not booting up
bar1
Re: not booting up
Post by bar1 »
anyone?
Re: not booting up
Maybe @MichaIng has some more ideas
Re: not booting up
Can you show the content of this FSCK000 file? In case the first few lines would be enough.
From what I see all required file are present with valid metadata. Do you load any dtoverlay, i.e. is there a related line in config.txt and is the related dtbo file present in /boot/overlay/? Although a missing overlay should not prevent boot.
Here are the files that match your kernel version btw: https://github.com/raspberrypi/firmware ... f4afe/boot
At least as long as you didn't use rpi-update manually. So we can try to manually replace all files from there, at best from an external host.
Also as a failsafe step, you could do a filesystem check on a Windows machine, which AFAIK deals with FAT partitions better than the dosfsutils for Linux.
bar1
Re: not booting up
Post by bar1 »
thanks, let me try replace the files.
