Upgrade to Bullseye apt upgrade errors Topic is solved
jetspeed
Re: Upgrade to Bullseye apt upgrade errors
Post by jetspeed »
Here's the result. Let me know if there is anything else. I intend to restore from the SD card soon.
root@DietPi:~# apt install pax-utils
Reading package lists... Done
Building dependency tree
Suggested packages:
  paxctl
  pax-utils
Need to get 71.0 kB of archives.
After this operation, 223 kB of additional disk space will be used.
Get:1 http://mirror.aarnet.edu.au/pub/raspbian/raspbian buster/main armhf pax-utils armhf 1.2.4-1 [71.0 kB]
Fetched 71.0 kB in 1s (66.0 kB/s)
Selecting previously unselected package pax-utils.
(Reading database ... 32092 files and directories currently installed.)
Preparing to unpack .../pax-utils_1.2.4-1_armhf.deb ...
Unpacking pax-utils (1.2.4-1) ...
Setting up pax-utils (1.2.4-1) ...
root@DietPi:~# lddtree /usr/bin/curl
curl => /usr/bin/curl (interpreter => /lib/ld-linux-armhf.so.3)
    libcurl.so.4 => /usr/lib/arm-linux-gnueabihf/libcurl.so.4
        libnghttp2.so.14 => /usr/lib/arm-linux-gnueabihf/libnghttp2.so.14
        libidn2.so.0 => /usr/lib/arm-linux-gnueabihf/libidn2.so.0
            libunistring.so.2 => /usr/lib/arm-linux-gnueabihf/libunistring.so.2
        librtmp.so.1 => /usr/lib/arm-linux-gnueabihf/librtmp.so.1
            libgnutls.so.30 => /usr/lib/arm-linux-gnueabihf/libgnutls.so.30
                libp11-kit.so.0 => /usr/lib/arm-linux-gnueabihf/libp11-kit.so.0
                    libffi.so.6 => /usr/lib/arm-linux-gnueabihf/libffi.so.6
                        libgcc_s.so.1 => /lib/arm-linux-gnueabihf/libgcc_s.so.1
                    libdl.so.2 => /lib/arm-linux-gnueabihf/libdl.so.2
                libtasn1.so.6 => /usr/lib/arm-linux-gnueabihf/libtasn1.so.6
                libnettle.so.6 => /usr/lib/arm-linux-gnueabihf/libnettle.so.6
                libhogweed.so.4 => /usr/lib/arm-linux-gnueabihf/libhogweed.so.4
            libhogweed.so.6 => not found
            libnettle.so.8 => not found
            libgmp.so.10 => /usr/lib/arm-linux-gnueabihf/libgmp.so.10
        libssh2.so.1 => /usr/lib/arm-linux-gnueabihf/libssh2.so.1
            libgcrypt.so.20 => /lib/arm-linux-gnueabihf/libgcrypt.so.20
                libgpg-error.so.0 => /lib/arm-linux-gnueabihf/libgpg-error.so.0
        libpsl.so.5 => /usr/lib/arm-linux-gnueabihf/libpsl.so.5
        libssl.so.1.1 => /usr/lib/arm-linux-gnueabihf/libssl.so.1.1
        libcrypto.so.1.1 => /usr/lib/arm-linux-gnueabihf/libcrypto.so.1.1
        libgssapi_krb5.so.2 => /usr/lib/arm-linux-gnueabihf/libgssapi_krb5.so.2
            libkrb5support.so.0 => /usr/lib/arm-linux-gnueabihf/libkrb5support.so.0
            libkeyutils.so.1 => /lib/arm-linux-gnueabihf/libkeyutils.so.1
            libresolv.so.2 => /lib/arm-linux-gnueabihf/libresolv.so.2
        libkrb5.so.3 => /usr/lib/arm-linux-gnueabihf/libkrb5.so.3
        libk5crypto.so.3 => /usr/lib/arm-linux-gnueabihf/libk5crypto.so.3
        libcom_err.so.2 => /lib/arm-linux-gnueabihf/libcom_err.so.2
        libldap_r-2.4.so.2 => /usr/lib/arm-linux-gnueabihf/libldap_r-2.4.so.2
            libsasl2.so.2 => /usr/lib/arm-linux-gnueabihf/libsasl2.so.2
        liblber-2.4.so.2 => /usr/lib/arm-linux-gnueabihf/liblber-2.4.so.2
    libz.so.1 => /lib/arm-linux-gnueabihf/libz.so.1
    libpthread.so.0 => /lib/arm-linux-gnueabihf/libpthread.so.0
    libc.so.6 => /lib/arm-linux-gnueabihf/libc.so.6
    ld-linux-armhf.so.3 => /lib/ld-linux-armhf.so.3
Many thanks. So it's librtmp.so.1 which keeps pulling in the Bullseye libraries. Can you try:
apt install --reinstall librtmp1
curl -I https://dietpi.com/
The question is how it is possible that restoring the backup does not restore this library as well, as all old files should be restored. Or if there is something patching the ELF header of this file after it was restored.
on a short test this seems to fix the curl issue, at least on my test system.
Lycidias
Post by Lycidias »
I successfully updated my pi4 to bullseye. Thanks :)
Cloned my SD to a faster one with w32 disk imager.
Everything is working so far, including my existing pihole and Jdownloader configuration.
I only need to test samba because there was a new samba.conf in the new package.
hopefully the configuration file did not get overwritten
Lycidias
Post by Lycidias »
I decided to take the new samba.conf but backed up my old one. I need to investigate and integrate my settings on the new one
I did a small test and the old config should work as well.
jetspeed
Post by jetspeed »
MichaIng wrote: Mon Sep 20, 2021 6:46 pm Many thanks. So it's librtmp.so.1 which keeps pulling in the Bullseye libraries. Can you try:
Many thanks, that did the trick!!! You guys are all my new best friends ;)
h_media
Post by h_media »
Hello, I'm just following the HOW TO UPGRADE TO “BULLSEYE” blog post, and have this warning after the apt update step:
W: Skipping acquire of configured file 'ui/binary-armhf/Packages' as repository 'https://archive.raspberrypi.org/debian bullseye InRelease' doesn't have the component 'ui' (component misspelt in sources.list?)
This is for a headless install, this seems to allude to a 'ui' / user interface? - Is this something I can ignore, or should I backtrack?
@h_media
Quite simple. You would need to edit /etc/apt/sources.list.d/raspi.list and remove the ui. This should fix the error message.
