Static Route: VPN Gateway behind fritzbox
beerenheini
Re: Static Route: VPN Gateway behind fritzbox
Post by beerenheini »
Joulinar wrote: Sun Feb 23, 2020 3:31 pm unfortunately I don't have an external WireGuard Server that I could use for testing. Otherwise I would play around with it :?
I specified 192.168.178.52 as Gateway..
Pls van you post ip -a as weil as ip -r from your RPi
Whether external or internal should not play a major role, hence testing with local VM should be possible add well. But I'll not find some time soon ;).
