great. what would you recommend. cloning the VM to another PC or restoring dietpi from a backup?`
best wishes!
export dietpi-backup Topic is solved
Re: export dietpi-backup
Cloning a VM depends on your VM software. usually there are containers that couple be simply copied from A to B
