mod cgi".
Log files are placed in /var/log/lighttpd, and will be rotated weekly. The frequency of rotation can be easily changed by editing /etc/logrotate.d/lighttpd.
The default directory index is index.html, meaning that requests for a directory /foo/bar/ will give the contents of the file /var/www/html/foo/bar/index.html if it exists (assuming that /var/www/html is your DocumentRoot).
You can enable user directories by using command "lighty-enable-mod userdir"
About this page
This is a placeholder page installed by the Debian release of the Lighttpd server package.
This computer has installed the Debian GNU/Linux operating system, but it has nothing to do with the Debian Project. Please do not contact the Debian Project about it.
If you find a bug in this Lighttpd package, or in Lighttpd itself, please file a bug report on it. Instructions on doing this, and the list of known bugs of this package, can be found in the Debian Bug Tracking System.
My emby server works fine on that ddns.net address.
Regards.
ok if you are able to see the placeholder page using HTTPS, all working fine on Lighttpd and SSL certificates side.
przemko
Post by przemko »
So do You have any ideas what may be wrong? Maybe move to upper version of php?
Regards.
what is your exact issue now?
przemko
Post by przemko »
My Nextcloud don't work. On Https I have
503 Service Unavailable
and on http
...ERR_CONNECTION_REFUSED
like no internet page.
is the access working using http://ip/nextcloud ?
przemko
Post by przemko »
No, I have that page like when there's no internet. As I say above
This site is unreachableServer 192.168.0.24 has rejected the connection.
Try these solutions:
Check the connection
Check your proxy server and firewall
issue is with nextcloud and not with web server. Could you you try to reboot and check if there are error messages inside the nextcloud.log file
cat /mnt/dietpi_userdata/nextcloud_data/nextcloud.log
Don't get confused, the output could be cryptic (if something is logged)
przemko
Post by przemko »
I reboot few times and log is always very, very long [55,9MB]. At the end I see something like this:
{"reqId":"8t1Be8cvrQgMzsdO0hWA","level":3,"time":"2021-01-15T19:10:06+00:00","remoteAddr":"","user":"--","app":"files_antivirus","method":"","url":"--","message":{"Exception":"RuntimeException","Message":"The antivirus executable could not be found at /usr/bin/clamscan","Code":0,"Trace":[{"function":"__construct","class":"OCA\\Files_Antivirus\\Scanner\\LocalClam","type":"->","args":[{"__class__":"OCA\\Files_Antivirus\\AppConfig"},{"__class__":"OC\\AppFramework\\Logger"},{"__class__":"OCA\\Files_Antivirus\\StatusFactory"}]},{"file":"/var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php","line":84,"function":"newInstanceArgs","class":"ReflectionClass","type":"->","args":[[{"__class__":"OCA\\Files_Antivirus\\AppConfig"},{"__class__":"OC\\AppFramework\\Logger"},{"__class__":"OCA\\Files_Antivirus\\StatusFactory"}]]},{"file":"/var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php","line":101,"function":"buildClass","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":[{"name":"OCA\\Files_Antivirus\\Scanner\\LocalClam","__class__":"ReflectionClass"}]},{"file":"/var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php","line":116,"function":"resolve","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["OCA\\Files_Antivirus\\Scanner\\LocalClam"]},{"file":"/var/www/nextcloud/lib/private/AppFramework/DependencyInjection/DIContainer.php","line":414,"function":"query","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["OCA\\Files_Antivirus\\Scanner\\LocalClam"]},{"file":"/var/www/nextcloud/lib/private/ServerContainer.php","line":133,"function":"queryNoFallback","class":"OC\\AppFramework\\DependencyInjection\\DIContainer","type":"->","args":["OCA\\Files_Antivirus\\Scanner\\LocalClam"]},{"file":"/var/www/nextcloud/apps/files_antivirus/lib/Scanner/ScannerFactory.php","line":45,"function":"query","class":"OC\\ServerContainer","type":"->","args":["OCA\\Files_Antivirus\\Scanner\\LocalClam"]},{"file":"/var/www/nextcloud/apps/files_antivirus/lib/BackgroundJob/BackgroundScanner.php","line":334,"function":"getScanner","class":"OCA\\Files_Antivirus\\Scanner\\ScannerFactory","type":"->","args":[]},{"file":"/var/www/nextcloud/apps/files_antivirus/lib/BackgroundJob/BackgroundScanner.php","line":121,"function":"scanOneFile","class":"OCA\\Files_Antivirus\\BackgroundJob\\BackgroundScanner","type":"->","args":[{"__class__":"OC\\Files\\Node\\File"}]},{"file":"/var/www/nextcloud/lib/private/BackgroundJob/Job.php","line":62,"function":"run","class":"OCA\\Files_Antivirus\\BackgroundJob\\BackgroundScanner","type":"->","args":[null]},{"file":"/var/www/nextcloud/lib/private/BackgroundJob/TimedJob.php","line":57,"function":"execute","class":"OC\\BackgroundJob\\Job","type":"->","args":[{"__class__":"OC\\BackgroundJob\\JobList"},{"__class__":"OC\\Log"}]},{"file":"/var/www/nextcloud/cron.php","line":126,"function":"execute","class":"OC\\BackgroundJob\\TimedJob","type":"->","args":[{"__class__":"OC\\BackgroundJob\\JobList"},{"__class__":"OC\\Log"}]}],"File":"/var/www/nextcloud/apps/files_antivirus/lib/Scanner/LocalClam.php","Line":43,"CustomMessage":"--"},"userAgent":"--","version":"19.0.5.2"}
{"reqId":"8t1Be8cvrQgMzsdO0hWA","level":3,"time":"2021-01-15T19:10:06+00:00","remoteAddr":"","user":"--","app":"files_antivirus","method":"","url":"--","message":{"Exception":"RuntimeException","Message":"The antivirus executable could not be found at /usr/bin/clamscan","Code":0,"Trace":[{"function":"__construct","class":"OCA\\Files_Antivirus\\Scanner\\LocalClam","type":"->","args":[{"__class__":"OCA\\Files_Antivirus\\AppConfig"},{"__class__":"OC\\AppFramework\\Logger"},{"__class__":"OCA\\Files_Antivirus\\StatusFactory"}]},{"file":"/var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php","line":84,"function":"newInstanceArgs","class":"ReflectionClass","type":"->","args":[[{"__class__":"OCA\\Files_Antivirus\\AppConfig"},{"__class__":"OC\\AppFramework\\Logger"},{"__class__":"OCA\\Files_Antivirus\\StatusFactory"}]]},{"file":"/var/www/nextcloud/lib/pr^C
