mariadb failed Topic is solved
Re: mariadb failed
ok we are one step further. Next to do
mv /mnt/dietpi_userdata/mysql/tc.log /mnt/dietpi_userdata/mysql/tc.save
systemctl restart mariadb.service
again pls post the error log if not working
naha
Re: mariadb failed
Post by naha »
That fixed it! Thank you very much for your help today. 8)
naha
Re: mariadb failed
Post by naha »
I donated as a small thank you!
Re: mariadb failed
ok good. Just to sum it up: you had incorrect file system permission in first place and MariaDB was not able to write to the database directory. Second issue was a corrupted file we moved away.
naha wrote: Thu May 20, 2021 12:02 am I donated as a small thank you!
Much appreciated
naha
Re: mariadb failed
Post by naha »
Perfect. I think I understand.
