curl: error while loading shared libraries
alleyu2
Re: curl: error while loading shared libraries
Post by alleyu2 »
No didn't help
root@DietPi-Pi4:~# ldd $(which curl)
        linux-vdso.so.1 (0xbeec6000)
        /usr/lib/arm-linux-gnueabihf/libarmmem-${PLATFORM}.so => /usr/lib/arm-linux-gnueabihf/libarmmem-v7l.so (0xb6fa7000)
        libcurl.so.4 => /usr/lib/arm-linux-gnueabihf/libcurl.so.4 (0xb6f11000)
        libz.so.1 => /lib/arm-linux-gnueabihf/libz.so.1 (0xb6ee6000)
        libpthread.so.0 => /lib/arm-linux-gnueabihf/libpthread.so.0 (0xb6ebc000)
        libc.so.6 => /lib/arm-linux-gnueabihf/libc.so.6 (0xb6d6e000)
        /lib/ld-linux-armhf.so.3 (0xb6fbc000)
        libnghttp2.so.14 => /usr/lib/arm-linux-gnueabihf/libnghttp2.so.14 (0xb6d3f000)
        libidn2.so.0 => /usr/lib/arm-linux-gnueabihf/libidn2.so.0 (0xb6d13000)
        librtmp.so.1 => /usr/lib/arm-linux-gnueabihf/librtmp.so.1 (0xb6cea000)
        libssh2.so.1 => /usr/lib/arm-linux-gnueabihf/libssh2.so.1 (0xb6cb4000)
        libpsl.so.5 => /usr/lib/arm-linux-gnueabihf/libpsl.so.5 (0xb6c94000)
        libssl.so.1.1 => /usr/lib/arm-linux-gnueabihf/libssl.so.1.1 (0xb6c15000)
        libcrypto.so.1.1 => /usr/lib/arm-linux-gnueabihf/libcrypto.so.1.1 (0xb69fb000)
        libgssapi_krb5.so.2 => /usr/lib/arm-linux-gnueabihf/libgssapi_krb5.so.2 (0xb69b1000)
        libkrb5.so.3 => /usr/lib/arm-linux-gnueabihf/libkrb5.so.3 (0xb68f6000)
        libk5crypto.so.3 => /usr/lib/arm-linux-gnueabihf/libk5crypto.so.3 (0xb68b6000)
        libcom_err.so.2 => /lib/arm-linux-gnueabihf/libcom_err.so.2 (0xb68a3000)
        libldap_r-2.4.so.2 => /usr/lib/arm-linux-gnueabihf/libldap_r-2.4.so.2 (0xb684e000)
        liblber-2.4.so.2 => /usr/lib/arm-linux-gnueabihf/liblber-2.4.so.2 (0xb6832000)
        libunistring.so.2 => /usr/lib/arm-linux-gnueabihf/libunistring.so.2 (0xb66b6000)
        libgnutls.so.30 => /usr/lib/arm-linux-gnueabihf/libgnutls.so.30 (0xb6513000)
        libhogweed.so.6 => not found
        libnettle.so.8 => not found
        libgmp.so.10 => /usr/lib/arm-linux-gnueabihf/libgmp.so.10 (0xb649a000)
        libgcrypt.so.20 => /lib/arm-linux-gnueabihf/libgcrypt.so.20 (0xb63c0000)
        libdl.so.2 => /lib/arm-linux-gnueabihf/libdl.so.2 (0xb63ad000)
        libkrb5support.so.0 => /usr/lib/arm-linux-gnueabihf/libkrb5support.so.0 (0xb6393000)
        libkeyutils.so.1 => /lib/arm-linux-gnueabihf/libkeyutils.so.1 (0xb637f000)
        libresolv.so.2 => /lib/arm-linux-gnueabihf/libresolv.so.2 (0xb635b000)
        libsasl2.so.2 => /usr/lib/arm-linux-gnueabihf/libsasl2.so.2 (0xb6334000)
        libp11-kit.so.0 => /usr/lib/arm-linux-gnueabihf/libp11-kit.so.0 (0xb622f000)
        libtasn1.so.6 => /usr/lib/arm-linux-gnueabihf/libtasn1.so.6 (0xb620f000)
        libnettle.so.6 => /usr/lib/arm-linux-gnueabihf/libnettle.so.6 (0xb61cb000)
        libhogweed.so.4 => /usr/lib/arm-linux-gnueabihf/libhogweed.so.4 (0xb618c000)
        libgpg-error.so.0 => /lib/arm-linux-gnueabihf/libgpg-error.so.0 (0xb6162000)
        libffi.so.6 => /usr/lib/arm-linux-gnueabihf/libffi.so.6 (0xb614a000)
        libgcc_s.so.1 => /lib/arm-linux-gnueabihf/libgcc_s.so.1 (0xb611d000)
maybe you would need to complete the Bullseye upgrade to overcome the situation.
