Jdownloader cannot start
kami
Re: Jdownloader cannot start
Post by kami »
Okay. I will try it. If i finished i give you the log.
Cu kami
kami
Post by kami »
just fixed it. After reinstall as a user it runs fine in headless mode with myjdownloder. But can you please tell me if there is a way to open the GUI?
Thanks a lot.
Cu kami
lucasmenno
Post by lucasmenno »
If you have your Desktop Environment running, open terminal and execute
java -jar /root/jdownloader/JDownloader.jar
This won't open any GUI when you're connected via SSH ;)
Everything i say can and maybe will be corrected by the DietPi seniors in this forum :D
BananaPi M1 using image for BananaPi Pro.
-1TB HDD, Network storage,Downloader(JD,Deluge,ripme) testing what looks interesting.
kami
Post by kami »
I am trying this over VNC and if i open a terminal and put this in side it only started headless??
lucasmenno
Normally it SHOULD work...
Is there any error showing in the terminal?
kami
Post by kami »
There is no error in the terminal. It just trying to make an update. But than it hangs. Java runs with 0,5 % usage.
kami
Post by kami »
Update Message: Nach Aktualisierungen suchen
Update Progress: 3%
Update Progress: -1%
Update Message: Kontaktiere Server...
lucasmenno
I tried some settings myself.
I am unable to get to the Mate Desktop vith VNC, but with RDP.
If you are running JD headless you need to kill it first to start the other one in the desktop.
Kinda running low on options and tipps here :roll:
Can you show me what you are seeing in an screenshot etc.? :?:
kami
Post by kami »
i am using the Mate Desktop with VNC and this runs fine. I am opening a Mate Terminal and then i only the some Thread and that it shows this and after hour the percentage change but never finished.
Cu kami
kami
Post by kami »
Updateprocess is now finished:
Update Progress: 3%
Update Progress: 100%
But the is no screen coming up? Always only headless?
Cu kami
