4
112172
29 October 2023
Raspberry PI 5 pci boot with nvme, error with 'rpi-eeprom'
6
33
1 May 2024
Error with balena etcher and dietpi image
1
10
1 May 2024
Unable to connect to IPVanish: End-of-central-directory signature not found. Either this file is not a zipfile, or it constitutes one disk of a multi-part archive
1
25
1 May 2024
Switch from lighttpd to nginx wihout reinstalling nextcloud
0
13
1 May 2024
25
169
1 May 2024
Where to add kernel command line options on Odroid C2 running Dietpi latest
1
20
1 May 2024
How to manually install Amiberry 5.70 on Dietpi 9.30 thanks
2
26
1 May 2024
Allo USBridge Signature No sound through HDMI
2
21
1 May 2024
Backup location not being used by dietpi-update
3
30
1 May 2024
Share of Unofficial DietPi - Radxa Zero 3W
42
905
30 April 2024
Raspberry Pi 5: Xorg issues - Chromium Autostart (Cannot run in framebuffer mode)
11
197
30 April 2024
NanoPi NEO running unstable since latest update
3
64
30 April 2024
App nextcloud iOS: browser is not supported
11
82
30 April 2024
Wordpress install; Unsupported special character in password causing SQL error
3
64
30 April 2024
Whilst Plex is working shutdown all other services
8
77
30 April 2024
DietPi fresh install WiFi issues on Raspberry Pi Zero 2 W
14
695
30 April 2024
Weird error on startup with caja
9
565
30 April 2024
Kindly review my custom user script for pre/post DietPi install automation!
2
81
30 April 2024
Dietpi-VPN GATEWAY with Pivpn server and Pihole
33
1105
30 April 2024
Dietpi x64 Migrate dietpi_userdata to a newer larger drive
1
46
29 April 2024
SSH issue using key - root works, second user don't
2
42
29 April 2024
Problems with the .htaccess file after updating nextcloud on an orangepi5
3
53
29 April 2024
NanoPi R5S - Boot from NVMe
24
1260
29 April 2024
DietPi on RK3328 Rk3318 TVBOX
8
3443
28 April 2024
Orange pi 3b NVME problem
31
231
27 April 2024
None of iptables persistent methods working
9
4764
27 April 2024
New UDOO boards
6
3104
27 April 2024
New Turingpi RK1
7
280
26 April 2024
Version for Odroid M1?
22
3047
26 April 2024
