[Solved] Docker does not start on clean image on RaspberryPi3
Re: Docker does not start on clean image on RaspberryPi3
Thanks for report and solution.
Will be fixed with next release :).
Garret
Post by Garret »
mspieth wrote: Tue Nov 13, 2018 12:49 pm Until the bug is fixed within dietpi, it's easy to fix on your own.
1. Install docker #162 normally via dietpi-software.
2. At the end of the install, docker will fail to start, thats ok for now.
3. nano /lib/systemd/system/docker.service
4. Find the line that says: ExecStart=/usr/bin/dockerd -g /mnt/dietpi_userdata/docker-data -H fd://
5. Either delete that line or comment it out by adding a # in front of the line.
6. Add the following line just below the original line: ExecStart=/usr/bin/dockerd -g /mnt/dietpi_userdata/docker-data -H unix://
7. Save the file
8. service docker start
That's it.
You could also just edit the above mentioned file and replace the fd:// with unix://
To me it still does not work by doing in this way with a fresh new installation of DietPi. Even if I give "systemctl daemon-reload" and then "service docker start" or in the opposite order.
root@dietpi:~# docker ps
Cannot connect to the Docker daemon at unix:///var/run/docker.sock. Is the docker daemon running?
root@dietpi:~#
My "/lib/systemd/system/docker.service"
[Service]
Type=notify
# the default is not to use systemd for cgroups because the delegate issues still
# exists and systemd currently does not support the cgroup feature set required
# for containers run by docker
ExecReload=/bin/kill -s HUP $MAINPID
TimeoutSec=0
RestartSec=2
Restart=always
Did you do:
before restarting the service? At best do this via:
systemctl restart docker
Garret
Post by Garret »
MichaIng wrote: Sun Nov 18, 2018 6:56 pm Did you do:
@MichaIng Yes, I had already done that as I wrote in my previous message but I did it again now after rebooting the raspberry pi. Still Docker does not work.
root@router:~# nano /lib/systemd/system/docker.service
root@router:~# systemctl daemon-reload
root@router:~# systemctl restart docker
Job for docker.service canceled.
root@router:~# systemctl status docker.service
● docker.service - Docker Application Container Engine
   Loaded: loaded (/lib/systemd/system/docker.service; disabled; vendor preset: enabled)
   Active: failed (Result: core-dump) since Sun 2018-11-18 20:48:51 CET; 6s ago
     Docs: https://docs.docker.com
  Process: 9258 ExecStart=/usr/bin/dockerd -g /mnt/dietpi_userdata/docker-data -H unix:// (code=dumped, signal=SEGV)
 Main PID: 9258 (code=dumped, signal=SEGV)
      CPU: 625ms
Nov 18 20:48:48 router systemd[1]: Starting Docker Application Container Engine...
Nov 18 20:48:51 router systemd[1]: docker.service: Main process exited, code=dumped, status=11/SEGV
Nov 18 20:48:51 router systemd[1]: Stopped Docker Application Container Engine.
Nov 18 20:48:51 router systemd[1]: docker.service: Unit entered failed state.
Nov 18 20:48:51 router systemd[1]: docker.service: Failed with result 'core-dump'.
root@router:~#
Okay so there is anther issue then. Please check docker logs for more details.
Garret
Post by Garret »
MichaIng wrote: Sun Nov 18, 2018 8:52 pm
Sorry I am very newbie to Docker. May I ask what should I do exactly?
iaresee
Post by iaresee »
Found this post because I'm struggling to get docker running under dietpi on my RPi3 as well.
Garret wrote: Sun Nov 18, 2018 8:55 pm Sorry I am very newbie to Docker. May I ask what should I do exactly?
So under systemd the command to run is:
journalctl -fu docker.service
For me, on my system, where dockerd is failing to start this doesn't really give me anything useful:
root@pi-hole:~# journalctl -fu docker.service
-- Logs begin at Thu 2016-11-03 17:16:44 GMT. --
Nov 23 22:20:08 pi-hole systemd[1]: Starting Docker Application Container Engine...
Nov 23 22:20:12 pi-hole systemd[1]: docker.service: Main process exited, code=dumped, status=11/SEGV
Nov 23 22:20:12 pi-hole systemd[1]: Stopped Docker Application Container Engine.
Nov 23 22:20:12 pi-hole systemd[1]: docker.service: Unit entered failed state.
Nov 23 22:20:12 pi-hole systemd[1]: docker.service: Failed with result 'core-dump'.
Nov 23 22:20:27 pi-hole systemd[1]: Starting Docker Application Container Engine...
Nov 23 22:20:31 pi-hole systemd[1]: docker.service: Main process exited, code=dumped, status=11/SEGV
Nov 23 22:20:31 pi-hole systemd[1]: Stopped Docker Application Container Engine.
Nov 23 22:20:31 pi-hole systemd[1]: docker.service: Unit entered failed state.
Nov 23 22:20:31 pi-hole systemd[1]: docker.service: Failed with result 'core-dump'.
I have no core dumps in /var/lib/systemd/coredump/ on my host. I also seem to be missing systemd-coredumpctl or coredumpctl...
Did you do the systemd unit change as mentioned above:
sed -i 's|fd://|unix://|' /lib/systemd/system/docker.service
iaresee
Post by iaresee »
MichaIng wrote: Sat Nov 24, 2018 10:37 pm Did you do the systemd unit change as mentioned above
Yup.
root@pi-hole:~# cat /lib/systemd/system/docker.service | grep ExecStart
Also made certain /mnt/dietpi_userdata/docker-data existed and had suitable permissions on it.
Garret
Post by Garret »
MichaIng wrote: Sat Nov 24, 2018 10:37 pm Did you do the systemd unit change as mentioned above:
@MichaIng it has already been mentioned several times that what you wrote was tried.
Anyways, I found out that the problem is apparently in the latest version of docker for rapsberry pi(arm). I realized the problem was this after I still got it not working by installing it on a new diet pi installation but with the docker official script.
Thus, in order to make it working for the moment these are the steps I did:
Install dietpi image
Run docker install script
Run sudo apt-get install docker-ce=18.06.1~ce~3-0~raspbian
The last step downgrades installs the previous version of docker.
Source: https://github.com/moby/moby/issues/381 ... -439733278
