4
112181
29 October 2023
Raspberry Pi 5: Xorg issues - Chromium Autostart (Cannot run in framebuffer mode)
14
216
3 May 2024
38
212
3 May 2024
Orange pi 3b NVME problem
36
247
3 May 2024
USB Wifi Scan issues AR9271
6
25
3 May 2024
Question on Media Server
4
31
3 May 2024
Support for Radxa Zero 3W
4
120
3 May 2024
Raspberry PI 5 pci boot with nvme, error with 'rpi-eeprom'
8
53
3 May 2024
Share of Unofficial DietPi - Radxa Zero 3W
46
947
3 May 2024
Filesystem stuck on Read-Only
4
20
3 May 2024
Ffmpeg libary problem
2
22
3 May 2024
AdGuard Home, static IP
2
29
3 May 2024
DietPi on RK3328 Rk3318 TVBOX
9
3464
2 May 2024
Deluge downloads through Wireguard but uploads outside the tunnel?
2
29
3 May 2024
NanoPi NEO running unstable since latest update
6
84
2 May 2024
[Raspberry Pi 5] Banding/Dithering on Images in Chromium Kiosk
0
22
2 May 2024
Error with balena etcher and dietpi image
2
30
2 May 2024
11
173
2 May 2024
Alsa Mixer MAX98357
1
58
2 May 2024
App nextcloud iOS: browser is not supported
14
92
2 May 2024
Allo USBridge Signature No sound through HDMI
3
34
2 May 2024
Umm, Parallels arm64 images for download
0
23
2 May 2024
Unable to connect to IPVanish: End-of-central-directory signature not found. Either this file is not a zipfile, or it constitutes one disk of a multi-part archive
1
140
1 May 2024
Switch from lighttpd to nginx wihout reinstalling nextcloud
0
24
1 May 2024
Where to add kernel command line options on Odroid C2 running Dietpi latest
1
46
1 May 2024
How to manually install Amiberry 5.70 on Dietpi 9.30 thanks
2
32
1 May 2024
Backup location not being used by dietpi-update
3
35
1 May 2024
Wordpress install; Unsupported special character in password causing SQL error
3
66
30 April 2024
Whilst Plex is working shutdown all other services
8
77
30 April 2024
DietPi fresh install WiFi issues on Raspberry Pi Zero 2 W
14
704
30 April 2024
