4
112191
29 October 2023
Orange pi 3b NVME problem
38
258
4 May 2024
New Open Source to twingate
2
27
4 May 2024
Allo USBridge Signature No sound through HDMI
4
40
4 May 2024
Deluge downloads through Wireguard but uploads outside the tunnel?
3
36
4 May 2024
Errors when setting samba and nfs share (usb stick)
7
19
4 May 2024
Question on Media Server
5
43
4 May 2024
[Raspberry Pi 5] Banding/Dithering on Images in Chromium Kiosk
2
36
4 May 2024
Ffmpeg libary problem
4
38
4 May 2024
Raspberry PI 5 pci boot with nvme, error with 'rpi-eeprom'
9
68
3 May 2024
Filesystem stuck on Read-Only
5
31
3 May 2024
USB Wifi Scan issues AR9271
7
32
3 May 2024
DietPi fresh install WiFi issues on Raspberry Pi Zero 2 W
16
720
3 May 2024
How to manually install Amiberry 5.70 on Dietpi 9.30 thanks
3
41
3 May 2024
Switch from lighttpd to nginx wihout reinstalling nextcloud
1
32
3 May 2024
Umm, Parallels arm64 images for download
1
33
3 May 2024
Raspberry Pi 5: Xorg issues - Chromium Autostart (Cannot run in framebuffer mode)
14
227
3 May 2024
38
250
3 May 2024
Support for Radxa Zero 3W
4
122
3 May 2024
Share of Unofficial DietPi - Radxa Zero 3W
46
957
3 May 2024
AdGuard Home, static IP
2
38
3 May 2024
DietPi on RK3328 Rk3318 TVBOX
9
3476
2 May 2024
NanoPi NEO running unstable since latest update
6
84
2 May 2024
Error with balena etcher and dietpi image
2
32
2 May 2024
11
181
2 May 2024
Alsa Mixer MAX98357
1
61
2 May 2024
App nextcloud iOS: browser is not supported
14
94
2 May 2024
Unable to connect to IPVanish: End-of-central-directory signature not found. Either this file is not a zipfile, or it constitutes one disk of a multi-part archive
1
203
1 May 2024
Where to add kernel command line options on Odroid C2 running Dietpi latest
1
70
1 May 2024
Backup location not being used by dietpi-update
3
37
1 May 2024
