PiHole Web Interface is not working
Re: PiHole Web Interface is not working
yes correct it would be needed to to place the SD card into another Linux box
Caporeira
Post by Caporeira »
Ok, now problem, please let mi know what i should do when put this sd card to another Linux box ?
one card is placed, don't mount it :)
Just check the device name
one we know the device name, I could give you the command to have it checked.
Caporeira
Post by Caporeira »
lukas@ubuntu:~$ lsblk -o name,fstype,label,size,ro,type,mountpoint,partuuid,uuid
NAME FSTYPE LABEL  SIZE RO TYPE MOUNTPOINT PARTUUID                             UUID
fd0                1.4M  0 disk
loop0
     squash       55.4M  1 loop /snap/core
loop1
     squash       65.1M  1 loop /snap/gtk-
loop2
     squash         51M  1 loop /snap/snap
loop3
     squash       32.3M  1 loop /snap/snap
loop4
     squash        219M  1 loop /snap/gnom
sda                 15G  0 disk
├─sda1
│    vfat          512M  0 part /boot/efi  392ce3ee-01                          0D93-38D7
├─sda2
│                    1K  0 part            392ce3ee-02
└─sda5
     ext4         14.5G  0 part /          392ce3ee-05                          666abd6b-cb49-4da5-a642-7856ceef633f
sr0               1024M  0 rom
sr1               1024M  0 rom
lukas@ubuntu:~$
root@DESKTOP:~# lsblk -o name,fstype,label,size,ro,type,mountpoint,partuuid,uuid
lsblk: failed to access sysfs directory: /sys/dev/block: No such file or directory
root@DESKTOP:~#
I don't see the SD card connected to the ubuntu box. Not sure if anything is needed to share USB devices from W10 to ubuntu.
Caporeira
Post by Caporeira »
This looks better :)
loop0  squashfs        55.4M  1 loop /snap/core18/2128
loop1  squashfs        32.3M  1 loop /snap/snapd/12704
loop2  squashfs        65.1M  1 loop /snap/gtk-common-themes/1515
loop3  squashfs        32.3M  1 loop /snap/snapd/12883
loop4  squashfs         219M  1 loop /snap/gnome-3-34-1804/72
loop5  squashfs          51M  1 loop /snap/snap-store/547
sda                    14.9G  0 disk
├─sda1 vfat     boot    256M  0 part                              e8af6eb2-01                          DC3E-E470
└─sda2 ext4     rootfs 14.6G  0 part                              e8af6eb2-02                          a7adb26a-8b87-4729-99c8-9f5ac069d51e
sdb                      15G  0 disk
├─sdb1 vfat             512M  0 part /boot/efi                    392ce3ee-01                          0D93-38D7
├─sdb2                    1K  0 part                              392ce3ee-02
└─sdb5 ext4            14.5G  0 part /                            392ce3ee-05                          666abd6b-cb49-4da5-a642-7856ceef633f
sr0                    1024M  0 rom
lukas@ubuntu:~$
I didn't read the whole topic but I think the goal is to do an fsck on the RPi SD card, right?
Run:
# First the boot partition
fsck /dev/sda1
# Then the root partition
fsck -f /dev/sda2
@MichaIng
would it need to be dosfsck on sda1 as it is vfat patition. Something like this?
dosfsck /dev/sda1
fsck -a /dev/sda2
fsck is a wrapper which automatically appends the detected filesystem type, so calls fsck.vfat, which is a symlink to fsck.fat, like dosfsck is. Means fsck can usually be called for every filesystem, at least on Debian. The dosfstools package of course needs to be installed.
Caporeira
Post by Caporeira »
What that's mean ?
My SD card / RPi ist broken or dietpi missing some software?
PS. On another SD card I have installed new dietpi+PiHole. And YouTube on my Android TV was blocked. With filter should I disable ?