alleyu2
Post by alleyu2 »
I tried that as well but somehow proftpd breaks the upgrade and then it doesn't continue. I can try again and show you the error. Out of curiosity, this is the out of apt policy for curl.
apt policy curl
curl:
  Installed: 7.64.0-4+deb10u2
  Candidate: 7.64.0-4+deb10u2
  Version table:
     7.74.0-1.3 -1
         -1 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
 *** 7.64.0-4+deb10u2 500
        500 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages
        100 /var/lib/dpkg/status
yes if possible pls share the issue with ProFTP but this I would recommend to continue on a new topic for ProFTP issue during upgrade
Please run the following:
apt install pax-utils
lddtree /usr/bin/curl
omavoss
Post by omavoss »
Joulinar wrote: Thu Sep 16, 2021 10:33 am maybe you would need to complete the Bullseye upgrade to overcome the situation.
I apologize in advance, but my problem is not only mine, but that of my whole family.
I have rebuilt Bullseye, installed the Baikal plugin and copied my previously saved directory /var/www/baikal into the new installation, overwriting the original configuration.
Unfortunately Baikal doesn't work anymore, I get an error message that baikal.yaml can't connect to mysql.
Baïkal was not able to establish a connexion to the configured MySQL database (as configured in config/baikal.yaml).
I can unfortunately update the old Dietpi system 7.4.2 (beta) because of the curl error nor successfully import the Baikal calendar into the new system 7.6 or Bullseye without losing the existing calendar data. This gives me quite significant problems with my entire family, because the Baikal calendar is synchronized on multiple devices.
Is there any way to get the old baikal.yaml to connect to the new mysql?
Thank you for understanding and kind regards.
Translated with www.DeepL.com/Translator (free version)
What about restoring the system to get Baikal back working, even if the curl issue persists
omavoss
Post by omavoss »
Hello, there is obviously a misunderstanding here.
I have rebuilt a Dietpi system 7.6.1, there is not the curl problem.There I installed the Baikal plugin and copied the /var/www/baikal directory from Dietpi 7.4.2 (system with the curl problem) into the new Dietpi 7.6.1. Nevertheless the Baikal calendar does not work, it comes the error
So I would like to repair and update the 7.4.2 system (the one with the curl problem) or run my old baikal.yaml in the new 7.6.1 system (whitout the curl problem).
So this baikal.yaml does work under Dietpi 7.4.2 and not under the new Dietpi 7.6.1.
Thanks for understanding.
What is the reason not to update the system running 7.4 to Bullseye?
omavoss
Post by omavoss »
I follow the howto for upgrading to Bullseye exactly:
https://dietpi.com/blog/?p=811
After the procedure is fully executed and the reboot is due, network connection via eth0 does not work anymore.
Therefore I reset the system with "dietpi-backup -1" and am now back on 7.4.1 with the known curl error.
Thank you.
