can't install on qnap debian VM Topic is solved
manilx
Re: can't install on qnap debian VM
Post by manilx »
That’s what I did but hangs on booting from HD.
There’s probably a way around this but as I have it running via Debian install it’s not worth digging into it.
Ok as the result is same, it doesn't matter how you set it up. 8)
