Feature request - cloudshell XU4
Fourdee
Re: Feature request - cloudshell XU4
Post by Fourdee »
Thanks John, \040 looking good.
I've updated the Cloudshell script. There was an issue with it failing to correctly handle storage paths with whitespace in them. Hopefully this fixes the 'mount not active' aswell.
Please run the following to update DietPi-Cloudshells:
wget https://raw.githubusercontent.com/Fourdee/DietPi/testing/dietpi/dietpi-cloudshell -O /DietPi/dietpi/dietpi-cloudshell
Restart DietPi-Cloudshell and let me know how it goes.
Thanks John.
johnvick
Legend
Post by johnvick »
HI Fourdee,
Again thanks for your efforts with this but still the same I am afraid with the "Mount not active" message.
It is not always there and mostly affects the rootfs drive. The numbers are fine it's just this message.
John
Fourdee
Post by Fourdee »
johnvick wrote:HI Fourdee,
John
Hi John,
Really bizarre, if anything the obtained values should be incorrect for the following mounts (due to whitespace):
192.168.1.4:/Multimedia/Music/John's iTunes/Music
192.168.1.4:/TV Series
192.168.1.4:/TV Documentaries
192.168.1.4:/Music Videos
in FSTAB I commented out the shares with spaces in their names, rebooted, and no "Mount not active" message.
Just wondering if this is caused by the above. Leave it with me :)
johnvick
Legend
Post by johnvick »
Hi Fourdee,
I only display the stats for three drives on the Cloudshell display and they are all attached to the XU4 - an eMMC, a USB flash and an SSD inside the case - not any of the shares on the QNAP.
John
Fourdee
Post by Fourdee »
johnvick wrote:Hi Fourdee,
John
Hi John,
Appreciate your patience with this. Unfortunately, Its going to be trial and error testing on this one, as I cant replicate.
Lets try invoking Sync and POSIX output from df. Please download the latest version, reboot and test, let us know results:
Thanks John
johnvick
Legend
Post by johnvick »
HI Fourdee,
Thanks for your continued efforts with this - unfortunately this version does not show any info at all - just N/A and Mount not active.
It's putting a "mount not found" message in the log every few seconds.
John
Fourdee
Post by Fourdee »
John
Hi John,
I've added additional debugging (logging) code to dietpi-cloudshell. Please can you update your version, reboot, and test:
When the scene fails to pull the drive data, please make a rough note of the time, then upload /var/log/dietpi-cloudshell.log to pastebin so I can check results.
Thanks John.
johnvick
Legend
Post by johnvick »
HI FOurdee,
Thanks again - I'll just post a section of the log here:
_____________________________________________
Tue 13 Dec 06:43:24 NZDT 2016 | Mount not found:
- Index = 2
- Path = /mnt/usb_2
- Index = 3
- Path = /mnt/usb_3
Tue 13 Dec 06:44:06 NZDT 2016 | Mount not found:
- Index = 0
- Path = /
- Index = 1
- Path = /mnt/usb_1
Tue 13 Dec 06:44:11 NZDT 2016 | Mount not found:
- Index = 2
- Path = /mnt/usb_2
- Index = 3
- Path = /mnt/usb_3
Fourdee
Post by Fourdee »
johnvick wrote: Tue 13 Dec 06:44:06 NZDT 2016 | Mount not found:
- Index = 0
- Path = /
Think i've found the cause, leave it with me, will attempt fix :)
Fourdee
Post by Fourdee »
Hi John,
Please try this updated version and let me know if 'mount not found' reoccurs:
Restart service
systemctl restart dietpi-cloudshell
