Upgrade from Buster to Bullseye Topic is solved
Niwre
Re: Upgrade from Buster to Bullseye
Post by Niwre »
@Joulinar
Up to dietpi-software reinstall 93 everything went through without any problems, but now there is an error, see screenshot.
You have ProFTP installed?
Niwre
Post by Niwre »
@Joulinar
yes, this is shown under dietpi software. :o
If not needed you could remove it. Otherwise we would need to fix it.
Niwre
Post by Niwre »
@Joulinar
I uninstalled it and now it worked, PiHole is running again including interface. Thank you for your support, without your help I would not have made it. :)
Best Regards
Niwre
you are welcome. Good to see our way/steps is working.
Lycidias
Post by Lycidias »
Does someone know if I will run into possible issues when upgrading to bullseye?
Thanks
For RealVNC there is currently a workaround required: https://github.com/MichaIng/DietPi/issues/4749
Not directly related to Bullseye but as of a recent breaking change in the RPi video core libraries.
